Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Apr 7, 2017 at 3:03 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Monte,
    You ever hear back on the parts truck in Cheyenne?
  2. Apr 7, 2017 at 3:11 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yea finally today.
    Took him forever. haha
    Haven't responded but i guess they just chopped the cab so should have everything i need.
    BossFoss[QUOTED] likes this.
  3. Apr 7, 2017 at 3:33 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  4. Apr 7, 2017 at 3:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    i don't get it..
  5. Apr 7, 2017 at 3:39 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I keep seeing these, within my reach. Same thing happened a few weeks ago on the scs website. A set was available when I looked.
    Its too bad they weren't the gunmetals in 16s. I would have snapped them up but no... they are always these copper things.
  6. Apr 7, 2017 at 4:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    you mean you checked the site when the last shipment was in..and there were coopers available but not gunmetal ones? wow.
  7. Apr 7, 2017 at 4:08 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, but it was 'lucky' fluke that I even saw them. 15 minutes later that were gone.
  8. Apr 7, 2017 at 4:09 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    when you went back thinking "fuck it, copper it is" :p haha
    so gonna get some Ray10s officially? least try..haha 16s? the 285/75r17 size wasn't appealing?
  9. Apr 7, 2017 at 5:51 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
  10. Apr 7, 2017 at 6:30 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :facepalm: Ah..no.
    And too phat.
  11. Apr 7, 2017 at 8:26 PM
    SconnieHailer
    Marc
    @BossFoss 295's work great :wink:
    My 295 work great too but I'm a 2nd 'degeneration
  12. Apr 7, 2017 at 8:46 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    They do good. Snug in the front but I think I'm only at 2 1/2 of the 3 I can go in the front
    Blackdawg[OP] likes this.
  13. Apr 7, 2017 at 8:52 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  14. Apr 7, 2017 at 8:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    do you have UCAs? what's your castor at?
  15. Apr 7, 2017 at 8:54 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Yes on the UCA's. Castor is Toyota spec but I need figure out what's good for running this size tire
  16. Apr 7, 2017 at 8:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    i just got Igor a new alignment...only .31 degrees of castor...ouch..
    UCAs need to happen..
  17. Apr 7, 2017 at 9:24 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Not a fan of wide tires. It effects how the truck turns in. Turn in is very important to me. Its why I have such a huge beef with how Frank drives. Absolutely no turn in whatsoever. Monte knows this to be true. I can't quote him but he knows that too. Instead of using the steering wheel to get Frank to turn, he has to use the throttle. Not always a good option.
    I have tried the wider tires on the redhead. Had a set of 33x12.5s on her for a few hours. Absolutely hated it.
    For me, it a ratio of height vs. width. a 295 would be ok if its no wider than 11.2" but I can't seem to find that tire.
    I just don't get it. I don't see what folks see in dem phat things.
    @Blackdawg :brianr:
  18. Apr 7, 2017 at 9:27 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    shouldve did the light racing group buy
    or got the camburgs the other week... ;)
  19. Apr 7, 2017 at 9:28 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Dude you need some UCAs bad.
    Personally, I hated how my truck drove with less than 2* of caster.
  20. Apr 7, 2017 at 9:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Dude a 285/75r17 is 11.2x33x8...come on. That's like..made for you.
    And franks turn in is not THAT bad. Come on..its not your truck..nor Igors turn in...but its not like its gonna fly off the cliff...id have done that by now.
    The point is the smooth ride. The ride over all those annoying ass small bumps is WAY WAY Fucking better then with the skinny tires.
    I wish i had gotten though Camburgs last week..would have been perfect. Just saw the post 10mins late..
    Couldn't swing the LR GB at the moment it happen..i was unemployed.
    Yea, my normal guys in Powell i think got it to 1.3º..was fine like that.
    Now..it doesn't snap in straight like it did. Super annoying.
    The LR ones are likely what i'll get..4º caster from those :p
