Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Apr 25, 2017 at 8:20 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Mesozoic
  2. Apr 25, 2017 at 8:31 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
  3. Apr 25, 2017 at 8:54 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Got my Kings back from Tim. :woot: Can't wait to get them back on. I was surprised at how anxious I felt while they were gone. :oops:
    I have a question about 1st gen IFS wheel travel. Without the shock in there, it looks to be about ~9" from full droop (no wheel mounted) to full stuff, all the way to the slightest compression of the bumpstops. Is this typical? How does this compare to a 2nd gen?
    It does not seem like my mid-travel Kings can take full advantage of all 9"s.
    Full disclosure, this is with Camburg UCA/1" uniball and OEM LCAs and ball joints. Also no anti-swaybar.
    Bennett707 likes this.
  4. Apr 25, 2017 at 8:56 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I'd like to know as well, I know my icons take advantage of every last bit of down travel but the up travel is unknown to me.
  5. Apr 25, 2017 at 9:10 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    How is it on the highway with no sway bar? Curious about it for off roading but have read it can be sketchy at highway speeds
  6. Apr 25, 2017 at 9:18 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I like it. But I do have 700# coils. Honestly, have never missed it.
    Its worth trying out on the highway to see if you can get used to it. Off road there is nothing to dislike about not having one.
    Instead of totally removing it, you can disconnect each end and rotate the bar so the ends point up. Zip tie them in that position and go do some slolom racing at 70 mph. :D
  7. Apr 25, 2017 at 9:21 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    I'll give it a shot now that it's becoming less of a DD
    Digiratus[QUOTED] likes this.
  8. Apr 25, 2017 at 9:27 PM
    Digiratus
    Roaming the PNW
    The RedHead
    To paraphrase something I once saw Ben write...
    An anti-swaybar is a lot like a condom, it feels safer with one on, but feels so good without one.
  9. Apr 25, 2017 at 9:28 PM
    Speedytech7
    Even with my last setup (Eibach poop coils and Blown billies) having no sway bar was a night and day difference, not as rough over bumps and the body roll was 100% manageable. Even evasive maneuvers were okay, just try them beforehand to make sure it works for you.
  10. Apr 25, 2017 at 9:31 PM
    Speedytech7
    Let's not forget that condoms have other purposes than modification of feel, the bar actually prevents body roll just like a condom prevents you from ending up with an 18 year burden. But I suppose the comparison is accurate in that neither are 100% effective
  11. Apr 25, 2017 at 9:31 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    :rofl:
  12. Apr 25, 2017 at 10:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yeah...long as it isn't 20 bucks haha Hopefully hear back tomorrow.
    Was fast they pulled it today.
    Well, did you lever the arm down? i know the LCA bushings hold up the assembly a bit by themselves. So could be more.
    But 9'' sounds right. Though i think you're right that the shock won't allow it full travel still. Think you'd be lucky to see 9'' of wheel travel.
    Why Long travel is a thing. 14'' of travel. Amazing what a difference it can make to have just a few more inches of travel too. So much smoother.
    2nd gens are similar travel.
    also...tim? who rebuilt them??
    Igor hasn't had a sway bar since the kings went on. Very much worth taking it off.
  13. Apr 25, 2017 at 10:32 PM
    Speedytech7
    No worries, I'm not going anywhere so if shipping is nutso I can grab it and hold onto it until Oregon :boink: :rolleyes:
    Also I think he means Tim F. @TMFF
    Blackdawg[QUOTED][OP] likes this.
  14. Apr 25, 2017 at 10:37 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    haha that is fair. Or i'll have you ship it. Will want to test it out ASAP.
    Then the SnapShot goes away in June finally and i can drive Frank the way he was meant to be..
    ooohhhh gotcha! Nice. That dude knows his stuff!
    Speedytech7[QUOTED] likes this.
  15. Apr 26, 2017 at 9:17 AM
    Digiratus
    Roaming the PNW
    The RedHead
    I did. It was at the bottom of the travel, I could not lever the arms down any further.
    It was interesting that the 2 sides are not identical. Surprise, surprise! The passenger side movement is about 1/2" higher than the driver side. There is also a slight difference in the amount of travel from side to side. The driver side is ~1/8" more.
    Are there any established numbers for extended travel King's OEM COs? I guess I'm asking how much of the 9"s are we able to use?
    Yeah, Tim from 303 Shock Services out of Henderson CO.
  16. Apr 26, 2017 at 9:37 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Rubber bushings in the LCA? What's the limiting factor in your downtravel?
    I have right around 9", any more and the CV binds.
  17. Apr 26, 2017 at 10:10 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    should be able to tell from your extended/collapsed length measurement of the Kings.
    Id guess the kings aren't using the full travel though.
  18. Apr 26, 2017 at 10:18 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    @Speedytech7
    Zane, thank you so much for your willingness to go to the junk yard and check up on things! They are going to ship it to me for 185 bucks so not a bad deal all in all. I'll sell the 4runner ECU i bought and basically make my money back.
    Appreciate your help! Here's hoping this damn thing works..
    SconnieHailer and Speedytech7 like this.
  19. Apr 26, 2017 at 10:28 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yes i had to pry down the LCA mount a lot to fit my Kings. So much so i couldn't even get the Sway bar back on.
    I don't see the point of doing it the way you are saying. Have the tire on the assemble isn't "real world application" because in the real world the coilover is forcing the LCA down..so the tire is irrelevant.
    What would be a good measure is doing what mike did, measure the travel available without the shock. Then put the shock in. THAT is the max droop the coilover can do is when it is just sitting there installed with no weight on it. Measure that droop number and subtract from the number he got with no coilover.
    That'll tell him his travel.
  20. Apr 26, 2017 at 10:32 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Yes. The LCAs are all original with 166K on them.
    The limiting factor right now may be the CV. :notsure:
    At full droop I could still rotate the axle but it had noticeably more rotational resistance (much harder to turn the hub by hand). I think of 'binding' as not being able to rotate it at all. If that is the definition, then it wasn't binding yet when sitting at the bottom of the travel.
