Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. May 10, 2017 at 10:03 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    thoughts. cutting the eye off the shock so i can remove the shock and then have more fun ways to get the bolt out
  2. May 10, 2017 at 10:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    what? Im guessing this is the rears? i was thinking fronts..
  3. May 10, 2017 at 10:08 PM
    Bennett707
    Oregon
    front
    lower strut bolt.
    i want to cut it and make it go away. no pressure at all on the shock any more.. could probably even fit my sawzall in there after and cut both sides of the bolt inside the tabs too afterwards.
  4. May 10, 2017 at 10:09 PM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    I am not saying he isn't. Not even sure who he is. Assuming you did 5 hours of work a day for the photos. That's $13 an hour to equal $200 over the 3 days. I am guessing the prices are low in an attempt to get more customers. Factor in gas, food, etc. Ouch. I guess its still $200 off his trip to the mountains and it would work if you had another job and just loved to go wheeling.
  5. May 10, 2017 at 10:10 PM
    Bennett707
    Oregon
    thats a lot of bolt to drill through.
  6. May 10, 2017 at 10:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    oh, well then no i would not do that.
    Let the PB soak, get a real breaker bar on it and add an extension tube to it. Leverage is king man.
    rickassay. The guy that every toyota he touches is epicily awesome. The 4runner, then the land cruiser, then the tundra, and now a new 4runner.
    Yeah idk what the game plan is for long term..
    LOL good luck. freakin huge bolt.
  7. May 10, 2017 at 10:14 PM
    Bennett707
    Oregon
    im still thinking about just cutting the shock.
  8. May 10, 2017 at 10:17 PM
    Bennett707
    Oregon
    even that low?
    might have to take another peak at it. looked like i had space.
    x2. bolt is big. obviously ben hasn't done any mods himself down there ;)
    i'll see if i can get a bigger breaker bar
  9. May 10, 2017 at 10:27 PM
    Bennett707
    Oregon
    I'll tackle it again after work tomorrow. Might be adding some tools to the arsenal on my way home
  10. May 11, 2017 at 7:10 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Sorry if it was already covered but did you unbolt it from the top bucket?
    Also, cattle branding day in Dubois was awesome. Fulfilling my cowboy fantasy one step at a time. One of the girls got some pictures so I'm stoked to get those sent to me.
    #WYOMIN'
    Pltmnky and Bennett707 like this.
  11. May 11, 2017 at 7:11 AM
    Bennett707
    Oregon
    yes tried with it unbolted and bolted from the top bracket. testing tension on the bolt
  12. May 11, 2017 at 7:31 AM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    How big of a ranch? How many steers?
  13. May 11, 2017 at 9:14 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    This explains a lot...
    gordi likes this.
  14. May 11, 2017 at 10:15 AM
    Bennett707
    Oregon
    Digiratus[QUOTED] likes this.
  15. May 11, 2017 at 10:30 AM
    Digiratus
    Roaming the PNW
    The RedHead
    I need one of these...
  16. May 11, 2017 at 10:34 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    no you don't.
    what happened to the LC?
  17. May 11, 2017 at 10:36 AM
    Digiratus
    Roaming the PNW
    The RedHead
    I don't? :cookiemonster:
    Ended up being more than I wanted to pay or could afford. They ended up using it for its trade-in value.
  18. May 11, 2017 at 10:38 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    darn. Oh well.
    And hell know. You think you'd be able to keep up with that giant heavy POS behind your fat ass truck? Already have problems with that :p
  19. May 11, 2017 at 10:40 AM
    Digiratus
    Roaming the PNW
    The RedHead
    ...but its got a nice hot water shower. o_O
    I do like the awning tho.
  20. May 11, 2017 at 10:42 AM
    BabyTaco
    Wyoming
    2011 RC Tacoma
    That's good enough to get things packed up on it. I'll install d rings on it to strap everything down nice and tight. I have some left over wood that I may use to make a second platform over some of my military boxes. I also have a long skinny box to fill in the gap under the platform.
    Blackdawg[OP] and m3bassman like this.
