Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jun 4, 2017 at 6:51 PM
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    521 up in the Big Horns aka "Gold mine trail". Name says it all, theres an old gold mine and some cool stuff to look at towards the top. There's even a ran down box wagon on the side of the trail.
  2. Jun 4, 2017 at 6:52 PM
    justinf307
    justinf307 Well-Known Member
    Justin
    Glenrock WY
    2007 Tacoma DCSB
    3 years ago we both had a mutual opinion that we didn't want them either. Baby fever is real, and you never know when it'll hit.
  3. Jun 4, 2017 at 6:57 PM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    Lol the truck doesn't talk back :laugh:. But yes. Just like the truck.
    I wish more smart parents would pop some kids out. It seems that the smarter people tend to be more career driven and "selfish". Two of my professors (they were married) adopted at an older age and I think that's the best route. They were able to travel and work in awesome areas and now they make enough money that a kid didn't stress them out. And they are still traveling and doing cool stuff. Glad you and Jen got your lil turd though. Should be a fun 18 years for you guys.
  4. Jun 4, 2017 at 7:46 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    No doubt, life is far from boring with a brat in the house :p
    BabyTaco[QUOTED] likes this.
  5. Jun 5, 2017 at 5:53 AM
    aiello307
    aiello307 Well-Known Member
    Anthony
    Sheridan
    2012 Tacoma Double Cab Baja
    Stock
    Morning Guys. Got a question for yall. I was turning left into a a very tight parking spot the other day, and hear a terrible rubbing/grinding noise coming from the front end of the truck (sounded like it was from under the drivers side wheel well). At first I assumed it was my tires rubbing, but I cant reproduce the noise when I turn sharp to the right. I checked around the forums and some people has mentioned something about the brake dust shields, so I checked on both sides, and those looked ok as well. I was curious if anyone has any other ideas I should look into. Thanks guys. Have a good Monday.
  6. Jun 5, 2017 at 7:19 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Thats ok. I'll pick up your slack and spread some ginger babies accross this earth one day
  7. Jun 5, 2017 at 7:23 AM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    What tire size and lift? Also u can have that happen when ur turning and under compression vs on a flat surface. I had wheel run but only turning one direction and backing up and had to be on a slight slope.
  8. Jun 5, 2017 at 10:24 AM
    aiello307
    Anthony
    Sheridan
    Stock
    Hey. Thanks for the response. Stock lift on the baja. I'm running 265/75/16 wrangler Duratracs.
  9. Jun 5, 2017 at 11:29 AM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    Go pull into the spot again and stop when it runs and check
  10. Jun 5, 2017 at 1:22 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    Anyone make any trips outs this way often?
  11. Jun 5, 2017 at 1:44 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Not seeing your pic. :notsure:
  12. Jun 5, 2017 at 1:46 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    hmm...popped up for me...
    Basically SE Nebraska, straight east of Cheyenne.
  13. Jun 5, 2017 at 1:51 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I see this one. :p
    Nope, never been in that area.
  14. Jun 5, 2017 at 4:25 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Some 2,000+/- year old engineering for you engineers.
  15. Jun 5, 2017 at 6:41 PM
    BabyTaco
    Wyoming
    2011 RC Tacoma
    @Digiratus
    Finally bought and used an aeropress for myself tonight. My kitchen is so small I didn't want a drip machine and I am glad I didn't go with one. This will travel to work and back since they make some crappy coffee there.
    Just need to sew up a travel pouch for it and off the the field it goes.
  16. Jun 5, 2017 at 7:55 PM
    SconnieHailer
    Marc
    Dude I use mine every day since Jen got pregnant and gave up coffee. It's seasoned big time. I pour in the first full to the top and wait for it to drain half way out then fill it full again and stir then wait for it to drain halfway ish again fill up one more time and press it. That way I get a full big mug in one go. The grind has alot to do with how this method works tho. Enjoy!
  17. Jun 5, 2017 at 8:39 PM
    BabyTaco
    Wyoming
    2011 RC Tacoma
    I started out using the inverted method because I like a stronger cup of coffee. I should try it as it was intended but my roommate said it was a bit weak when they did it. Love how easy it is to clean.
  18. Jun 5, 2017 at 9:06 PM
    Justrom
    Justrom Well-Known Member
    County 10 - Wyoming
    '13 Dbl Cab Long Bed
    We got ours after breaking a glass French Press on the Alaska trip. Soooo much easier to clean up than the old French Press. I use the inverted method, fill it halfway up, wait 30 sec, stir, fill the rest of the way, let sit for 1:30, then press out slowly over 30 seconds. Coffee is 3T of Cafe Britt Dark Roast. It fills a large travel cup about halfway, then we fill the cup the rest of the way with hot water.
    SconnieHailer and m3bassman like this.
  19. Jun 5, 2017 at 9:08 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I luv my aeropress.
    How many scoops of coffee and how finely ground when you do this. I've always worried that putting too much water can bring out the bitterness.
    What is the inverted mmethod?
  20. Jun 5, 2017 at 9:21 PM
    BabyTaco
    Wyoming
    2011 RC Tacoma
    You put the plunger in first and flip it upside down. Then put in the coffee, then water, and then screw on the filter. This allows you to have control of the coffee brew time. When your ready, you flip it over the cup and push in the plunger.
    I found this real quick. Seems like a decent walk through with pictures for the inverted method.
    https://www.moustachecoffeeclub.com/aeropress-inverted-method-how-to-brew
    Justrom and m3bassman like this.
