Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jul 18, 2017 at 8:52 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yuengling is good, iconic east coast beer. It's basically just the one beer though
  2. Jul 18, 2017 at 8:53 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Really no idea. It's incredible because it's SOOOO damn good and so damn cheap! I could get a pint of yuengling at a lot of places when I was out east for like 2 to 3 bucks a pint, and it's better than any other beer in that price range by miles
  3. Jul 18, 2017 at 8:55 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    The amount of yuengling We drank in the keys...was just dumb. Every Wednesday night at dunns OV we Ran the bar out of pitchers and we had to finish the ones we had so they could fill em up.
    God I miss the keys
  4. Jul 18, 2017 at 8:55 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    This says otherwise.
    https://www.yuengling.com/our-beer/#tab_all-beer
    And you like lagers right. Like that modelo the other day.
  5. Jul 18, 2017 at 8:55 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    No it can't haha thats a format that is over 8 times the rate of a CD. ULTA high resolution. Its 4 time the rate of what most consider high res.
    yours probably does 320kpbs MP3s. Which is the highest DATA rate MP3 can do. A CD plays at 1156kbps.
    Sample rate is what i was talking about which is how many samples per second my recorder captures. So a CD is 44,100 samples per second. For each sample you get a bit assinged to it for amplitude with a max value of 16. Which is 96dB of headroom. VS 24 bit which is 144dB of head room. 32 bit is 192dB of headroom.
  6. Jul 18, 2017 at 8:58 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Did you hear that noise...My head just exploded.
    A Mo Cat likes this.
  7. Jul 18, 2017 at 8:59 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
  8. Jul 18, 2017 at 9:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It resonated at 1.2k haha
  9. Jul 18, 2017 at 9:11 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    I need about 6' of headroom
    Close enough?
    Blackdawg[QUOTED][OP] likes this.
  10. Jul 18, 2017 at 9:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Thought you only needed 3''..
  11. Jul 18, 2017 at 9:23 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :rofl:
  12. Jul 18, 2017 at 9:31 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    yes. all of the above. I love classic George straight and some Kane Brown and jon pardi all the same
    m3bassman[QUOTED] likes this.
  13. Jul 18, 2017 at 10:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Trip thread started bitches.
    Digiratus likes this.
  14. Jul 18, 2017 at 10:49 PM
    Speedytech7
    I'm sure you can buy others in the store but any place that says they have yuengling is only gonna have the classic. Always get it when visiting family, it's good shit.
  15. Jul 18, 2017 at 10:52 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I'd be willing to try it.
  16. Jul 18, 2017 at 11:40 PM
    nosbusa
    nosbusa Well-Known Member
    noah
    colorado springs
    i dont own a toyota
    more than any one person should have done
    and then you need sound equipment that can reproduce the clarity of the bitrate. thats where i come in. being a sq sound judge i have to pay close attention to the frequencies. i would like to hear some of your music inside my truck. i have done a bit of audio mods to my truck. be interesting to see.... er hear.
  17. Jul 18, 2017 at 11:42 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Id be amazed if there is even a vehicle setup that plays back DXD format.
    Im doing classical music though. Not sure you'd like that or not haha
    recording in 9.1 3D surround sound
  18. Jul 18, 2017 at 11:54 PM
    nosbusa
    noah
    colorado springs
    i dont own a toyota
    when tuning or judging sound systems we use classical, jazz, rock, etc. nora jones, dire straits, rebecca pigeon. the eagles hotel california from their hell freezes over cd is also one of the cleanest recordings to listen to. theres a lot of test music i have which is all classical and jazz
  19. Jul 19, 2017 at 12:01 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    BOOM
    1900 bucks blown. Front ARB diff here we come!
    Speedytech7 and m3bassman like this.
  20. Jul 19, 2017 at 12:04 AM
    Alpine_Taco
    Alpine_Taco Member
    Austin
    VIRGINIA BEACH, VA
    '06 Tacoma double cab w/6 ft bed
    K&N COLD AIR INTAKE UNDERDOG RACING DEVELOPMENT LT CERAMIC COATED HEADERS DOUG THORELY PIPE BOMB PERFORMANCE Y-PIPE MAGNAFLOW MUFFLER W/ CUSTOM CUT AXLE DUMP 2.5"PIPE UNDERDOG RACING DEVELOPMENT CUSTOM TUNE KING OFF-ROAD RACING 0-3.5" SUSPENSION (SET AT 3") W/ TOTAL CHAOS UCA AND TOYTEC ADD-A-LEAF PACK HELLWIG ADJUSTABLE REAR SWAYBAR KIT SPYDER SMOKED DUAL HALO HEADLIGHTS VIPMOTOZ SMOKED NEON TUBE TAIL LIGHTS YELLOW FOG LIGHTS 285/75R16 TOYO AT2 TIRES WITH BLACK PROCOMP WHEELS BUSHWACKER BODY KIT 2017 PORSCHE WHITE PAINT JOB W/ PORSCHE BASALT BLACK PEARL ROOF AND TRIM CUSTOM BATTLE TATTERED AMERICAN FLAG TAILGATE AND EURO STRIPE IN SATIN BLACK MOAB SIDE STEPS HONEYCOMB MESH GRILLE CUSTOM FABRICATED TUBULAR BED RACK
    I'm from Douglas but am Military and live out of state now :( Would love to link up when ever I'm around tho
    Blackdawg[OP] likes this.
