Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jul 28, 2017 at 12:01 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    /And so it begins...again. :)
  2. Jul 28, 2017 at 12:03 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    And again and again haha
  3. Jul 28, 2017 at 12:51 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    probably.
    If life worked out id forgo that though. Id start looking for a 5.3l ls and then cage and 4 link the rear.
    Put the blower on Igor. T100 axle out back with the TC shock kit and hydros then either move the MCM kit to Igor and get a Solo kit for Frank or the FROR kit if it ever comes out.
  4. Jul 28, 2017 at 1:19 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Poor little igor. You promised you would never modify him. :rofl:
    m3bassman likes this.
  5. Jul 28, 2017 at 1:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah...but. I like the double cab on the long trips haha
  6. Jul 28, 2017 at 1:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Life is too short to leave the tacoma stock..
    :p
  7. Jul 28, 2017 at 1:36 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Im thinking about buying 2 of the Cree 7" 140 w led spot lights for the front...each one says it's like 11k lumens haha! Seems worth it to me! Has a flood and a spot lens...
  8. Jul 28, 2017 at 1:37 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Bwahahaha
    Close to stock
  9. Jul 28, 2017 at 1:38 PM
    Playwfire
    Playwfire Active Member
    Andrew
    Buffalo, Wyoming
    2003 Double Cab TRD
    OME lift
    Anyone know of any forums specific to Lexus off-road? I'm trying to sell the 09 GX 470.
  10. Jul 28, 2017 at 1:43 PM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    How much are you selling it for? I would look for overland groups on Facebook. Lots of people with too much money looking for a vehicle like that.
  11. Jul 28, 2017 at 1:47 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Why is it that all of the GX470s are silver. Did they not make them in red? :confused:
  12. Jul 28, 2017 at 2:09 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Link to bars?
    No regrets. I've have a built truck that I abuse very hard. When it breaks as it does. I ha e a nice capable rig to keep me going to the mountains.
    When you have a rig like frank. It's expensive to fix. You're worried about your Lil elocker actuator. I just dropped 2k on a diff. I'll need another 4k for the rear suspension I want.
    It's nice to still wheel while waiting for funds. Otherwise. I would not have been able to go on the three trips I did this winter and spring. And before you point out that b I dropped as much money on Igor that I could have fixed frank...I couldn't have. I didn't have the space or time to work on him this winter.
    Speedytech7 likes this.
  13. Jul 28, 2017 at 2:11 PM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    Lol @m3bassman
  14. Jul 28, 2017 at 2:12 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :ohsnap:
    BossFoss likes this.
  15. Jul 28, 2017 at 2:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  16. Jul 28, 2017 at 2:33 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Your an easy target. And it's silly you won't fix it. But will buy a new 2k tent....talk about weird priorities.
    I'd rather have a truck that works right and sleep on the ground.
  17. Jul 28, 2017 at 2:44 PM
    BabyTaco
    Wyoming
    2011 RC Tacoma
    I love when we argue about financial decisions here. Like any of us are in the position to give advice :laugh:.
  18. Jul 28, 2017 at 2:45 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Or buy a sailboat like me and don't buy a new locker OR tent!
  19. Jul 28, 2017 at 2:48 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No doubt..haha
  20. Jul 28, 2017 at 3:33 PM
    nosbusa
    nosbusa Well-Known Member
    noah
    colorado springs
    i dont own a toyota
    more than any one person should have done
    lumens and lux are 2 different things. i would be more interested in lux at 75 yards. also cree makes several chips. i would check to see which bin they came from. xml and xml2 are the ones you want. but they are found in more expensive bars
