Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Aug 22, 2017 at 7:31 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    No way to just add camber. you'd be changing the whole alignment. Need the right tools for it.
  2. Aug 22, 2017 at 7:56 AM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    Been browsing commuter cars with the idea of hanging onto BabyT another year to feel the future out. My supervisor reassured me I have the job as long as I don't kill someone or steal government property. Which gives me comfort in having 2 cars and not worrying about moving.
    Anyone ever purchase a rebuilt titled car? There are tons of them here. Seems like a simple fender bender is enough for insurance to write it off? Anyways, low mileage, new models and cheap. Most even have pictures of the accident. Everyone says once a car is in an accident it's ruined, but BabyT feels good as new and she was hit harder than some of these cars.
    I'm talking like corollas, civics, and vw Jetta or Passat. Nothing sporty, just a simple car to save gas getting to work or going to Boise/spokane, etc.
  3. Aug 22, 2017 at 8:18 AM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    The fact I am not dead is a testament to the human body after what I have put this thing through..
    A Mo Cat, gordi and BossFoss[QUOTED] like this.
  4. Aug 22, 2017 at 8:47 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    That first pic is one of the best ones I've seen posted by any of my friends. Got the light waves really welll!
    Justrom likes this.
  5. Aug 22, 2017 at 8:37 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Ben, replacing the axle seal and axle bearing is not a trail fix.
  6. Aug 22, 2017 at 8:45 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Are you saying new bearings aren't better than your old bearings? :cookiemonster:
    BossFoss and gordi like this.
  7. Aug 22, 2017 at 8:56 PM
    Squeaky Penguin
    Brett
    You should change them sometime between when they need to be replaced and when Monte changed his. :D
    Mine made it 262k miles.
    Only introducing the possibility of other failures if you or the shop you have do it don't know what they're doing. Zero issues on mine after doing it myself. Not really a valid argument to not change them.
  8. Aug 22, 2017 at 9:06 PM
    Squeaky Penguin
    Brett
    Not all about miles. I think it is affected by tire size/weight, wheel offset, how you use your truck, miles, etc.
    No idea if yours need to be replaced or not, but I wouldn't want to find out in the middle of nowhere. That being said, my seals only weeped slightly and I drove it like that for a couple weeks before I swapped the bearings.
  9. Aug 22, 2017 at 9:10 PM
    Digiratus
    Roaming the PNW
    The RedHead
    If the axle is bent as you inferred at the start of this discussion, replace the axle and by default the wheel bearing and seat. Its no longer about mileage if the axle is bent.
  10. Aug 22, 2017 at 9:11 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Man, wish I could find a 3rd gen for $7,500. That's awesome.
  11. Aug 22, 2017 at 9:18 PM
    Digiratus
    Roaming the PNW
    The RedHead
    If the axle shaft is not bent and your seal isn't leaking, why are we even having this discussion? :confused:
    Speedytech7 and gordi like this.
  12. Aug 22, 2017 at 9:24 PM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    what was the guy welding on it for
  13. Aug 22, 2017 at 9:34 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Wut??
  14. Aug 22, 2017 at 9:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    also my bearings made it...190k?? i think..ish..
    Also lasted 6 months damn near before totall implodeage....but man did it implode
  15. Aug 22, 2017 at 9:39 PM
    Digiratus
    Roaming the PNW
    The RedHead
    You always lose me. I think it's when you start talking.
  16. Aug 22, 2017 at 9:41 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ha. Wow.
    :rofl:
  17. Aug 22, 2017 at 9:54 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    you get your time off approved?
  18. Aug 22, 2017 at 10:00 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    zing
  19. Aug 22, 2017 at 10:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I have a lot to do..wish i could do more really.
  20. Aug 23, 2017 at 8:18 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah I had a week off but now few of those days I'll have to edit a piano solo album I just recorded for Steinway's label I just recorded yesterday. And have a jazz one to finish. And other 5.1 mixes to do as well.
    Plus fix frank rear suspension and Jerry can mount. Swap bed racks from igor and tent. Those are my major things. Timing belt water pump for igor.
