Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Nov 7, 2017 at 7:57 PM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    The one tire I forgot to consider.
    Durafails and going 37s.
  2. Nov 7, 2017 at 8:03 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Well they are a great snow tire. One of the best.
    But I'm calling BS on both claims :luvya:
  3. Nov 7, 2017 at 9:04 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Nothing wrong with BaoFengs, cheep Chinese or not. And 3800 mAh battery, that is a lot of battery. I'll bet they have some heft to them.
  4. Nov 7, 2017 at 10:55 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    The site said about 2 days worth of use time out of the per charge...The yurt trip we go on in the winter has no electricity and we will be out for 4 days lol. Even then we will need a solar charger. Ya the weight is kind of a bummer but having communications will be a good relief on big tours
  5. Nov 8, 2017 at 9:06 AM
    BabyTaco
    Wyoming
    2011 RC Tacoma
    Nope, I went with duratracs but I did lie about the 37's. One of the best "snow" tires around and not a lot of complaints in the traction department. 35's are always 10 ply with the stronger sidewall. Plus they came out pretty darn cheap. I have had several friends, including @FreidTaco, who run them and love them. Can't beat real world results with people who live(d) in similar snow conditions. I've been mislead many times on this forum by people that think they have a harsh winter.
    I found reviews on Cooper and BFG AT's were all over with how well they performed in winter. Some liked them, others said they were the worse and then some said mediocre. The lifespan of the coopers are longer but I have seen some people really stretching out the life of the duratracs with regular rotations.
    Hopefully they work out and I don't regret my decision later :laugh:.
  6. Nov 8, 2017 at 9:11 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    nah i don't think you will. They aren't a bad tire at all. Should work good.
  7. Nov 8, 2017 at 10:34 AM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    My old 33s i ran for 35k and sold to buddy who ran another 15k on them...
    Current 35s I only have like 10k on them. I also run them on my work pickup (2500 duramax) running 95% highway i have gotten 55-60k out of past two sets
    BabyTaco[QUOTED] likes this.
  8. Nov 8, 2017 at 11:57 AM
    Justrom
    Justrom Well-Known Member
    County 10 - Wyoming
    '13 Dbl Cab Long Bed
    @FreidTaco What are you running for pressure in the Duratacs on the Taco and how often are you rotating your tires? I've got Load Range E Duratracs on my '13 Tacoma and haven't found a sweet spot for inflation yet.
  9. Nov 8, 2017 at 12:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Do the chalk test if you want the best wear.
    Justrom[QUOTED] likes this.
  10. Nov 8, 2017 at 1:55 PM
    FreidTaco
    FreidTaco boost
    jeff
    I run 38-40psi but I run lots of gravel roads with these so less likely to notice funny wear. Usually rotate every 2nd or 3rd oil change (6k or 9k miles) Depends on my time availability. Now that i have a 2 post lift it will be faster and easier for both jobs.
  11. Nov 8, 2017 at 2:00 PM
    Justrom
    County 10 - Wyoming
    Thanks - I think I'm in the low 30s, guess I need to make the time to do a chalk test and see if it would help to add a few psi.
    BabyTaco likes this.
  12. Nov 8, 2017 at 8:00 PM
    Ponchuco
    Ponchuco New Member
    2011 trd dcsb
    Excellent. I’ll keep an eye out for your rig when I’m in the area.
  13. Nov 8, 2017 at 8:54 PM
    Digiratus
    Roaming the PNW
    The RedHead
    According to the weather app on my phone, we are locked in for heavy rain for at least the next 8 days in a row. Might be longer but that is as far out as the app shows. And it doesn't say showers, it says rain which generally translates to a lot of it at high intensities. Tis the time of year. :(
    I am guessing that'll mean serious snow for those east of us for the same time period. Don't say you weren't warned.
  14. Nov 8, 2017 at 8:57 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Can I dislike this? I want summer back. Or spring at least. Maybe just some daylight. :pout:
    Digiratus[QUOTED] likes this.
  15. Nov 8, 2017 at 8:58 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Hmm. Well it usually takes 2-3 days for your shit to get to me from what I've noticed.
    Damn. More snow already. I have a recording session next week. 3 hours of driving a day is bad weather early in the morning and Kate at night won't be fun.
  16. Nov 8, 2017 at 8:59 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sunny here :)
    Also frozen haha
  17. Nov 8, 2017 at 9:00 PM
    Digiratus
    Roaming the PNW
    The RedHead
    It's no wonder people jump off bridges so often here. With the the time change we are entering the tunnel....
    And wont come out the other end until sometime in March.
  18. Nov 8, 2017 at 9:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Huh only supposed to snow on Saturday and next Thursday. Cool.
    Sucks to be you guys haha
    Though I miss sunny powell...every time we visit it's warmer and sunnier.
    Justrom likes this.
  19. Nov 9, 2017 at 4:47 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Damn..left my led pods on..killed the battery.
    gordi likes this.
  20. Nov 9, 2017 at 8:31 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Were you at work?
