Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Dec 5, 2017 at 6:18 PM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    Sadly tacomaworld will do that to you
    justinf307[QUOTED] likes this.
  2. Dec 5, 2017 at 6:24 PM
    justinf307
    justinf307 Well-Known Member
    Justin
    Glenrock WY
    2007 Tacoma DCSB
    Haha right! Sure does drive better than my pickup, and the V8 would be nice. I'm sure I would miss having a pickup too much though Tried to convince my wife to trade off her 15 Grand Cherokee for it but she wasn't having it.
  3. Dec 5, 2017 at 7:13 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    What I see is the mods for them cost way more too, plus idk what size family you have but you don’t usually need a 9 person rig
  4. Dec 5, 2017 at 7:32 PM
    justinf307
    Justin
    Glenrock WY
    2007 Tacoma DCSB
    Just three of us right now, and a couple dogs so the third row would be out 99% of the time. Ideally if I were to do it I would like to find a decent first gen for the times a pickup was necessary.
    Suspension wise if I'm reading correctly my coilovers should be a direct swap, and a rear coil conversion is pretty cheap. Other than that I agree mods do seem higher priced. Sliders and skids would be things I could do myself, but bumpers and what not are pricey!
    Doubt I'd go through with it, just kinda like the way they look. It would for sure make a more enjoyable ride to get to places to wheel, especially as many times as we venture down to CO every year. Frankly I'm just not getting to do as much hardcore wheeling since selling the Jeep.
  5. Dec 5, 2017 at 10:10 PM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    In western Nebraska. Can deliver to laramie. Make me an offer.
  6. Dec 6, 2017 at 10:13 AM
    justinf307
    Justin
    Glenrock WY
    2007 Tacoma DCSB
    On another note, does anyone have any suggestions for areas around Moab that might be less crowded during Easter jeep safari? We've been wanting to go back and Tess finally had a decent spring break, but it unfortunately coincides with EJS.
  7. Dec 6, 2017 at 10:24 AM
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    Any place they are not. They will have the schedule of runs in the Safari magazine they put out and the net. Went last year and avoided them easy. Just looked and they don't have schedule posted yet.
    justinf307 likes this.
  8. Dec 6, 2017 at 11:15 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    The Maze is about as isolated as it gets.
    Southern area too has tons of stuff
  9. Dec 6, 2017 at 12:04 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Ok i'm out of patience with my steering rack. I am literally tossed around the road by grooves or un even lines, and the alignment is never right and its straight killing my tires. Its just sloppy as fuck and I dont think just having 35s is the culprit. Its obviously worn and leaking and after being subject to my abuse for the last 5 years is past the end of its life. So, everyone says get oem, and get the 01-04 year replacement ones right?
  10. Dec 6, 2017 at 12:30 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    For how much you abuse it, yes, OEM. Write to this guy for a pretty good price.
    https://www.tacomaworld.com/threads/gunny-is-back.476544/page-40#post-16603229
  11. Dec 6, 2017 at 3:29 PM
    Digiratus
    Roaming the PNW
    The RedHead
    @Blackdawg
    Monte did you get your splash guards from cnote4? Any feedback on them? Happy? Did you get clips too? Are they OEM? How do the gaurds feel? As thick and flexible as OEM? Were they for Frank or Igor?
    gordi likes this.
  12. Dec 6, 2017 at 3:37 PM
    justinf307
    Justin
    Glenrock WY
    2007 Tacoma DCSB
    Thanks for the suggestions. Great Idea to check their schedule and plan accordingly.
  13. Dec 6, 2017 at 6:58 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I did get them very fast. I paid extra to have shipped early. And HD clips. Haven't installed yet. Going on igor. Very high quality and flexible. 1/8" thick. Very nice. Clips seem okay. One time use ones though.
  14. Dec 6, 2017 at 8:20 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I think I'm gonna go ahead and order a set then. My passenger side one is totally missing and some of the driver side holes are torn or missing clips.
    Thanks for the feedback.
  15. Dec 6, 2017 at 9:15 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah I think they are well worth it. Will get a set for frank too eventually. Igor just gets way more winter driving. And his are brittle and torn.
    Saw a dude use screws and washers. Might do that on the driver side so then I can get to the oil filter easier.
    Digiratus[QUOTED] likes this.
  16. Dec 6, 2017 at 9:15 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    White rim trail is neat too. We were there during jeep week and that was open. Passed a few people but it was nothing like the other trails for traffic. Need to reserve campsites ahead of time, might be why it's less traffic too
  17. Dec 7, 2017 at 6:29 AM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    Mine were cracking and so I ordered the same material off Amazon and cut new ones and used the current plugs. Cost me like 1/4 of what they were asking I think. Had to borrow a driver side one from my brother since mine had fallen apart
  18. Dec 7, 2017 at 9:46 AM
    BossFoss
    Wyoming
    01 DC Tacoma
  19. Dec 7, 2017 at 4:13 PM
    justinf307
    Justin
    Glenrock WY
    2007 Tacoma DCSB
  20. Dec 7, 2017 at 4:43 PM
    Glenn_R
    Glenn
    April 7th opened today for backcountry overnight permits and is already 75% full. If you want to camp in Island in the Sky the 8th will open tonight at midnight. Check here for information on White Rim Road and here for reservations..
