Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Dec 26, 2017 at 3:58 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Didn’t need 4wd luckily! Back in Jackson!
  2. Dec 26, 2017 at 4:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Im still confused as to how you are driving if the tulip itself is blown up
  3. Dec 26, 2017 at 4:21 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    the driver side doesn't disconnect. The passenger side does form the diff.
    Even then, doesn't really matter as the CV axles always spin with the wheel. So if the tulip is nuked..the wheel shouldn't turn..at least not well. Or there would be horid noises and it would just get worse in about every way.
  4. Dec 26, 2017 at 5:25 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    im guessing the tulip itself didn't nuke as said previously.
  5. Dec 26, 2017 at 6:27 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    It didn’t make any noise. No idea how. The boot came off the inside cup, so I could see inside kinda( didn’t care to look that close) I don’t really know what went wrong. I didn’t *see* chunks fall out. But when I move the shaft around it def has a ton of play. Some how it had to have been able to spin independently without making a bunch of noise. I’m equally curious. But I’m going to have to wait till tomorrow night to pull it apart and find out
  6. Dec 26, 2017 at 7:02 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well..cv axles move in and out by design.
    On a more sad note..
    It finally happened. I hit a deer tonight with igor :sad: luckily though was just at the driver side. Almost made it past but hit it full on the ass. Bumper is toast as is grill sadly and fender.
    Ordering new fender tonight.
    I need a new bumper though. Thoughts? I wanted to build my own but not gonna happen in the next week.
  7. Dec 26, 2017 at 7:08 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    That leaves almost no options other that what you have.
  8. Dec 26, 2017 at 7:10 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Also would have been fine with out hoops tonight. If I had had something more solid below it wouldn't have caved to hit the fender and such.
    But I get your point.
  9. Dec 26, 2017 at 7:11 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Eric doesn't sell DIY kits anymore. And his lead times are way too far out so not ruling him in.
    ARB. .gross
  10. Dec 26, 2017 at 7:16 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Got my old stock you can use until you have time to build one
    Edit: and a purple fender too I suppose, but I'm guessing you want a green one
    Blackdawg[OP] likes this.
  11. Dec 26, 2017 at 7:23 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah im gonna order a fender. Pretty cheap. 104 bucks shipped. I'll just get it painted.
    Thanks! I will keep that in mind. Not sure i can run down to get it. Might just be easier to get something. Can always resell it.
    think you can get it. But not a fan of that thing either..particularity how you can't run any skids but all pros..
    my options a thin. Damn.
  12. Dec 26, 2017 at 7:24 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Can put hoops on anything.... That said @Blackdawg Billy makes the sexiest first gen bumper I think, full plate brute force. Makes me all warm and fuzzy thinking about it, if I didn't have other crap high on the list I'd get one to replace my current one.
  13. Dec 26, 2017 at 7:26 PM
    Speedytech7
    sexxxx
    Blackdawg[QUOTED][OP] likes this.
  14. Dec 26, 2017 at 7:27 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Looks nice indeed. But billy's lead times aren't that great either. I'd be lucky to have something by may i think
  15. Dec 26, 2017 at 7:27 PM
    Speedytech7
    very true sadly
  16. Dec 26, 2017 at 7:28 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I was pretty close to calling him about a hybrid actually. I like his hybrid design as well.
  17. Dec 26, 2017 at 7:31 PM
    Speedytech7
    After having my current bumper I'm not wild about tube besides for grille and grille braces. It looks good on some trucks but it just isn't doing it for me. Luckily there's piles of 1st gen folks in AZ so I think I can move it when the time comes.
  18. Dec 26, 2017 at 7:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah i get that. Reason why i have a plate bumper on frank..
    His plate is pretty nice. Tucked up damn high though.
    I like what Ray did with his tube bumper though and plated the back. Looks killer really.
    Speedytech7[QUOTED] likes this.
  19. Dec 26, 2017 at 7:35 PM
    Speedytech7
    Wow you went zero to full sarcasm, careful not good for your blood pressure. Because you seem out of the loop you can buy the tubes pre-bent and notched, plenty much more adventurous folks do it.
  20. Dec 26, 2017 at 7:37 PM
    Speedytech7
    What with the constant adversary deal as of late? I have no beef with you...
    turbodb likes this.
