Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Dec 26, 2017 at 8:31 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    haha helps to be a local
  2. Dec 26, 2017 at 8:32 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    I think if you got a DIY, it'd be hush-hush. The idea would be to just have a Relentless on the truck, which would be a win for him.
  3. Dec 26, 2017 at 8:33 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I've read that the eibachs are 620 lb coil but I've never run them so hard to compare. IIRC, Monte is running 600# on his Kings.
  4. Dec 26, 2017 at 8:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    idk how much of a win it would be..But could be idk.
    They are 620s. Also i think longer.
    Just took them off grants 4runner. Frank barely had lift near the end of their life on him.
    still jacked grants up over 3''
  5. Dec 26, 2017 at 8:37 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    i used too. I think is was heavier to begin with by design...more plate up front, not a slim. But then i reinforced it some. But i can't imagine it would add much.
    If i pulled the winch id be fine im sure.
  6. Dec 26, 2017 at 8:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I know the bumper new was 115lbs. I bet its closer to 125 now with new tweaks. Add the winch and its about the same as yours.
    It would make sense to do it for now i guess...Not stoked to take it off..but could redo the winch wiring once i put it back on frank.
  7. Dec 26, 2017 at 8:54 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    FIFY
  8. Dec 26, 2017 at 8:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :brianr:
    True though..could do like Ben said. But would rather keep the Elite on Frank. Could get a 10k winch for his fat ass though..
    Speedytech7[QUOTED] likes this.
  9. Dec 26, 2017 at 8:58 PM
    Speedytech7
    After the last trip rear winch seems like a higher priority
  10. Dec 26, 2017 at 8:59 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    FIFY
    :anonymous:
  11. Dec 26, 2017 at 9:00 PM
    Speedytech7
    Well played haha
    Damn can you image hanging two winches off the rear plus his rear bumper... would need a new frame after a tough landing.
    turbodb[QUOTED] likes this.
  12. Dec 26, 2017 at 9:06 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    lol fuck you :luvya:
    Double fuck you :luvya: :luvya:
    Hows it different from a Co2 bottle, 5 gal of gall and full spare :anonymous:
  13. Dec 26, 2017 at 9:10 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I actually weighed the bumper I got from Tim after sending it off for powder coating. 110#
    Blackdawg[OP] likes this.
  14. Dec 26, 2017 at 9:11 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    makes sense as mine has the light hoop
    Digiratus[QUOTED] likes this.
  15. Dec 27, 2017 at 12:35 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Speaking of fab projects...I’m day dreaming and planning out the initial stages of my next project once the rest of the regular maintenance is done.
    We got our last room maste in, which keeps my rent just over 500 with utilities...so I still have disposable income to save back up!
  16. Dec 27, 2017 at 12:36 AM
    Speedytech7
    You should make a cable actuated cutoff for your LED headlights haha
  17. Dec 27, 2017 at 6:22 AM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    i knew i liked you
  18. Dec 27, 2017 at 6:24 AM
    Speedytech7
    Bummer its so rare for him to make 1st gen stuff. I'll have to ask about getting one, I really like it tucked nice and high no extra garbage and winch isn't as low as all the other bumpers.
    gordi[QUOTED] likes this.
  19. Dec 27, 2017 at 6:30 AM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    I like that none of you guys said for monte to just go back to stock front end on igor and drive a little slower? i mean that is also an option before he has two franks in not too long.
  20. Dec 27, 2017 at 6:33 AM
    Speedytech7
    Isn't that implied, haha you don't go to an AA meeting to hear yeah just go home and drink this'll sort itself out. Just like you don't go to TW for advice on how to make your truck more stock haha. But yeah I bet that's the cheapest option, sounds like he's had a few close calls and a less than short commute as of late.
