Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jan 12, 2018 at 1:51 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I have to rotate every oil change with the Taco, the cruiser can be every other (closer to the 6000mi recommended). That said my tires are all pretty evenly worn even though the KO2s are so freaking temperamental.
  2. Jan 12, 2018 at 1:59 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yeah I dropped the ball pretty bad here. Probaby would have lasted longer. But im still on course to get 35k out of them so whatever.
  3. Jan 12, 2018 at 2:01 PM
    Speedytech7
    What're you supposed to get out of them? I'm like 40% tread at 38-42k miles with the KO2s
  4. Jan 12, 2018 at 2:04 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    50k lol
    But whatever.
  5. Jan 12, 2018 at 3:02 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    IMO, 35K is pretty good. I am lucky If I get that much before I start to dislike the set. Once the edges of the tread blocks get rounded, they lose their ability to bite for traction. This is regardless of tread depth.
  6. Jan 12, 2018 at 3:03 PM
    Speedytech7
    Gotta start doing some smoky burnouts to sharpen the tred blocks then
    m3bassman likes this.
  7. Jan 12, 2018 at 3:08 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Hell yeah, 4 wheel burnouts... Do them all the time. :rolleyes:
  8. Jan 12, 2018 at 3:09 PM
    Speedytech7
    You could do two wheel burnies and then rotate, get that maint outta the way too haha. If a measly 4cyl can do a burnout surely you can manage a couple haha.
  9. Jan 12, 2018 at 3:11 PM
    Digiratus
    Roaming the PNW
    The RedHead
    This looks like way more fun...
    gordi likes this.
  10. Jan 12, 2018 at 3:12 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Oh, and we can't forget that burnouts actually extend the life of the tread by reducing the height of those pesky tread blocks.
  11. Jan 12, 2018 at 3:13 PM
    Speedytech7
    When you're burning off KO2s it doesn't matter haha. I suppose yours might be tougher to get to slip haha
  12. Jan 12, 2018 at 3:18 PM
    Speedytech7
    I have a tread depth gauge, I'll measure them when I get off work. Maybe they're taller, the fronts are starting to look low though so I'm not too hopeful for those at least.
    m3bassman[QUOTED] likes this.
  13. Jan 12, 2018 at 3:30 PM
    Speedytech7
  14. Jan 12, 2018 at 3:31 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    My tread depth is getting pretty low on the front.
    Will need new tires before long.
    Man. Igor is sucking the Frank money away again..
  15. Jan 12, 2018 at 3:33 PM
    Speedytech7
    Just get some used tires for winter weather, save some cash and keep you from breaking or wearing out Igor more than necessary with camping and such.
  16. Jan 12, 2018 at 3:38 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well..i still have to fix the whole front. And do the engine maintenance. I really need to fix Franks spindle to get him up here so I could drive him while I have Igor down for a few days. Matt just told me if the Solo spindles are stock geometery they should work...so that could be my big upgrade for Frank this year. Fabbed spindles, Unibal lowers, Heim steering.
    SilverGhost likes this.
  17. Jan 12, 2018 at 5:15 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
  18. Jan 12, 2018 at 6:00 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    I should of gone Solo. :homer:
  19. Jan 12, 2018 at 6:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I'm honestly thinking about buying the xlt kit. Comes with the fabbed spindle....but God damn.2" wider. Idk if I can do that. I do have plans to 4 link the rear though..18" of travel would go well with that..
    Still love my kit though. I think if I added the spindle and stuff it would be awesome.
    SilverGhost[QUOTED] likes this.
  20. Jan 12, 2018 at 7:50 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    For sure. Yeah the width will be tight on trails. But being able to run 10” on the front. I think it’s one of the best kits out there for our 4x4 trucks. Wish I would of know about it before I did my front.
    Blackdawg[QUOTED][OP] likes this.
