Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jan 15, 2018 at 3:13 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    those are like 60% more than an arb
  2. Jan 15, 2018 at 3:15 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yeah..i know. Why Im not running one haha
  3. Jan 15, 2018 at 8:14 PM
    1997tacomav6
    Denver
    Pretty close, :bananadance: 551,600 supercharged miles now
  4. Jan 15, 2018 at 8:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    its a sweet truck man!
    1997tacomav6[QUOTED] likes this.
  5. Jan 15, 2018 at 8:24 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Mmmm Hmmm I needs me a hood like that for some intercooling. Where did you find that? Customize a 4runner one or buy it?
  6. Jan 15, 2018 at 8:28 PM
    1997tacomav6
    Denver
    BossFoss[QUOTED] likes this.
  7. Jan 16, 2018 at 6:28 AM
    BossFoss
    Wyoming
    01 DC Tacoma
    m3bassman and 1997tacomav6 like this.
  8. Jan 16, 2018 at 12:14 PM
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    m3bassman likes this.
  9. Jan 16, 2018 at 12:59 PM
    geoff325
    geoff325 Well-Known Member
    Big Horn Basin
    Raptor
  10. Jan 16, 2018 at 6:07 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Extreme! 55 is sure wishful
  11. Jan 16, 2018 at 8:36 PM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    @Dagostino480 I am just a little over an hour from cheyenne over in nebraska. I have a welder and fancy new plasma cutter that i got for Christmas that is begging for projects. Also a 2 post lift in the shop. Shoot me a pm, and i can help you out.
    Sidenote.... Fiberglass, leaf packs, trilogy skids, and shock towers showed up in past couple weeks...... Just waiting on shocks still...... I have so much to do now, ill need a mod week to get it all done.
  12. Jan 17, 2018 at 8:49 AM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    02 Toyota Tacoma TRD "El Brah-co"
    Toytec BOSS with Dakars
    What is the maximum +caster values you can achieve with lr uca’s And 265/75/16’s and 285/75/16’s respectively without any wheel well rubbing? 1st gen
  13. Jan 17, 2018 at 11:30 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Lr uca's will go up to +4° caster.
    Which is way too much.
    However. If you set them at the 4° mark you can then add caster via the lcas which in turn will move the wheel away from the cab area giving you more clearance and would net you around +2° total.
    Either way you should easily be able to clear those tires with a bit of hammering.
  14. Jan 17, 2018 at 12:50 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    I’m currently on dtracs 31.5 and have no rubbing issues, however it has never tracked quite the same post lift as the oem ucas cant quite be brought back into factory caster settings. Some of the lr uca write ups mention rubbing in the rear of the wheel well with +2* caster setting, however none of them mention tire size and I don’t see it in their vehicle specs. I’m going to go 33’s for my next set so I’m more interested in anyone with firsthand experience runn No that set up.
  15. Jan 17, 2018 at 2:34 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Blackdawg[OP] likes this.
  16. Jan 17, 2018 at 5:11 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well I'm sire you can find people running those with 33s. I'm not though. Only person here that runs lr uca's is Ben but he has 32s.
    Nice! Doesn't look bad. Needs some love but for the price...totally worth it.
  17. Jan 17, 2018 at 7:57 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
  18. Jan 17, 2018 at 7:58 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ben runs a 275/70r17
    A 32 x10.5 basically
  19. Jan 17, 2018 at 9:22 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    I gave up trying to press in my bushings because I don’t have a vice, and the hammer didn’t work. Dropped them off at a shop to call and have them do it in the am, then in my sulking, I realized I can use my impact gun and just get a bigger bolt and cup to put on the control arm and I can press the bushing in that way
  20. Jan 17, 2018 at 9:24 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yep. Done that on the trail. Works great
