Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jan 18, 2018 at 1:03 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    oh..nevermind. Hella lights are way cheaper then i remember haha
    m3bassman likes this.
  2. Jan 18, 2018 at 1:10 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    unless you got something different than the 500 or 500ffs.
    Do you really think the retro fit hellas with the 55w HIDs will be substantially better than the HIDs i posted? I do have to go through the moderate amount of work to drill the back of the hella housing and mount the HIDs
    the pro comps look a bit more durable too...And if I wanted to could I just put in a 55w bulb in the pro comp ones I posted when/if they go out and make them brighter?
    edit: looks like its all about the ballast (im learning) so if I wanted brighter lights, gotta get the 55w kit you posted
  3. Jan 18, 2018 at 1:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Idk if you could get the ballast to work on the pro comp lights if you tried that.
    Think mine were the 500ff
    Brighter? Idk. I do think that the procomps will be a better spot because the reflector bowl is deeper so it'll make a more focused spot vs the hellas which will have a better spread.
    Couldn't say which would be better though. Hellas will be a lot small(thinner)
  4. Jan 18, 2018 at 1:20 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    better spread, sounds nice, and they are still long range enough they will go weeellllll beyond the head lights ya?
    also, seems like a way easier conversion than i thought
  5. Jan 18, 2018 at 1:24 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    my led sun headlights are quite nice thanks
  6. Jan 18, 2018 at 1:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yes mine still had a very good spot. Goes damn far. I still have 2 mounted on Frank. Still the brightest lights on him.
    700s are about 8'' big. never ran them. I fit 4 hella 500s on the front of early Frank though.
  7. Jan 18, 2018 at 1:31 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  8. Jan 18, 2018 at 1:34 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Blackdawg[OP] likes this.
  9. Jan 18, 2018 at 1:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    oooooo nice! :popcorn: Interested to see what you find.
  10. Jan 18, 2018 at 1:41 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  11. Jan 18, 2018 at 1:42 PM
    Speedytech7
  12. Jan 18, 2018 at 1:45 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Seems to have convieniently missed that post :D
  13. Jan 18, 2018 at 1:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    lol forgot to respond.
    I told her that. But she said, we aren't married!. So...miss it was. haha
    Digiratus likes this.
  14. Jan 18, 2018 at 2:21 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Well ya fuckin sold me. Easily the biggest improvement were the 500s. cheap, easy, bright AF. looking at other posts 6k seems too blue, so i think id opt for 5500.
    next round of buying starts in 4 weeks, after i pay rent and finish round 2 of maintenance
    Blackdawg[QUOTED][OP] likes this.
  15. Jan 18, 2018 at 2:29 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    and like clockwork...every couple of years i totally remove and redo all the wiring in my truck as i add enough stuff that just shoving more wire in doesen't work anymore. So when i start this next wave of fun mods, imma pull out all the wiring, get new switches, employ some relays, and make everything cleaner
  16. Jan 18, 2018 at 2:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Get a bussman if you can swing it. Super clean install that way.
    You can't do this install 100% as you can't use the mounting bracket i used. But you can figure out something similar. check it: https://www.tacomaworld.com/threads...nkensteins-helper.390488/page-4#post-13214812
  17. Jan 18, 2018 at 2:35 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    i already have that blue sea fuse box/100a breaker I made a while back. Going to obviously run everything off that. While I like your method of only running ground into the cab, i want my switches to all light up, im still going to run power through the cab, and probably just run a relay for the hellas. but i got a while to figure that all out
  18. Jan 18, 2018 at 2:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah this is a different bussman install..click the link haha
    and if you get switches that light up. Do NOT get blue. For the love of god. Too damn bright. Just go for red/orange.
    IDtrucks[QUOTED] likes this.
  19. Jan 18, 2018 at 2:37 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    luckily some of the switches i want only come in red...just realized that my ARB ones are blue...guess we will have a theme of red for lights and blue for lockers haha
  20. Jan 18, 2018 at 2:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    My Ditch light switch is blue..fucker is way to bright. I want to swap it out and will after I add some spots to the new bumper. Plus Then I can finally do my high beam interceptor mod.
