Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Feb 20, 2018 at 12:37 PM
    geoff325
    geoff325 Well-Known Member
    Big Horn Basin
    Raptor
    Anyone here know a good place in northern wyoming to get a trailer? I just bought a 2018 X3 RS turbo. I am looking to get a trailer but this is the extra wide version, about 72 inches. Its 11 feet long too. Also if you guys have some input on the terrain there, would trailer brakes be necessary? I have the tow package, about 6800 lbs, so total weight should be around 2500 to 3000 depending on trailer. Thanks,
  2. Feb 20, 2018 at 12:49 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    If you plan on going up the mountain with it...id get trailer brakes.
    As for where to get trailers..none really come to mind but I see them for sale in places all the time in Cody and Billings and such. Boone Fabrication in Cody may make them actually.
  3. Feb 20, 2018 at 2:21 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Forklift Debacle Update:
    Ballard Transfer came in get our forklift upright again.
    They brought two forklifts of their own. This is Big Bertha:
    The hookups:
    Even the driver was big.
    His smaller companion:
    Tilted it back up:
    Higher and higher:
    Until that magic moment when the weight shifted back and it rotated the rest of the way on its own:
    I gotta say, these guys were pros and made it look easy. But I guess that is their experience showing.
    Glad that is over...
  4. Feb 20, 2018 at 2:54 PM
    Digiratus
    Roaming the PNW
    The RedHead
    One of Big Bertha's fork tips had a huge shackle and two smaller ones for the 3 pickup points. The smaller ones were 3/4" like we use.
  5. Feb 20, 2018 at 7:45 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    02 Toyota Tacoma TRD "El Brah-co"
    Toytec BOSS with Dakars
    @Blackdawg @Squeaky Penguin, CVJ got back to me, looks like $282 an axle with the high angle boots on both ends and no cores, which is pretty much Toyota reman price, so I’ll be going with the CVJ’s in hopes that the high angle boots make a difference.
    How many hours do you figure your front end refresh took you on Igor?
    General question for everyone, how long have people spent doing the timing belt replacement?
  6. Feb 20, 2018 at 7:49 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Timing belt with water pump can take a full saturday. Depending on your skill level.
    Front end refresh..as is when i did LBJ, tie rods, steering rack bushings? mmm..idk..4-5 hours maybe. But i fucked up and had to drop the rack 2 times haha Normally takes less then that. I can swap a CV in under an hour and do a LBJ in less time now..but im well versed doing that :anonymous:
  7. Feb 20, 2018 at 7:53 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    Guess they couldn’t get the forks back down the mast? That would have made nervous AF.
  8. Feb 20, 2018 at 7:53 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    You can figure on at least a full day for first go round with the TB.
  9. Feb 20, 2018 at 7:59 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    I’m doing CV Axles, lower ball joints, upper ball joints, inner and outer tie rod ends, tie rod boots, steering rack bushings and UCA’s.
  10. Feb 20, 2018 at 8:03 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I think you'll be happy with the CVJs and high angle boots. Two hard seasons on mine and no issues.
    Timing belt took me a solid afternoon.
    Pltmnky likes this.
  11. Feb 20, 2018 at 8:03 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    Didn’t you do one recently? Hint, hint, nod knowlingly;)
    BossFoss[QUOTED] likes this.
  12. Feb 20, 2018 at 8:12 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    I did. If you want help I'll come give you a hand one of these weekends.
    Pltmnky[QUOTED] likes this.
  13. Feb 20, 2018 at 8:22 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    I might take you up on that offer, especially if you have a torque wrench that goes up to 250ft. Lbs. other than that I have access to a nice heated shop with all the air tools ones heart could desire...we’d be talking Pappy Van Winkle not PBR:cheers:
    Or maybe Stranahans or PVW 15yr old, forgot how much the high end PVW is:eek:
  14. Feb 20, 2018 at 8:23 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    that'll be a good day of work Id say at an easy go pace.
  15. Feb 20, 2018 at 8:30 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    I was kind of figuring a day per side, if everything was really fiighting me.
  16. Feb 20, 2018 at 8:41 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    not bad to plan for it haha
  17. Feb 20, 2018 at 8:57 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    I might of overshot there, last time I had PVW it was like $300 a bottle, now it’s a mortgage payment...
  18. Feb 20, 2018 at 8:58 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    really? My dad got 2 bottles couple years back. Was 100 for 15y and 150 for 18y he got.
  19. Feb 20, 2018 at 9:01 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    Who’s his supplier and what’s his personal phone number and address :rofl:, I haven’t seen it for sale outside of a major metro and the internet prices are steep.
  20. Feb 20, 2018 at 9:04 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    think it was some small place in Big Timber MT actually that he got it. Put his name down at like 10 stores in Wyo and MT haha i guess that guy buys all the PVW in the MT
