Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Mar 2, 2018 at 5:34 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I will be watching closely what they come up with.
    nice! What kid? DMZ?
    Yeah. But thats what positive castor is..that said. 1'' will be a LOT of castor.
  2. Mar 2, 2018 at 5:54 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    no idea for both. Have to wait and see.
  3. Mar 2, 2018 at 6:20 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    02 Toyota Tacoma TRD "El Brah-co"
    Toytec BOSS with Dakars
    If these increase castor, it should increase stability at highway speeds/track straighter right? If that’s the case I’d be a customer, hopefully it will jive with the SPC’s.
    On another note, if I plan on running 33’s with the 5speed, what gears should I aspire to?[/QUOTE]
  4. Mar 2, 2018 at 7:08 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Let us not loose site of the fact that the real value of these new lower arms would be the uniball design to eliminate the stock LBJ. That in itself is enough reason right there for running them.
    And if you ask 10 guys about regearing, you'll likely get 10 different perspectives. Here is mine. 4.56s with the 5 speed will be enough if your truck does not get heavy or you do not need to go really slow out on the trail. Otherwise go 4.88s. If I had a 5 speed I would still go 4.88s knowing what know now.
    Pltmnky[QUOTED] likes this.
  5. Mar 2, 2018 at 7:13 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Still 4 bolts holding it to the spindle, or fabbed spindle, whereas the cost would make no sense.
    I still will say there's no LBJ 'problem', just something you have to keep up on. $1500+ on new LCAs versus checking you bolts and LBJs occasionally, I'll be sticking with stock lowers.
    Speedytech7 and Blackdawg[OP] like this.
  6. Mar 2, 2018 at 7:30 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    I just went through the same decision you are - I've got the MT and 33's now and knew it was between 4.56 and 4.88's. Ultimately, I went with 4.88's and I'm glad I did. The truck just feels "peppy" again. And gas mileage isn't all that much worse - in fact, it's comparable to what I was getting on 4.10's (the 33's are what kill the mpg's).
    I figured that I'd rather err on overgearing slightly, so that I wouldn't run the risk of having to regear again in the future (I have no plans to go to 35's).
  7. Mar 2, 2018 at 7:37 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I didn't see a price point listed with that announcement. Do you know something the rest of us don't?
    Failure of the 4 mounting bolts is not the problem.
  8. Mar 2, 2018 at 7:44 PM
    Squeaky Penguin
    Brett
    That's the going rate for stock length uniball lowers for 2nd gens. Don't see why these would be any different.
    Also, those uniballs hate mud, and the lowers end up way more susceptible than in our UCAs. The guys that I know running them are dealing with constant squeaking and replacing uniballs at least once a year.
  9. Mar 2, 2018 at 7:50 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Maybe some ground rules first; I've seen you drive :burnrubber: :D. But sure
  10. Mar 2, 2018 at 8:45 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    [/QUOTE]
    4.56 if you stay light. 4.88 if you want to offroad a pig.
    It doesn't appear to be a uniball design. Still stock LBJ.
    I disagree. having a LCA that is setup to run a better bump stop and secondary already could very well be worth it to some.
    it'll feel almost exactly like Frank regear in terms of pep and torque. When Brett and I did the crawl race i was just BARELY slower.
  11. Mar 2, 2018 at 9:01 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I was going by what it looked like in the picture. Looks like a uniball to me. :notsure:
  12. Mar 2, 2018 at 9:16 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    I guess for me if I did add a failsafe dimension to the lbj that would be enough for me. If however it effectively lengthens the wheel base and makes it cruise down the highway better, that would also be enough for me. If it does neither of of these things then it is useless to me.
    I guess 4.88’s are my long term objective then, because if I knew how to weld, I’d probably go straight to 35’s. Cuz as Will Smith said, “ it’s just for the look, I don’t light it.”
  13. Mar 2, 2018 at 9:16 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I know, i just meant in terms of the torque and accleration. It'll be the same....well..when you last drove Frank. SC made it a lot faster.
    Its not. There are other photos and it looks identical to my LT adapters.
  14. Mar 2, 2018 at 9:17 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    If you go to 35s(which really? You don't seem like you'd need 35s?) go for 5.29s hands down.
  15. Mar 2, 2018 at 9:22 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    I wouldn't want to drive around for very long without 35's on 5.29's though...
    Edit: ...this is just me, headed to the grocery in 2LOW... der-dee-der :p
    Pltmnky likes this.
  16. Mar 2, 2018 at 9:24 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    Most people don’t plan on getting 35’s, it just happens...like marriage...or having children:laugh:
    turbodb[QUOTED] likes this.
  17. Mar 2, 2018 at 9:27 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    Who actually “needs” 35’s? They sure as shit look cool in the grocery store parking lot though:boink:
  18. Mar 2, 2018 at 9:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No that wouldn't be good. though someone on here had 5.29s on 33s haha
    Almost no one.
    You just don't seem like the person who does the kind of wheeling that would see much benefit from them is all i meant. 33s are perfect for these rigs. Not saying I don't love 35s, just saying that with the investment of 35s its often not worth it for most.
  19. Mar 2, 2018 at 9:38 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  20. Mar 2, 2018 at 9:38 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Seriously... Sometimes I wish I has 5.29s.
