Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Mar 2, 2018 at 9:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    with an auto i can see that. Not so much with a manual haha
  2. Mar 2, 2018 at 9:41 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    02 Toyota Tacoma TRD "El Brah-co"
    Toytec BOSS with Dakars
    I know exactly what you’re saying, and you’re completely correct, I could have redone the stock suspension and stuffed 265/75/16’s under and it and probably have not needed to go up a size. But the bottom line is I enjoy the mod process and incrementally going overboard. In defense of my current setup it feels better going 60mph over washboard dirt roads then my old setup. We all seem to forget, though that all these “crawling” trails were originally done by Willy’s jeeps or equally un-modified vehicles. So why do we do all these mods? Cause we like it.
  3. Mar 2, 2018 at 9:42 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Looks like they all have small shank hole for stock LBJ, which if that's the case I see no real value to these unless the price is plus or minus 100 from stock replacements. If you can go for a lower uniball wouldn't it be oriented sort of unideal?
  4. Mar 2, 2018 at 9:46 PM
    Speedytech7
    Just looked in the comments, yeah stock LBJ only, can't fit a 1" uniball in the space.
  5. Mar 2, 2018 at 9:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    haha nothing wrong with that!
    I can say..doing 35s was a PITA for a mod..but i enjoy them.
    Like i said earlier, the real advantage will be dual shock mounts and if a bump stop can can fit.
    As for geometry of the LBJ, shouldn't matter too much, its the tie rod that i think might have problems.
  6. Mar 2, 2018 at 9:48 PM
    Speedytech7
    I meant for a uniball, it would put pressure on the minimal contact side of one. Instead of being oriented vertically. I suppose anything to lessen the harshness of the stock short arms would be nice. I suppose I won't have to worry about any of it anyway.
  7. Mar 2, 2018 at 9:50 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah just do their fabbed spindle again...bet that will be a package. probably cost as much as LT easily.
    Speedytech7[QUOTED] likes this.
  8. Mar 2, 2018 at 9:51 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ah, that i don't know.
  9. Mar 2, 2018 at 9:52 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    That’s exactly where I’m coming from, I’d spend over 10k in welding equipment and practice just to be able to tub for 35’s. But man I like how they look...so someday who knows?
    Speedytech7 likes this.
  10. Mar 2, 2018 at 9:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Nah you only need like 1k in gear probably. A lot of time and no matter what...welding on the body work...SUUUUCCCKKKKS. So..just embrace it haha
    Pltmnky[QUOTED] likes this.
  11. Mar 2, 2018 at 9:56 PM
    Speedytech7
    It's half the reason I bought a new welder for my last project, just gotta find a good sealer for after the work before I dive in.
    Pltmnky likes this.
  12. Mar 2, 2018 at 10:04 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    You’re making a strong case for buying a welder:welder:
  13. Mar 2, 2018 at 10:06 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Get smaller wire, that will help. .030 or smaller.
  14. Mar 3, 2018 at 11:13 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    That was fun. And didn't have to stand around in the snow and cold this time.
    m3bassman likes this.
  15. Mar 3, 2018 at 12:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  16. Mar 3, 2018 at 2:37 PM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    That video was a pain. More trail view would be better
  17. Mar 3, 2018 at 2:40 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    What
  18. Mar 3, 2018 at 4:09 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    I think he means doing the trail in person and not living life vicariously through the internet is the better option.
  19. Mar 3, 2018 at 5:04 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    Oh probably. I wasn’t living through the video I was complaining about the video being 1/4 of the screen. I did watch 1 minute of the video
  20. Mar 3, 2018 at 6:03 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    Yeah that is a small viewing area, sorry I was projecting my own regrets about pissing away time on the internet rather than making things happen.
    m3bassman and gordi[QUOTED] like this.
