Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Mar 11, 2018 at 3:58 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Didn't I remind you of that already? That's why we're not waiting for ya :sorry: :p
  2. Mar 11, 2018 at 4:02 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    On the flip side, we haven't started to get ready yet so you're ahead there. That's tomorrow. Mostly just reinstalling the skids and some food prep, I think.
  3. Mar 11, 2018 at 5:02 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I am rethinking my bed organization today, trying to find some action Packers locally and a couple more fuel cans
  4. Mar 11, 2018 at 5:11 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    if you are going into the maze and doing a lot of driving, take as much gas as you can.
  5. Mar 11, 2018 at 5:13 PM
    Speedytech7
    Tire? Like just tire no wheel? Not easy to wrestle them sun's of bitches into a rim or inflate aftet
  6. Mar 11, 2018 at 5:16 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah just bringing a wheel is stupid. Especially considering you and Zane have the arm strength of a baby hamster combined.
    And not great way to set the bead safly as none of you run CO2
  7. Mar 11, 2018 at 5:27 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    02 Toyota Tacoma TRD "El Brah-co"
    Toytec BOSS with Dakars
    Just curious as to why you run CO2 vs nitrogen? Nitrogen is more stable inside the tire and will also run air tools if you don’t have a compressor.
  8. Mar 11, 2018 at 6:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Because nitrogen is expensive as fuck
    Meh. Not really. Your a twig. Anyone that has met you knows that
    My problem is usually over torquing bolts
    Member1Zillion likes this.
  9. Mar 11, 2018 at 6:26 PM
    Speedytech7
    Hey, I have zero problems making sure my parts are bolted down at least
    m3bassman likes this.
  10. Mar 11, 2018 at 7:02 PM
    Member1Zillion
    Member1Zillion Involuntary Kamikaze Co-Pilot
    Big Whiskey, WY
    '01 TRD, '17 Tundra, '07 FJ Cruiser, 94 PU, '18 T4R, '84 PU
    This, that, & the other thing
    I accidentally found an '04 double cab in perfect shape today. Low miles too. I gotta stop this addiction with used Toyotas. I've gotta let some go before the Mrs commits a homicide.
    BossFoss likes this.
  11. Mar 11, 2018 at 7:05 PM
    Speedytech7
    Rear shock ended up being threadless, hilift was a palm wheel, exhaust broke a weld. Battery was probably loose tho
  12. Mar 11, 2018 at 7:29 PM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    I’d comment but I had a wheel come off haha. But ben you were working on it with me. 70/30 my fault.
  13. Mar 11, 2018 at 7:32 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    I’ve never had to buy it, but have always had access to it through aviation, what is the cost difference between identical sized bottles of nitrogen and CO2?
  14. Mar 11, 2018 at 7:57 PM
    Speedytech7
    I know haha, the bolt hole had all the threads pulled out somehow
  15. Mar 11, 2018 at 7:58 PM
    Speedytech7
    Pretty much loaded up, just gotta throw the toolbox in
  16. Mar 11, 2018 at 8:00 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    So much gas for he 4cyc
  17. Mar 11, 2018 at 8:04 PM
    Speedytech7
    I was told bring extra, and there is a part along the way to moab where there are almost no stops for the entire range of my tank
  18. Mar 11, 2018 at 8:11 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Calm down boys. I've got the solutions right here.
    1. Kristen and @mrs.turbodb will both be on the trip, so we've got the arm strength covered.
    2. And hopefully we won't have to worry about torquing down ball joints, none of us are running 35's.
    hahahahaha
    gordi likes this.
  19. Mar 11, 2018 at 8:54 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  20. Mar 11, 2018 at 8:55 PM
    turbodb
    Dan
    PNW
    AdventureTaco
