Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Mar 28, 2018 at 4:34 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    should have done cam tab gussets while you where in there.
  2. Mar 28, 2018 at 4:35 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    If we had a little bar stock with us that would have been a good idea.
  3. Mar 28, 2018 at 5:22 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    ...and some more time. I think there was already some urgency to get out of there :). (Of course, we could have parallelized it for sure...)
    Edit: Mike - happy to bring the welder over, or have you drop by if you want to get it taken care of.
  4. Mar 28, 2018 at 5:23 PM
    Speedytech7
    If we had the bar stock it would have been 10mins per side with the metal glue gun. I still have to do it to mine too
  5. Mar 28, 2018 at 5:28 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    hahahaha i had so much fun doing that exact same thing
    turbodb[QUOTED] likes this.
  6. Mar 28, 2018 at 5:50 PM
    INBONESTRYKER
    INBONESTRYKER Well-Known Member
    WY
    '96 access cab 3.4 5 spd manual 4X4
    1/4 sq key stock at the hardware store - if you get plated, a soak in vinegar will remoe the plating.
    Speedytech7[QUOTED] likes this.
  7. Mar 28, 2018 at 5:51 PM
    Speedytech7
    Now I have next weekends project
  8. Mar 28, 2018 at 5:53 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I tried welding behind the stock tabs.
    Total Chaos setup is much better. My alignment has been holding really well. Huge PITA job, made even worse if you've already welded behind the stock tabs...
  9. Mar 28, 2018 at 6:44 PM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    I heard it’s a huge pain in the ass. The total chaos kit makes it easier and worth the expensive price
  10. Mar 28, 2018 at 8:15 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah i wouldn't do the bar stock idea.
  11. Mar 28, 2018 at 8:18 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I had no idea this was important. I've heard and read that it is on 2nd gens, haven't heard this in the same volume for 1st gens.
    Now I am confused. Is it an easy job or not?
    What is it that made it so hard?
    Is the steering rack in the way for the rear tabs? I assume there are tabs on the back side of the arms.
  12. Mar 28, 2018 at 8:22 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    You have to drop the LCAs and chisel off the stock cam tabs then burn in the TC ones. 8x..not a fun job.
    Was a prime time to do it while the LCAs were down. as they dont drop without move the rack out of the way..
    For what we do. It is worth it I think.
  13. Mar 28, 2018 at 8:35 PM
    Squeaky Penguin
    Brett
    LCAs need to be out, cvs should be out, and the steering rack should be out, or at least unbolted and pulled back.
    Then you have to drill though the spot welds on the stock ones and hammer them off. If you already welded behind bent stock ones like I had, it's a nightmare grinding through all that. Not a lot of room to work in there, especially on the inside ones.
    Worth it though, my alignment held solid all of last year.
  14. Mar 28, 2018 at 8:44 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I sure wish I had realized all this before last weekends party.
    BossFoss likes this.
  15. Mar 28, 2018 at 8:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :sorry:
    Id have mentioned it if I knew that was happening.
    Digiratus[QUOTED] likes this.
  16. Mar 28, 2018 at 8:47 PM
    Speedytech7
    There's always next time haha
  17. Mar 28, 2018 at 9:32 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
  18. Mar 28, 2018 at 9:51 PM
    Digiratus
    Roaming the PNW
    The RedHead
    BossFoss[QUOTED] and drr like this.
  19. Mar 28, 2018 at 10:29 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Jeez you guys are trying to add more stuff we could have done?!
    Mike I have an idea that your style of driving isn't quite "bending cam tabs" crazy...
    Digiratus likes this.
  20. Mar 29, 2018 at 6:47 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not usually. But doesn't mean he doesn't do it every once in a while. He like to strech the red heads legs here and there.
    sometimes on purpose...sometimes not..haha
    At least he has life time alignment.
