Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Mar 29, 2018 at 6:48 AM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    I’ve seen people weld behind the stock cam tabs but I’m curious if that is very easy bc that metal seems very thin. At least on second gens
  2. Mar 29, 2018 at 7:11 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    The metal is very thin on both gens. This is why I don't think its a good idea as the heat will literally pull the tab away from the cam.
  3. Mar 29, 2018 at 8:14 AM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    On the second gen it was super easy to do the chaos cam gusset. Air chisel off stock tab and weld on gusset. Yea it's awkward position to weld but it's not that bad.
    FreidTaco and gordi like this.
  4. Mar 29, 2018 at 8:32 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I still wish I could do solid lowers like you. And heims in the LCAs like Camburg LT kits.
  5. Mar 29, 2018 at 10:30 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Well, considering it was impossible to move the cam adjusters, it seems like the tabs were safe in those conditions.
    Now that we have molested her down there, it may well be that alignments are easier to lose. :oops: I guess as long as the tabs don't bend in the process, things will be fine in that there wont be anything an alignment can't fix.
  6. Mar 29, 2018 at 12:04 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    You did a good job of marking your alignment cams, I would do the same with the bolts after making sure the shop torques them properly.
    It would be pretty easy to reset the alignment to the last known position until you could get it on a rack then.
    Digiratus[QUOTED] likes this.
  7. Mar 29, 2018 at 1:40 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yup. I had planned on doing this..
    drr[QUOTED] likes this.
  8. Mar 30, 2018 at 9:46 AM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    How many of you are running c range tires? I have E and am considering my next set to be C. Considering another set of stmaxx or an all terrain
  9. Mar 30, 2018 at 9:59 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I have Cs on Frank, always have. Little truck also has Cs. Igor has Es. I would love to run Cs on Igor. Only tire in a 33 on a 17'' rim i can find thats not shit is the KO2s..
    Don't think you'll find many options in a C rated for a 16 or 17'' wheel.
  10. Mar 30, 2018 at 10:44 AM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    I have 17s, was hoping for a 285 in c rating.
  11. Mar 30, 2018 at 10:46 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    only 285 i found was a KO2 with a C rating. Or E if you wanted.
  12. Mar 30, 2018 at 10:50 AM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    Ya I really
    Like the copper at3s that we have on the 4Runner too. I’m just curious is having less ply in the center has been a off-road issue for anyone with a c vs e
  13. Mar 30, 2018 at 10:55 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not for me. In fact, ride is better having the softer side wall.
    Thats all it is. While some tires do have more side walls in there E vs a C. Some do not. Just a less stiff side wall as E is just a higher load range.
    Our trucks don't weight that much for an E anyways. So it tends to be a rough ride. Don't get me wrong aired down is still smooth in Igor, but not as smooth. And when Igor is at 40psi its rough. Im hoping just a wider tire in general though helps it be not quite as rough as I also won't have to run as high of tire pressure on the street.
    gordi[QUOTED] likes this.
  14. Mar 30, 2018 at 11:22 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    I so wish someone would make 33" C's for 16" wheels. I sometimes wonder if I should have stuck with 15's, and foregone the Tundra brakes... For now, I'm hoping the sidewalls on these ST/Maxx's break in over time.
    Digiratus likes this.
  15. Mar 30, 2018 at 11:34 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    I have a bit - 18 psi is meh (feels like 25 on my C Duratracs); 16 is better. Going for 15 on the next trip.
  16. Mar 30, 2018 at 11:36 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    are yours Es? if so..don't expect them to loosen up much..mine never did really.
    True but for a tall and skinny tire like his to get even wear he will have to run a higher pressure on the road. I run 40-42 in igor for instance vs 32 in Frank which is considered pretty low.
    at least you're on 16s. I went to 18 and it felt great but the odds of hitting a wheel where way too high with mine that low. 20 it is.
  17. Mar 30, 2018 at 11:44 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    Yep, mine are E's. And yeah, on the road I have to be at ~40, which is not great (though is better when we're loaded down, which is most of the time now when we're in the truck :D :p).
    I'm surprised 16/17 would make that much of a difference with hitting a wheel; I'll have to keep a really close eye. Maybe I stick in the 16-18 range long term; we'll see.
  18. Mar 30, 2018 at 11:47 AM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    I run 35 on the st Maxx and rotate every 5k. Really even tread wear actually. But ya stiff still.
  19. Mar 30, 2018 at 11:48 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I mean might as well try it.
    I had i think 18? maybe it as 15..idk can't remember :oops: for HITR and saw this:
    [​IMG]M~D~U-66.jpg by Monte Nickles Photos, on Flickr
    I know that doesn't look that bad in the photo(does it ever look as bad?) but it wasn't even a really narrow spot for the tire to be on and was pretty darn close. For crawling, was fine. But I know that at speed that could be a wheel breaker. So back up to 20 i went after that trail.
    turbodb[QUOTED] likes this.
  20. Mar 30, 2018 at 9:33 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not gonna lie. Looks like it fits perfect on 2nd gens with the voodoo bed rail caps.
    Love how the side panels full open
    If i had a 2nd gen Id be all over that.
    Can't wait to see what yours looks like @Squeaky Penguin I really how they have tested fitted a 1st gen..gonna be way different to fit. Plus narrower bed.
    Digiratus, BossFoss and SconnieHailer like this.
