Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Apr 9, 2018 at 10:55 AM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    So who else is checking the torque on their U-bolts after reading this. I checked mine about a month ago, but will check them again as soon as I get home.
  2. Apr 9, 2018 at 10:58 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I'm gonna go throw a set on my cruiser just to check them. Also maybe I'll throw a torque wrench on the ones on the taco :p
  3. Apr 9, 2018 at 11:00 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Goose lake. SOS trip. We re did you leafs and I had done mine before the trip. On our way out i heard clicking from the rear. Checked the rear U bolts. After the bigger obstacle right by the lake I tightened them up and you checked yours to be safe and they were also loose.
    Mine were also loose when we did the Magruder
  4. Apr 9, 2018 at 11:10 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I think I did it as i have the wrench out already.
    m3bassman[QUOTED] likes this.
  5. Apr 9, 2018 at 12:07 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Impressive lack of forethought and general lack of concern about somebody else's stuff right there, but hey you got it on video and got likes :thumbsup:
  6. Apr 9, 2018 at 12:30 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    :anonymous: I havent checked my ubolts in 2+ years... I have the megabeast ones from ruffstuff. The nuts are almost an inch tall and I red loctite them. And now they're practically welded on there with rust. Maybe I'll hook up to a stump with my axle this weekend and leterBUK. Probably get a ton insta likes! Then I can get a Ford 9"!
  7. Apr 9, 2018 at 12:41 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    WTF, after the first sound of metal snapping, they continued wowsa
  8. Apr 9, 2018 at 1:16 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    that sounds like a great plan! think i'll follow suit!
  9. Apr 9, 2018 at 1:21 PM
    Prayn4surf
    Socal
    I think everyone on TW is outside with a torque wrench as we speak
    I just realized I was in the Wyoming thread ha, thought I was somewhere else...carry on haha
  10. Apr 9, 2018 at 3:07 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    i had that happen to me in moab a few years back. luckily it happened in camp going 3 mph...wondered why my tire was rubbing the front of me fender while not flexing...on the rear axle. center pin broke and u bolts came way loose and the axle slid forward on one side
    in other news, this last storm ripped the tarp off my boat...so now 2.5 weeks ahead of schedule i have to borrow a truck and make an emergency trip to idaho falls to drag it back so it doesent leak or something dumb
    SnowroxKT likes this.
  11. Apr 9, 2018 at 3:51 PM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    I’m like 1.5 years and have taken them on and off a few times. Blue loctite and never had issues with a proper torque wrench
  12. Apr 9, 2018 at 3:56 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    no so much the nuts coming loose at it is the bolts stretching themselves.
  13. Apr 9, 2018 at 7:00 PM
    BossFoss
    Wyoming
    01 DC Tacoma
  14. Apr 9, 2018 at 7:29 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    tight is tight idk ive never had an issue or even found one loose. Like Marc said rust keeps them pretty still. Mine have a little love on them at all times but i have checked them in the past and they wouldnt even move but they always come off.
  15. Apr 9, 2018 at 9:11 PM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    Found out why allpoo installed such a small bolt.
  16. Apr 9, 2018 at 9:13 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I've read several times in several places that u-bolts should not be reused. iirc, its the way the threads are cut into the metal rods. They deform when torqued to spec.
    You guys can reuse yours if you want, but I treat them as throw away parts and always use new.
  17. Apr 9, 2018 at 9:15 PM
    Speedytech7
    They're like headbolts to me, trash after one use
  18. Apr 9, 2018 at 9:22 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Good quality bolts of any type should have roll formed threads, not cut threads. If they are cut, you lose quite a bit of strength at the root of the threads, and they're probably cheap enough you can replace them often.
    Quality u bolts are usually a high carbon alloy and the torque spec shouldn't be anywhere near the yield point. If the threads aren't damaged there is no reason you can't reuse them.
    Agreed on the headbolts though, those are usually torque-to-yield by design.
  19. Apr 9, 2018 at 9:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    What is that?
    I usually replace them pretty often. Most the time they are bent anyways.
  20. Apr 9, 2018 at 9:31 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Did not know there was more than one type. Are the ones from Wheelers or Alcan the cheap ones or the good ones?
