Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Apr 17, 2018 at 9:36 PM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    True and better that he’s not ona a trip. But I think he is stuck dailying Ben’s Durango lol. Poor guy
  2. Apr 18, 2018 at 1:25 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    wow toyota wants 1258 bucks to do a clutch. hahahahaha wow.
    only 303 for the speedo cable though..
  3. Apr 18, 2018 at 3:45 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Wow. These guys are pros. Calm, cool and collected under pretty tough conditions.
  4. Apr 18, 2018 at 3:47 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah that female pilot held it together great.
  5. Apr 18, 2018 at 11:25 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    Grape them right in the mouth.
  6. Apr 20, 2018 at 6:36 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    trying to figure out wtf was going on with this trailer wiring is boggling my mind and its only like, 6 or 7 wires (the po never had brakes either). Used a 6 (trailer) to 7 pin adapter on one truck (newer assuming factory wire install), no brakes but lights all work (all 3 functions), then i plug it into another truck's 7 pin (older, possibly aftermarket wiring install) and the brakes get full power and lock up. So I cut the blue wire for trailer brake power on the trailer and the brakes free. So that at least tells me they work. Then I dissect the wiring harness, and the blue brake controller output wire is plugged into a white trailer brake wire, and also has a spliced end grounded to the trailer frame. Im assuming this ground is bad since I cut the brake wire forward of this splice, in other words i cut the blue wire and further down the trailer there was still a splice with a ground leading to the trailer frame. The brown, other trailer brake wire (only 2 wires for the 4 brakes, magnetic brakes are not polarized so they can go either way) is attacched to a black wire...which if done properly is the 12v accessory power. The 12v power wire should be the center pin, but sometimes the trailer brake and 12v power wire have switched positions on 6 way pins, ideally never on 7 pins, so if it worked with one truck and not the other im not sure if that matters.
    The best part, there was no ground going through the trailer harness. Only that one spliced end going to the trailer frame (still unsure on connection quality there). In the ground wire's place was the black 12v accessory wire.
    SO, my theory, and from looking at the one pic I have of the old 6 pin harness and the black 12v power wire is where the ground wire should be. So on the newer truck when i plugged in the connector the blue brake output from the truck went to the trailer and never grounded and activated the brakes, also assuming on this truck there is no accessory power since they never locked up. And on the older truck im thinking there was accessory power since the brakes stayed locked up until I unplugged the harness, or cut the blue brake line which could have been acting as a ground back into the truck. I guess i dont know the states of either of the tow trucks except that one was much older and i would trust the wiring less, and one was much newer so i can only assume it was done cleanly
    The older truck's controller could have been malfunctioning and sending a constant signal, but that doeset really explain why on the newer truck when I tried to apply trailer brakes they didnt work. I think its more likley the older trucks brake controller wasnt doing anything at all, just grounding the trailer to the frame
  7. Apr 20, 2018 at 6:51 AM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    I think for a time Ford and chevys were wired differently for trailers. It caused what you are describing for the brakes to lock up. Weird they wouldn't just try and make it the same
  8. Apr 20, 2018 at 6:54 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    if thats true...it may be the case. the newer truck was a gmc sierra and the older one was an early 2000s? f-150
    m3bassman likes this.
  9. Apr 20, 2018 at 11:18 AM
    Justrom
    Justrom Well-Known Member
    County 10 - Wyoming
    '13 Dbl Cab Long Bed
    Couple of cool Cruisers. The older one was lifted in 35s, fully caged and running racing seats with 5 point belts....:burnrubber:
    BossFoss, Blackdawg[OP] and m3bassman like this.
  10. Apr 20, 2018 at 11:32 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    nice! There an event your at or something?
  11. Apr 20, 2018 at 12:46 PM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    Just received a package from trail-gear with an allpoo product inside
  12. Apr 20, 2018 at 12:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    trail gear bailed allpro out. Bought them i believe.
  13. Apr 20, 2018 at 2:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Holy fawk it's nice out. I almost forgot what a sunny warm day was. It's almost hot even in just a t shirt.
  14. Apr 20, 2018 at 2:27 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    When and where.
  15. Apr 20, 2018 at 2:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    no chance for us. Nothing opens until june in the pyors and big horns.
    Still nice though. Probably hike to Mystic lake soon even. Rivers aren't swollen here yet. Rising. But not raging. We are bracing for some serious run off this year.
  16. Apr 20, 2018 at 2:33 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
  17. Apr 20, 2018 at 2:40 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
  18. Apr 20, 2018 at 2:41 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    Ah ok. Enjoy! Why not take the green machine?
  19. Apr 20, 2018 at 2:41 PM
    Speedytech7
    Nah, he turned it into a real truck, see he replaced the recycled water bottle bed with a flatbed.
  20. Apr 20, 2018 at 2:50 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    Show me people that have problems with the original bed lol
