Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jul 25, 2018 at 6:55 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I'm just going to take it with me everywhere and take a selfie wearing it in cool weird spots haha
  2. Jul 25, 2018 at 6:55 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    The bolts/spacers that @turbodb shows are the ones we ship/install with our skids. I chose a bit different design style for the skid and have our IFS match up to the bottom of our bumper for a more smooth skid transition, but place out mounting bracket on the bumper in a similar location to stock for compatibility of most skids, hence the reason for the long bolts/spacers with our skid.
    Whether or not you need them is probably based on the design of the plate you are mounting, if it has a vertical lip and bolts up tight to the factory front skid cross member then you should only need short/factory length bolts(like the ones we include with the bumper when shipped). We do up the bolt/nut size to an M10-1.25 from the factory M8-1.25 that are stock, hence our reason for including new bolts. The OE skid holes are large enough for an M10, and we prefer running the larger hardware there on the skid.
  3. Jul 25, 2018 at 6:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Awesome. Thanks for the info Eric. I'm trying to extract a bolt from the rear mount so not sure if it lines up. I like the bigger bolts though, nice touch. Hopefully have it mounted tomorrow
  4. Jul 25, 2018 at 7:11 PM
    Explor
    Explor Don’t take the trip ... let the trip take you
    Northampton County Pa.
    FUN
    TRD valve stem caps , A Chimney & Back up camera. , Cooper STMaxx 255/80/17, SCS Dark Bronze wheels, , bed matt, weathertech floor liners and bug deflector , flyzeyez dash and glove box light , Best Top supertop, Brute Force Sliders , Bumpers ,KC back up lights, vent shades, tinting, superwinch 9.5 , Factor 55 winch thimble , KC ditch lights , BAMF IFS skid plates , Tepui Ruggedized RTT , Awning , Bed light kit , Hood Struts , Camburg UCAs ,Bud built gas skid , all pro differential skid , cbi jerry can holder , 15lb CO2 Tank , URD short shift , Defined engineering shackle bolt crossmember, Clazzio seat covers , 4:56 Nitro gears , ARB rear locker, CMKA12 compressor. Super Bump Stops, Bushwacker Flares , CBI bed rack , king resi front 700# , OME Dakar, Bilstein 6100's 10" light bar diode dynamics , AV monster fogs , TC bed reinforcement brackets , TC spindle gussets w swaybar Yeasue Ham , cb
    Where has Marks Puffy been thread !
  5. Jul 25, 2018 at 7:31 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    This is a great idea
  6. Jul 25, 2018 at 8:40 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Welcome to adulting :). It won't be long before you're asking @Digiratus :)luvya:) where to get a step stool to setup your tent. hahahahahaha
    Blackdawg[QUOTED][OP] likes this.
  7. Jul 25, 2018 at 8:50 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    A true sign of domestication. Pretty soon your nuts will stop working.
    :mad:
    :rolleyes:
    BossFoss and m3bassman[QUOTED] like this.
  8. Jul 25, 2018 at 9:00 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Blackdawg[OP] likes this.
  9. Jul 25, 2018 at 9:10 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ha! No doubt. Still a kid though. I still spend way to much time dreaming up truck mods and audio gear purchases...
    Can't say Im nearing that. Never owned a LG appliance and only have these by shear luck. Only criteria I needed to fulfill was stack-able, which these are either stack-able or side by side but came with the stacking kit. Just worked out with these. 320 bucks for both isn't expensive in my book haha
    HA!
    Fuck not. My nuts work great :laugh:
    Speedytech7 likes this.
  10. Jul 25, 2018 at 9:25 PM
    Speedytech7
    Just go full tilt, Miêle appliances cannot be beat! Or subzero if you need a nice fridge, and Viking for a man's cooktop. Why do I know so many appliance brandshelpimgettingold
  11. Jul 25, 2018 at 9:29 PM
    Speedytech7
    Middle class is still a thing? I'm just poor haha
    I'll probably never buy super nice appliances, cooktop is the only one I'd want really nice. I hate electric coil tops and induction tops, need to be gas.
    BossFoss likes this.
  12. Jul 25, 2018 at 9:33 PM
    Speedytech7
    I do this too, but my bank statements always straightens me back out haha. Just know that it doesn't matter to your friends. :)
  13. Jul 25, 2018 at 9:40 PM
    Digiratus
    Roaming the PNW
    The RedHead
    If you have money in your pocket and food in your fridge, you're definitely not at the bottom.
  14. Jul 25, 2018 at 10:08 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    ...mmm hmm. Says the guy who's now looking for shade over his kitchen... :devil:
    (though, I guess I do too, if I'm honest)
  15. Jul 25, 2018 at 10:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    can't blame him there. I had that once. Was freaking sweet.
    Digiratus and turbodb[QUOTED] like this.
  16. Jul 26, 2018 at 6:19 AM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    It's crazy how many people just throw away broken appliances. They are easier than ever to fix, with youtube how-to videos and the ability to order any parts you want online.
  17. Jul 26, 2018 at 7:36 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah i looked at a video and it wasn't even the same model and was like...holy crap thats easy. And mine was even simpler to take apart than the one I saw. Was super easy. like 15 screws total maybe. Need to just move it in the house now and I need to wire the drier up for a 3 prong 220 instead of a 4.
  18. Jul 26, 2018 at 7:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Dan what did you do with the tow hook in the frame? My bolts wouldn't suck up to the hamper by a very large gap. Not the hook blocks my skid plate.
    That and the front lip is too thick...gonna be a long day of grinding.
  19. Jul 26, 2018 at 7:20 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I had to use a band saw to cut off about 1/2" of that lip on my BBs.
  20. Jul 26, 2018 at 7:44 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah had to do the same on mine.
    Doing the same here too. Though not near that much, maybe 3/16'' total. Of course I have like 1'' left and my cut off wheel is gone now haha have to wait till tomorrow. Fine with me. Don't like the bolts he sent, bit torqux head bolts. Rather have normal bolts.
