Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jul 27, 2018 at 11:38 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I need to put a backup camera on my truck.
    I can't see shit out of the back of my truck between the seat bolsters and the GFC.
    m3bassman and Speedytech7 like this.
  2. Jul 27, 2018 at 1:30 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I put a front and rear dashcam system on mine, it covers the stock rearview. Kinda nice because i can have the rear camera on in the rearview all the time if I want.
  3. Jul 28, 2018 at 10:34 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Finally finished!! Took WAAAAAY longer than expected.
  4. Jul 29, 2018 at 7:42 AM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Those bullet cases pressed into the wood? Hard to tell from the photo.
  5. Jul 29, 2018 at 7:22 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Just go back from Goose Lake. Fuckin hell that place is so great.
    SconnieHailer and Digiratus like this.
  6. Jul 29, 2018 at 8:45 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Did you camp below the lake? Did it rain on you?
  7. Jul 29, 2018 at 8:52 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    we made it to the lake no problem. Thought we wouldn't be alone but somehow were. LOTs of people on the trail. More than normal but was saturday..Was a group of 4 with land cruisers 4runner and a range rover. they ALL had trailers :laugh: We met them at the "big" obstacle, they had left the trailers further back and just ran up to the lake. Water is high as hell. Still a lot of snow in the area.
    We got super lucky with rain. It rained twice shortly at night. Pretty much it. Was still cloudy when it go dark though. We hiked around the entire lake as well today. Insane views. I took almost 400 photos. Hoping i have tuesday off so I can do those. Hit up all the nice look outs as well after the trail, Fisher Peak has a big drift right at the fork, not passable at this time. Should be in a few weeks though.
  8. Jul 29, 2018 at 9:05 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :jellydance: Sounds awesome.
  9. Jul 29, 2018 at 10:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    it was. Super great up there. mosquitoes were biblical bad though.
    Speedytech7 likes this.
  10. Jul 30, 2018 at 11:55 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Naw, just brass wood screws, which I found out, spin and snap in half at the slightest bit of resistance from the wood. I had to drill pilot holes, pre screw them with stainless, then I could put in the brass screws
  11. Jul 31, 2018 at 6:02 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  12. Jul 31, 2018 at 8:48 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Monte, help to understand what I a looking at here. I understand they are stock length for a 1st gen. But whats not clear is how they will mount to the frame. I see what looks like poly bushings and sleeves, similar to what is used in aftermarket UCAs. But I don't see how the OEM cam adjusters will work with those.
    Also, the ad doesn't say it but is it correct to assume they were designed to use the OEM LBJ?
  13. Jul 31, 2018 at 10:09 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah all poly bushing. Oem lbj unless you run solos spindles.
    Uses sleeves so not really sure myself. I'd assume you used the stock bolts and the cams but not the oem sleeves? Not sure really. I don't have them :p
  14. Jul 31, 2018 at 10:14 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, definitely not clear how that would work. :notsure:
  15. Jul 31, 2018 at 10:17 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    They have photos of it mounted. But I don't know anyone with them. Brand new and all. On Instagram it looked like a bunch of folks were interested.
    I'm bummed the secondary mounted didn't make it. Might as well do the white line bushings and the TC kit
  16. Jul 31, 2018 at 10:20 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, so far I don't see the advantage of these.
  17. Jul 31, 2018 at 10:25 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    cool factor I suppose. Potentially more travel, but I still think the UCA is the limiting factor though, and even then the LBJ will be.
  18. Jul 31, 2018 at 10:30 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I noticed that the OEM LCA bushing were limiting mine. By going to the whitelines at least a full inch of down travel was added. Maybe even a little more.
    It was funny, after installing them, we had to jack up the front to be able to get the front wheels back on. :rofl:
    Blackdawg[QUOTED][OP] likes this.
  19. Jul 31, 2018 at 10:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah I think I might go that route. The fact you can add a hydro front bump on the Solo arms is tempting...but not really. You be riding in the bumps so much I would suck to tune.
    I think with either the Superbumper or the Plastic Guys ones plus secondary double bypasses with extended CO, UCAs and the Whitelines. Be a killer setup.
    though part of me is just going...just get LT again..haha
  20. Jul 31, 2018 at 10:37 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I have all that except a secondary double bypass shock. What all is involved with mounting one of those? Sounds expensive. :oops:
