Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Aug 2, 2018 at 9:22 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I had to switch to Verizon, so far I've been very happy and no more damn data caps!
  2. Aug 2, 2018 at 9:23 PM
    Speedytech7
    Or on long rides in the middle of NV, or really any highway or road that isnt in the middle of a big metro area
  3. Aug 2, 2018 at 9:23 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Can't be any worse that sprint.
    Speedytech7[QUOTED] likes this.
  4. Aug 2, 2018 at 9:25 PM
    Speedytech7
    Sprint can hardly be considered a service anymore... It's a disservice. Like seriously... It might be better than Metro PCS from a status point of view haha
    Digiratus[QUOTED] likes this.
  5. Aug 2, 2018 at 9:27 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The only thing that matters is from a dropped call and data connection point of view.
  6. Aug 2, 2018 at 9:33 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    well..sorta. They slow it down after a certain amount depending on your plan
  7. Aug 2, 2018 at 9:34 PM
    Speedytech7
    They're the only two remaining CDMA networks so the merger makes sense, hopefully they update the sprint towers and make Verizon even better than the best. I didn't have issues when I drove through NV after meeting with you guys a couple months ago, but I probably took another path. I went through the center of the state haha
  8. Aug 2, 2018 at 9:35 PM
    Speedytech7
    Business unlimited, no caps, no throttling threshold. I can pull down 107Mbps in my living room on data, it's amazing
    Blackdawg[QUOTED][OP] likes this.
  9. Aug 2, 2018 at 9:43 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I've seen 100Mbs down at work with my Verizon service. It helps there is a tower on the far corner of our building tho.
  10. Aug 2, 2018 at 9:45 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Nice. IDK what I can hit. Still on a true unlimited grandfathered plan
  11. Aug 2, 2018 at 9:45 PM
    Digiratus
    Roaming the PNW
    The RedHead
    This is true. I have an 'unlimited' plan but they will begin throttling after 15GB in a billing cycle. I never even get close to that tho. Usually 6-7GB/month.
  12. Aug 3, 2018 at 7:39 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    You took the doors off the Durango? That has to be the ugliest vehicle in all of boise right now
    BossFoss likes this.
  13. Aug 3, 2018 at 9:12 AM
    Digiratus
    Roaming the PNW
    The RedHead
    :laughing:
  14. Aug 3, 2018 at 4:02 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Hah hence why mine come off, it’s a blast
  15. Aug 4, 2018 at 7:11 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Huh. That’s pretty sweet
  16. Aug 4, 2018 at 7:47 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    02 Toyota Tacoma TRD "El Brah-co"
    Toytec BOSS with Dakars
    C19CDF49-9B7E-4FCD-92D7-E082B35DA480.jpg Good times:rolleyes:
    BossFoss and Digiratus like this.
  17. Aug 4, 2018 at 8:32 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Looks like the kind of fun @turbodb might be having next weekend. :p
    turbodb likes this.
  18. Aug 4, 2018 at 9:04 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ouch. Hopefully you weren't driving..
    What? Why?
  19. Aug 4, 2018 at 9:08 PM
    Speedytech7
    They're gonna pop his BJ cherry... couldn't resist :p
    He still has his stockers
    Digiratus likes this.
  20. Aug 4, 2018 at 9:16 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ah gotcha
