Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Aug 16, 2018 at 7:49 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    :gossip: those are the stock mounts.
  2. Aug 16, 2018 at 8:09 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    BCN doesn't care, it imports both. KMZ is just a zip of the KML, so it compresses the text to make for a smaller file. I tend to use KML since it means I can hand edit with a text editor, and there's less likelihood of zip corruption (i.e. one more thing to go wrong).
    But really, it doesn't matter. And zip corruption never happens. All Office files that have a 4 letter extension (DOCX, XLSX, PPTX, etc.) are also all zip compressed (for the same reason).
    Edit: KMZ does have a little more functionality (that we don't currently use) - you can embed custom images, waypoint markers, etc. in the file; and then they move around with your map. But, I don't think BCN understands those; they'd just be used when another GE user opened the KMZ.
    Speedytech7 likes this.
  3. Aug 16, 2018 at 8:47 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I see that both options are available when I do the Save As.
  4. Aug 16, 2018 at 8:53 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Yes... so? (sorry, I don't follow the point you're trying to make or question you're trying to ask :confused:)
  5. Aug 16, 2018 at 9:09 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    well you can take photos with your device and save it to the tack and such. maybe thats why.
    I use KML Mike.
  6. Aug 16, 2018 at 9:14 PM
    Digiratus
    Roaming the PNW
    The RedHead
    haha, I was channeling one of my customers. :rofl:
    I noticed that the one you created for GC and the ones Monte did last last were .KMLs. I guess I thought there would be more compelling reasons. I think I a going to leave it as .kmz and see if BCN is happy.
  7. Aug 16, 2018 at 9:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I just don't like compressed files haha
  8. Aug 17, 2018 at 6:56 AM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
  9. Aug 17, 2018 at 8:01 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah I'd believe it. The early VW diesels got like 70mpg.
    m3bassman likes this.
  10. Aug 17, 2018 at 8:40 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    You definitely drive more causual with it. It's not bad around the daily life. But offroad I find it infuriating a lot of the time.
    Igor got 18-22 till I out the bumper on. Areo dynamics makes a big difference.
    Ect doesn't do shit haha changes shifting is all.
  11. Aug 17, 2018 at 8:50 AM
    Digiratus
    Roaming the PNW
    The RedHead
  12. Aug 17, 2018 at 9:02 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It have different gears?
    Offroad in 4lo it shifts super hard. Never in the gear I want. Slow to shift. And you can only go 20-25 in 4lo.
    45 is the sweet spot. Got 23 once out if Frank doing most 45-55
    m3bassman[QUOTED] likes this.
  13. Aug 17, 2018 at 11:04 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah makes sense. 4runners had way more gear options through the year. 4.56 and even 4.88s.
    Use the gear code thing. Should tell you right away. I have a document.
  14. Aug 17, 2018 at 11:09 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
  15. Aug 17, 2018 at 12:08 PM
    Squeaky Penguin
    Brett
    Ah. That's the factory lower mount, but not upper.
    That's going to rub hard when flexed out, probably hit that mount too.
  16. Aug 17, 2018 at 12:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    What Brett said. Not a OEM upper mount.
    4runner rear shocks setup is a PITA to setup. You'll likely rub for sure.
  17. Aug 17, 2018 at 12:55 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I mean...do you plan on offroading it? 3/4'' spacers might be good.
  18. Aug 17, 2018 at 1:09 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    fair enough haha
  19. Aug 17, 2018 at 1:44 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    one cost 40k
    the other cost 5k
    haha just sayin! cheaper mods too..and the RTT will work super good on the SUV...plus has better suspension than both the trucks..
  20. Aug 17, 2018 at 2:06 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Eh. I don't see the need to start from scratch on that truck. Its modded but not like beyond. Plus most that shit you'd do yourself anyways and save money getting it with the truck.
    Why would you want 2 4runners?
