Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Sep 11, 2018 at 9:21 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    There's a dot on the crank pulley that arrow is pointing to.
  2. Sep 11, 2018 at 9:26 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    What he said, start left and work it to the right and get all the slack to the tensioner
  3. Sep 11, 2018 at 9:29 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    I've always pulled the PS and AC to the side and removed the AC bracket to get to that bolt. How did you get in there?
  4. Sep 11, 2018 at 9:32 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    No sarcasm at all. Simply my decades of experience observing human behavior.
    m3bassman[QUOTED] likes this.
  5. Sep 11, 2018 at 9:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    fuck I thought I had a photo of it. Its a small dot on the crank pulley. Do the tensioner LAST next time as well. Makes lining up everything much much easier. Then just push in the tensioner and use the mounting bolts to suck it down. IDK why everyone trys it the other way. I laughed at that step in the video. Though in Timmy's defense he corrected himself in a 2nd video.
    Cool cool. Wow sorted already?
    Meh, i did like 10 haha Like I said, brain dead from work these past days. also getting a cold. Doesn't help so not super motivated to do much of anything. I will get this done before AZ though!
  6. Sep 11, 2018 at 9:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  7. Sep 11, 2018 at 9:49 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Looks like non OEM parts to me
  8. Sep 11, 2018 at 9:50 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The one on the right is not a Toyota t-stat.
  9. Sep 11, 2018 at 9:55 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Only little guys can do it. :rolleyes:
    [​IMG]IMG_4842 by mike digirat, on Flickr
  10. Sep 12, 2018 at 11:24 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Started reading through the pelfrey thread...Holy crap what a colossal clusterfuck
    m3bassman likes this.
  11. Sep 12, 2018 at 3:48 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah. Shitty deal.
  12. Sep 12, 2018 at 5:54 PM
    Squeaky Penguin
    Brett
    Nice work Ben!
    Not as bad as thought it might be?
  13. Sep 12, 2018 at 8:03 PM
    Squeaky Penguin
    Brett
    I don't recall that bolt, but I do remember pulling the AC compressor and mount and PS pump completely off when I did mine. Not sure why exactly I did that, but must have made it a little easier to work on the TB.
    BossFoss likes this.
  14. Sep 13, 2018 at 11:33 AM
    Digiratus
    Roaming the PNW
    The RedHead
    my at dipstick is a bit contorted and does not go in smoothly. I think it's normal. Certainly not straight and easy like the oil dipstick.
  15. Sep 13, 2018 at 7:50 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    @drr where did you get your lights from again? I looked and think the Q series Hyper/driver combo will work great for me. Bit bigger than the ones you put on.
  16. Sep 13, 2018 at 8:06 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Damn, those Q series are beastly. Pretty similar light output to the D-XL Pro Hyperspots though, which are the ones I got
    https://www.rigidindustries.com/d-xl-pro-dually-xl.html#
    Bought them on group buy through mrtmotorsports.net at 30% off, and Rigid was having a $50 rebate deal at the same time. Brought it down to about $330.
    I might go with the regular Spot pattern if I were to get them again.
  17. Sep 13, 2018 at 8:10 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I think the driving(45º)and Hypershot will be about perfect.
    Kind kind of see here:
    https://youtu.be/U0f2_u1LHf0?t=45s
    With the ditch lights added in should make for a great deer spotting combo, which is what Im after haha
    You can't get the XL pro is a combo pattern either..so the advantage goes to the Q series there.
    drr[QUOTED] likes this.
  18. Sep 13, 2018 at 9:44 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    turbodb and m3bassman like this.
  19. Sep 13, 2018 at 10:28 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah they look like a great all-in-one light. It'll be interesting to put them side by side and see the difference. The lights in my bumper are D2 driving lights, so theoretically it should be a similar light output with both sets on.
    Blackdawg[QUOTED][OP] likes this.
  20. Sep 13, 2018 at 10:33 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Indeed! Going to try and get some quotes soon. Still think I'll do Amber Squadrons in the bumper for fog lights. Should be okay for me up front anyways.
