Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Sep 19, 2018 at 10:04 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Ah that would make sense.
    I thought I had ben read the code a while back too but I don't remember where that lead.
  2. Sep 20, 2018 at 8:41 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    In 2006, when I was shopping for a 4x4, I drove a low mileage '01 T4R with a v6 and an auto.
    Compared to the extracab TRD trucks I had been looking at, the runner was kind of a pig. Certainly not as quick. I can't recall how it was equipped locker wise and no idea on the gear ratio, but at the time I assumed what I was feeling partially due to the weight differences between the two types of vehicles.
    I also remember noting that the Toyota horsepower spec for the v6 in the runner was less than the one in the trucks. 190 vs 180/185 IIRC.
  3. Sep 20, 2018 at 9:04 AM
    Digiratus
    Roaming the PNW
    The RedHead
    I'm pretty sure the HP rating was in the paperwork (original sticker, etc.) that came with that vehicle. It also seems like I have seen the same thing elsewhere in other documentation.
    However, it has been a long time and my recollection might be in error.
  4. Sep 20, 2018 at 9:25 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    that helps.
    did you mean 96? no 2006? because...in 2006 the 4runners had the 4.0l. Which had 235hp at that time. And actually eventually more than the tacoma, 10hp more. Or the sweet 2uzfe v8 :cool:
    Every 3rd gen i've driven is nice, just like a taco yet not. I did not like the wiggle from the 3link though over big bumps. Got bad on grants especially lifted.
    4th gen should be good i think. Especially with the v8. I drove a 5th gen though and it was a total pig. But its the biggest 4runner ever made too..
  5. Sep 20, 2018 at 9:38 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, I know, reading comprehension can be hard... and is a lost art. :luvya:
    Another diff I noticed at the time was seating position. Hard to explain but the seat in the truck seemed to be more upright or higher in relation to the view out the window and over the steering wheel.
    Essentially, all of these things I've mentioned ended up turning me off on the one I drove.
    m3bassman[QUOTED] likes this.
  6. Sep 20, 2018 at 9:46 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    That does probably help. The wheel base I thought was the same, just the body was shorter?
  7. Sep 20, 2018 at 10:20 AM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Interesting, I always thought the 4runner was on a truck frame. Good to know
  8. Sep 20, 2018 at 10:34 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Any info on the wheelbase length of the 1st gen single cabs? Seem like a 4 runner is closer to that.
  9. Sep 20, 2018 at 10:42 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Huh interesting. Seemingly ringing a tiny bell back in my head somewhere about the single cab wheel base.
  10. Sep 20, 2018 at 6:58 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    welp bought a new 18-135 for 300 shipped. Not bad. $500 in camera lenses..sheesh.
  11. Sep 20, 2018 at 7:26 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    @Blackdawg
    You ever take the Gros Ventre Rd in Bridger National Forest?
  12. Sep 20, 2018 at 7:32 PM
    STLegend
    STLegend Well-Known Member
    '13 TRD OR
    OME, DX4, S/T Maxx, Bushwackers, A.R.E Shell, Yakima Racks
    I typically go down there a couple times each summer
  13. Sep 20, 2018 at 7:35 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    You go all the way through to union pass when you go? Just looking to see if it dead ends or if the forest service rd at the end is passable.
  14. Sep 20, 2018 at 7:58 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I have not. Though I've been on Union Pass. Watch the Eclipse from there.
  15. Sep 20, 2018 at 8:04 PM
    STLegend
    '13 TRD OR
    I can't say for certain, I want to say one of the times there was a gate. But hey bring a bolt cutter and a spare lock and you're golden.
    I will certainly be checking though.
  16. Sep 20, 2018 at 8:11 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    looks like the road goes a ways but has a big fence. Goes by a few houses.
    https://www.google.com/maps/place/G...b185c22018dd1!8m2!3d43.5923774!4d-110.3837857
    Looks like you could go around the fence pretty easy though. However, the road just disappears after a bit. Also looks like a lot of deadfall across the road.
    BossFoss[QUOTED] likes this.
  17. Sep 20, 2018 at 8:52 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Thanks, I will compare it to the wyo atlas I have and see if I can find a way through so I can make a loop
    Blackdawg[QUOTED][OP] likes this.
  18. Sep 21, 2018 at 9:19 AM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    02 Toyota Tacoma TRD "El Brah-co"
    Toytec BOSS with Dakars
    The road goes through all the way, both past goose wing and cow creek towards the Darwin ranch, there are closure gates on both though:rolleyes:, both are open to snow machines during the winter though
  19. Sep 21, 2018 at 9:38 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well that's weird.
  20. Sep 21, 2018 at 9:56 AM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    A lot of the usfs roads from Jackson to Dubois interconnect in lots of places, but they keep on putting up closure gates because apparently they hate us. They all show up on ORV maps as “Jeep trails.”
