Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Oct 19, 2018 at 8:16 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    oh i thought you had a 2 for some reason..
    Might go for a 2 then. Will last a little longer i think than a 1
  2. Oct 19, 2018 at 8:17 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    I went and played with a 2 when they came out, didn't like two things: 1. build quality seemed cheaper in my hand. 2. No headphone jack (I think you have to use wireless, or get a USB-C headphone...which then means no headphone+charge at same time)
    But, by all means, check them all out and get the one you like the price/perf point of.
  3. Oct 19, 2018 at 8:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    hm well..that's stupid. What is with that fad? Headphone jacks disappearing and shit.
  4. Oct 19, 2018 at 8:26 PM
    INBONESTRYKER
    INBONESTRYKER Well-Known Member
    WY
    '96 access cab 3.4 5 spd manual 4X4
    I have the S2, it has a headphone jack. Being retired and living in a weak signal (Verizon, any other provider would be the same) calls in/out once in awhile, text is a little better. A new phone wouldn't make much difference. Mostly use apps anyway.
  5. Oct 19, 2018 at 8:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I had an s3 for ever. Im the same way. Really don't use a lot of apps. Few things i use at work now though that are handy here and there.
    Where i work I dont even have cell service haha just wifi.
    Bluetooth sucks donkey dick. Its bitrate is depressing for audio. I never use my phone for that though so whatever.
  6. Oct 19, 2018 at 8:55 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I did see...
    turbodb likes this.
  7. Oct 19, 2018 at 9:04 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    see what?
  8. Oct 19, 2018 at 9:07 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    might order some new bushings while you're there.
    Just need a shorter bolt. I don't remember what the length is.
    m3bassman[QUOTED] likes this.
  9. Oct 19, 2018 at 9:12 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Did you win any money?
    I’m sure if you won a larger amount you wouldn’t tell (I wouldn’t).
    I forgot I was old enough to buy a ticket, and my cousin won 8$.
  10. Oct 19, 2018 at 9:13 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The diff bushings? Super easy. Plasticguy sells them.
    Why are you taking the rear axle off?
    Fuck yeah I'd tell haha
    Sadly no, I didn't even win $2 ha
    JKO1998[QUOTED] likes this.
  11. Oct 19, 2018 at 9:15 PM
    JKO1998
    Utah
    I’d tell after I get my ticket turned in or whatever.
    Wish I woulda bought on in Mountview on my way home yesterday, I stopped there anyway.... fckn Utah.
  12. Oct 19, 2018 at 9:16 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    lg v30 is worth a look 32bit DAC on board and USB-C so you get a real headphone jack and charge support
    Blackdawg[QUOTED][OP] likes this.
  13. Oct 19, 2018 at 9:17 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    You sure you can do that and they aren't too long?
  14. Oct 19, 2018 at 9:27 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well i think most of the 2.0 icons like that are a 9.125'' shock. Should be okay with the lift you have. I think. But no idea.
    And...why aren't you just undoing the lower mount and letting the shock fall out? haha thats how I do all rear shocks..
  15. Oct 19, 2018 at 9:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    For that situation I do this, well, I have to now on Frank no matter what especially for the front.
    Jack the truck up and take the wheels off, for the rear jack it up from the diff. then lower it down to a safer height for the jack stands. I like putting mine on two 6x6s and at the lowest setting. Usually the hubs end up just up off the ground a few inches. Granted that LT..but I do the same for the rear.
    Was surprising to rotate the tires on the little truck and have the frame normal height. Didn't need the 6x6s haha
  16. Oct 19, 2018 at 11:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yes i know. You forget Grant has a 4runner and I've done the suspension on it twice now.
    It works just fine doing it that way with the runner too. How we swapped springs.
  17. Oct 20, 2018 at 10:29 AM
    Digiratus
    Roaming the PNW
    The RedHead
    What you did there. :rolleyes:
    I still have my original bolts around here somewhere if you want them. This assumes they are the same on a tacoma and a 4runner.
  18. Oct 20, 2018 at 1:28 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I look for them when I get home.
  19. Oct 20, 2018 at 2:08 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I also forgot but a simple way to reverse the drop is to just put the spacers up on top of the crossmember ha
  20. Oct 20, 2018 at 4:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Dan, what did you say our collapsed length was with the new rear ADS shocks? @turbodb
    JKO1998 likes this.
