Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Nov 12, 2018 at 9:54 AM
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    Yeah that's a bummer. Always hard to watch them leave.
    PcBuilder14[QUOTED] likes this.
  2. Nov 12, 2018 at 1:17 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    If it was cavitating you should be able to see the bubbles.
    If you confident it's still coming from the pump, probably means your pump is done for. Sounds pretty similar to what mine sounded like when it died in AZ last year, except I had to listen to it constantly for the entire drive back.
  3. Nov 12, 2018 at 1:18 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Is the fan pulley bearing and water pump two separate assemblies on the 5VZ, which one do you think it is?
  4. Nov 12, 2018 at 1:24 PM
    Speedytech7
    Sucks if it sends shrapnel into the rack and kills the fluid actuator and seals though
  5. Nov 12, 2018 at 1:25 PM
    Squeaky Penguin
    Brett
    Yes, two separate parts.
    The fan rides on a hub that is mounted to part of the TB cover. Never heard of one of those bearings failing though. :notsure:
    Can't hurt to clean the reservoir and flush it. It'll cost you an hour and a quart of ATF. You can pull the reservoir off without removing the pump.
    I'll caution you towards reman pumps - I didn't have good luck with them. Little over $300 for an OEM pump and I'm now happy with how everything it working.
  6. Nov 12, 2018 at 3:03 PM
    INBONESTRYKER
    INBONESTRYKER Well-Known Member
    WY
    '96 access cab 3.4 5 spd manual 4X4
    Words you should never say!
  7. Nov 12, 2018 at 4:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Lol just find a guy on here doing a part out. Actually I bet Brett has one..
  8. Nov 12, 2018 at 4:36 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Negative, it went into the 4Runner I sold
    Blackdawg[QUOTED][OP] likes this.
  9. Nov 12, 2018 at 4:43 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oh i thought the box as for the 4runner? We talking about the taco?
    Wrong MAF location? must have been a 95-97. Anything after that I believe is the newer MAF sensor.
    Relay could be dead even if its clicking. Get the volt meter out. Then try hard wiring a light to the battery. 100w Halogen bulbs don't last a super long time though so keep that in mind. Could try and find an LED bulb that fits it or retro HIDs too which is what I'd do.
  10. Nov 12, 2018 at 4:44 PM
    Speedytech7
    The likelihood that I'll be selling my Taco in the coming months is very high, so if anybody knows someone else that may be interested feel free to give em my info. 5-6k is what I'll be looking for. I can't and won't take it with me back to WA come August. My move back there is going to be a hail Mary attempt at getting my life back on track as is and I don't forsee having the time to use it. Everything works but the AC, you all know what's on it, won't be gaining any significant miles for the next 6 months.
  11. Nov 12, 2018 at 4:47 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :pout:
    Then how are you going to come wheeling with us?????
  12. Nov 12, 2018 at 4:48 PM
    Speedytech7
    There will come a time when I'll build another for the tough stuff, until then I'm going to put a few bucks toward making the cruiser handle milder stuff cause I like y'all so much :)
  13. Nov 12, 2018 at 4:53 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Did i update my internet family that im not at JHMR anymore? lol
  14. Nov 12, 2018 at 4:55 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    You can buy my 99 when the time comes. It’s pristine
  15. Nov 12, 2018 at 5:04 PM
    Speedytech7
    Tent I'm keeping for the cruiser, and the hi lift. Everything else I'm leaving as is.
    m3bassman[QUOTED] likes this.
  16. Nov 12, 2018 at 5:45 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    02 Toyota Tacoma TRD "El Brah-co"
    Toytec BOSS with Dakars
    Aftermarket Napa PS pump in my Tacoma has whined like a bitch when it’s cold from day one. Has always leaked a little as a bonus, whine always goes away after it warms up, been going a couple of years like that.
  17. Nov 12, 2018 at 5:46 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    DAT ski pass doh...
  18. Nov 12, 2018 at 6:59 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    All I heard in your video was a super metallic cognitive dissonance:cool:, but if you’re hearing a whine that’s congruent with inop power steering, that’s exactly what I had.
  19. Nov 12, 2018 at 8:40 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    A093EC1C-EB40-415C-9AD3-90CAFC091A41.jpg Somebody was confused...
  20. Nov 12, 2018 at 9:01 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Or upgraded. :crapstorm:
    Pltmnky[QUOTED] likes this.
