Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Nov 27, 2018 at 2:34 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    I see you two trying to peer-pressure a delay :p.
    Can't be too soon when it's 3 months after the trip. Plus, what better time to relive this amazing adventure than when it's cold and wet out anyway? Enjoy it, and post your own 'cause I wanna see them, as does everyone else I'm sure! :)
    :thumbsup:
  2. Nov 27, 2018 at 2:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Cold and wet? Its not that cold here :p coming Im sure..
    I don't really mind. Does still feel like it just happened to me though in a way haha
    turbodb[QUOTED] likes this.
  3. Nov 27, 2018 at 2:36 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    The pink bar is supposed to float to let you know when it's getting full, mine gets stuck tho. Also how did you switch boxes the mafs are different and incompatible with each other
  4. Nov 27, 2018 at 2:37 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Actually, it now feels like the pressure to get them done is off since you doing the thread without them.
    turbodb[QUOTED] and Speedytech7 like this.
  5. Nov 27, 2018 at 2:39 PM
    Speedytech7
    I live without photo pressure :D
    turbodb likes this.
  6. Nov 27, 2018 at 2:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    pressure is still there for me :boink: I won't do a write up without all the photos.
    Digiratus[QUOTED] likes this.
  7. Nov 27, 2018 at 2:47 PM
    Digiratus
    Roaming the PNW
    The RedHead
    As it should be.
  8. Nov 27, 2018 at 10:45 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Nice little single cab. :D
    Blackdawg[OP] likes this.
  9. Nov 27, 2018 at 10:46 PM
    Speedytech7
    With a Honda K24, that's fuckin rad!
  10. Nov 28, 2018 at 5:57 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
  11. Nov 28, 2018 at 6:26 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
  12. Nov 28, 2018 at 6:35 AM
    JKO1998
    Utah
    It’s like a mini rtt, kinda
  13. Nov 28, 2018 at 7:33 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    did you try removing the belt and starting it? Does it have AC?
  14. Nov 28, 2018 at 7:37 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah saw in daily.
    Sounds like a vac leak to me or something is loose.
    Id check you MAF as Zane mentioned they didn't line up right potentially.
    It's either that or a fully spun bearing somewhere.
  15. Nov 28, 2018 at 4:03 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  16. Nov 28, 2018 at 5:04 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    They are bright. Wish I'd gotten the yellower ones though..
  17. Nov 28, 2018 at 5:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well definitely only needed one for the work bench. However it not having a shield sucked.
    Thankful I hadn't thrown this out yet.
    Old florescent light that was on the bench when I got it.
    These things are a lot smaller
    Removed the shield and drilled some holes. Mounted it up again
    Works good and doesn't blind me now
    Now for the garage
  18. Nov 28, 2018 at 6:42 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Lights off camera flash
    Garage door lights
    New lights
    Forgot to buy cable hangers.
    Pretty happy. Need to figure out something for the other half. Though it's not as important. If the lil trucj is in there fully the bay is well under the low ceiling part.
    m3bassman likes this.
  19. Nov 28, 2018 at 7:15 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Is it 1906 and heating is cheap? Where is your insulation?
  20. Nov 28, 2018 at 7:21 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yes probably. Old ass house. No insulation in the garage and no heat. late add on.
    Why I wont' be doing any big projects this winter.
    Did not need two. Puts out plenty of light and I have a small lamp for lighting things right in front of me.
