Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jan 15, 2019 at 8:46 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    I bought a Milwaukee battery one this year. Love it, makes greasing a breeze. It helped that I run Milwaukee tools and the battery investment was already there though I guess
    Pltmnky likes this.
  2. Jan 15, 2019 at 9:15 PM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    Get the 20v dewalt. Way better and they r phasing our the 18v
  3. Jan 15, 2019 at 9:18 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    You aren't supposed to use moly lube in ujoints though. Causes the surfaces to wipe across the needle bearings and flat spot them rather than let them roll and do their job
    @turbodb, to answer your question. I have 3 grease guns all with different greases in the
    turbodb and Digiratus like this.
  4. Jan 15, 2019 at 9:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    How so? Moly is less tacky then that red shit
  5. Jan 15, 2019 at 9:42 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I really like this idea. This unit is kind of pricey but I can see the value. And wow, a 4' hose would be awesome.
    https://www.homedepot.com/p/Milwauk...tteries-Charger-Hard-Case-2646-21CT/204064022
    I'm with Ben, hand held grease guns are a pain in the ass to use sometimes. I am not with Ben in not doing the necessary maintenanace in a timely manor because of that pita factor. :laugh:
    BossFoss[QUOTED] likes this.
  6. Jan 15, 2019 at 9:43 PM
    Speedytech7
    I don't care if you use red and tacky or not but if you look in your manual it specs non moly infused for the joints. In fact the only thing that requests it is your slip yoke because telescoping sliding motion is what it does. It's much like using GL5 in your trans it is too slippery. You'll just slowly flat spot the needles and put slop in your joint. The needles are supposed to have that taciness so they move along with the shaft in the joint. This is not something I came up with, you can look it up if you don't believe me or your shop/owners manual.
    Glenn_R likes this.
  7. Jan 15, 2019 at 9:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Cool good to know.
    Speedytech7[QUOTED] likes this.
  8. Jan 16, 2019 at 4:58 AM
    BossFoss
    Wyoming
    01 DC Tacoma
    The one I nabbed didn't have a case, battery or charger. Think it was like $130? You can buy just the flexible hose for any of the regular grease guns for a cheaper fix, that will make greasing easier too.
    Edit: https://www.amazon.com/Lumax-LX-120...ocphy=9029312&hvtargid=pla-568351618942&psc=1
    Edit2: also make a M12 version. Which would probably do fine if your just doing your truck. Then you could buy the M12 ratchet which is super handy.
    https://www.amazon.com/Milwaukee-24...ocphy=9029312&hvtargid=pla-571578816398&psc=1
    Digiratus[QUOTED] likes this.
  9. Jan 16, 2019 at 7:40 AM
    eltacoutah
    eltacoutah Well-Known Member
    Ben
    Utah
    2010 TRD Sport
    Hey guys, I'm planning a trip up to the Jackson hole area this summer. My brother and I both have tacomas and would like to hit a couple trails, as well as some fishing spots. We've never been up there, well, I did a scout trip up to Yellowstone but that was 15 years ago so I don't remember much. We'll be staying in the Driggs Idaho area for 4-5 days and one day we're planning on going up to Yellowstone with the family to see what they have up there. Any info would be awesome, nothing too crazy because we'll still need to drive home. Thanks for your time and info! :mudding:
  10. Jan 16, 2019 at 10:45 AM
    BossFoss
    Wyoming
    01 DC Tacoma
  11. Jan 16, 2019 at 10:49 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
  12. Jan 16, 2019 at 10:55 AM
    BossFoss
    Wyoming
    01 DC Tacoma
    Right. Wow talk about a markup
  13. Jan 16, 2019 at 10:58 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    total publicity stunt.
    Can't believe they did that though. Doubt they can even get their money back..although maybe. Is very low miles.
    Also god damn i hate Bring a Trailer..
    Speedytech7 likes this.
  14. Jan 16, 2019 at 12:36 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    02 Toyota Tacoma TRD "El Brah-co"
    Toytec BOSS with Dakars
    I’ve gone all in on the Milwaukee M18 bandwagon, have like 5 of the impact guns and maybe 12 of the other tools, a couple of m12 ratchets. Use to be a diehard Makita LXT loyalist, but for the price and quality, no one is doing it better than Milwaukee right now.
  15. Jan 16, 2019 at 1:01 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Pltmnky[QUOTED] likes this.
  16. Jan 16, 2019 at 1:06 PM
    Speedytech7
    If it is a big dealership it'll work out fine and one of the salespeople or the GM or something will buy it after someone gets screamed at for being so stupid as to purchase it as marketing materials. My job works closely with dealerships, this kinda stuff was out of someone's pocket there is no way this was approved in any capacity by Toyota.
  17. Jan 16, 2019 at 1:26 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    He has a fj80 in there right now and a brand new 2019 landcruiser for like 85k lol. Still changes full synthetic oil for cheap thankfully
  18. Jan 16, 2019 at 6:11 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Two steps forward, one step back today.
    When at first you don't succeed... :sawzall: and then take a step forward. (thanks @Speedytech7)
    Then, take an easy step forward. (thanks @Digiratus!)
    .... and then one step back. Apparently the bed rack is stronger than the bed. That's a vertical crack in the top rail through the hole, and a horizontal crack about 2-3" long along the rail edge - like the whole thing was pulled inwards (well, clearly it was...)
    Anyone else have any issues like this? Curious for ideas on how to prevent in the future... for now, I think some sheet metal welding is in store, then some sort of reinforcement along the back?
  19. Jan 16, 2019 at 6:17 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Good stuff. Welcome to beating on your shit all the time life haha
    Squeaky Penguin and Speedytech7 like this.
  20. Jan 16, 2019 at 6:18 PM
    Speedytech7
    I can't tell if that's a sarcastic thanks or not haha. Hope it all goes together smoothly again though :) As for the crack, I've never seen one crack there before. My bed bars help true up my bedsides, in fact without them the bedsides aren't quite vertical. But I don't know how you'd get a vertical tear like that. I don't see any reason you can't just drill the end of the crack and weld it. I do use 3/16 plates behind those rails where my bolts go through to avoid pinpointed stress.
    turbodb[QUOTED] likes this.
