Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jan 17, 2019 at 7:11 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I don’t see a problem, dogs aren’t picky.
    The way I have to set up now there aren’t any holes in the side.
    jubei likes this.
  2. Jan 17, 2019 at 7:26 PM
    JKO1998
    Utah
    How did it get to be that shape exactly?
  3. Jan 17, 2019 at 8:20 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    No complaints so far. They make doing an alignment yourself pretty easy, got me a little more clearance from the firewall, and will be super easy to swap the ball joint out if/when needed.
    I'm surprised you haven't done UCAs yet. What else are you doing on the front?
    jubei[QUOTED] likes this.
  4. Jan 17, 2019 at 8:21 PM
    JKO1998
    Utah
    The middles gone U
  5. Jan 17, 2019 at 8:31 PM
    JKO1998
    Utah
    This really isn’t worth the time trying to figure out but, I’ve dedicated this much time so.
    I don’t think you originally cut it like this:
    But I could be wrong
  6. Jan 17, 2019 at 8:33 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I am running that combo. I like it a lot. But I do like to go fast once in a while.
    That is a very good price. The Timbrens alone run about $200. Are you currently on the stock hockey pucks? These will be a lot taller and a lot softer.
    Do the plates on that used kit have threaded holes for bolting on the Timbrens?
    Ubolts for a flip:
    Justrom[QUOTED] likes this.
  7. Jan 17, 2019 at 8:38 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    It's a small poop shovel lol
  8. Jan 17, 2019 at 8:38 PM
    JKO1998
    Utah
    That’s weird that it ended up like that, looks like you took an old stone grinder to it
  9. Jan 17, 2019 at 9:52 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Ha! Just ordered a set for my mom to put on her Tacoma for when she is pulling her Casita. They look like they will get the job done.
  10. Jan 19, 2019 at 1:55 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    What did you get? And why 4G for the tablet and not just offline maps? Seems like you may not have reception when you're out anyway...plus you'd need another SIM.
    APRS config (step-by-step) is here: https://adventuretaco.com/where-are-you-adding-aprs-to-the-ham-radio-comms/
    ...and BCN config is here: https://adventuretaco.com/how-to-planning-a-trip-route-part-2-taking-the-gpx-on-the-road/
  11. Jan 19, 2019 at 2:07 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It's easy. Looks good though. I love mine there
    m3bassman[QUOTED] likes this.
  12. Jan 19, 2019 at 3:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Paint?
    And you just need to download the map files for aprs then navigate to them. You can do it by states only or the full country. I did the full country one but it does have the same detail. But never let me down.
  13. Jan 19, 2019 at 4:22 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Man, welding on the body sucks doesn't it?
  14. Jan 19, 2019 at 5:09 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Sure, but where's the fun in that? This was a new experience, and now I know.hiw to do it. Plus, I'll be drilling a couple new holes anyway just to spread the load.
  15. Jan 19, 2019 at 5:20 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Did you start by burning a hole through it that you then needed to fill? :p
    jubei likes this.
  16. Jan 19, 2019 at 5:58 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Who me? :anonymous:
    I can also vouch for the flammability of nearby factory paint. :bananadead:
  17. Jan 19, 2019 at 6:02 PM
    Squeaky Penguin
    Brett
    Sounds exactly like how my core support repairs have gone. :bananadead:
    m3bassman likes this.
  18. Jan 19, 2019 at 9:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    This why tubing suuuuucccckkkkksss
  19. Jan 19, 2019 at 10:11 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Tubbing. Of the firewall. That's what he means. Not round tubing. Though that would suck too if it were as thin as a body panel. ;)
  20. Jan 19, 2019 at 10:38 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah tubbing.
    And 35s make all the difference :cool:
