Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Feb 13, 2019 at 4:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Just blew the radiator in Igor. Cooked the motor good and pribprob the tranny too.
    Half way to home. Supposed to snow tonight.
    Still haven't put in the new fuel pump in the little truck which also needs a clutch.
    Great.
    I hate not having a shop
  2. Feb 13, 2019 at 4:11 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Jason and Jerry bought out pelfreybuilt hahaha
    Awesome.
    Not sure what that means..but they bought the old stock and maybe will be going into production perhaps. Not sure on the last bit.
    Cool beans guys. Glad to see you're trying to make it right for some folks @JLee @jberry813
    m3bassman likes this.
  3. Feb 13, 2019 at 4:16 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Very. Steaming out the pin hole. Boiled over into the over flow. Temp gauge was maxed out when I noticed it
  4. Feb 13, 2019 at 4:17 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I think it's for the alarm beeper
  5. Feb 13, 2019 at 4:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yep. Blew a hole in it somewhere up front passenger side.
  6. Feb 13, 2019 at 4:18 PM
    Speedytech7
    Was wondering this too, wonder if it froze
  7. Feb 13, 2019 at 4:23 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Idk could have. Was fine this morning though and was not Uber colder the last 2-3 days.
    Idk. Still liquid in the top hose. I don't think I lost a ton. But have a friend towing me home. To far and middle of no where
  8. Feb 13, 2019 at 4:27 PM
    Speedytech7
    It'll boil (overheat) earlier if it can't hold pressure
  9. Feb 13, 2019 at 4:29 PM
    Speedytech7
    They can be, should hold .9 bar. But I suspect the pinhole is probably the culprit haha
  10. Feb 13, 2019 at 4:47 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Nah somehow something made a pin hole or broke a seam. From there is just all down hill.
    Didn't have a shackle...of course..so had to leave Igor in a pull out. Have to get it tomorrow. Somehow.
    Ugh.
    Least im salary now haha
  11. Feb 13, 2019 at 6:23 PM
    INBONESTRYKER
    INBONESTRYKER Well-Known Member
    WY
    '96 access cab 3.4 5 spd manual 4X4
  12. Feb 13, 2019 at 7:24 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah. Not even bad luck. It's that I can't maintain them well. Hate it.
    Just tried getting it. Of course my shackle won't fit the recovery point. Spent like 30 mins trying to file out the hole and shackle. Going home again to take a grinder to the shackle bolt.
    Poor marks for relentless on that front.
    Trying to be the snow. It's just starting to fall
  13. Feb 13, 2019 at 8:48 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    @BossFoss
    What did you do with the motor from your double cab? What was the mileage?
    Did not think I need it but if I totally nuked the rings then I might..
  14. Feb 13, 2019 at 8:52 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Trouble on the top passenger side area on that radiator? Didn't you have a mounting issue in that same area at the north rim? I never fully understood what had happened and what you did to fix it.
  15. Feb 13, 2019 at 8:54 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah had a gap there. Just put washers there for now as I couldn't get the bolt tighter.
    Digiratus[QUOTED] likes this.
  16. Feb 13, 2019 at 8:57 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Same area as the pin hole maybe?
  17. Feb 13, 2019 at 8:57 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    I have it crated up on a pallet. Think there was 207,000 on it.
  18. Feb 13, 2019 at 9:04 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ish. Think the hole is just under the top tank. The mount is like what..4-5" lower so not sure.
    Cool. I might want to buy it..will let you know later haha
  19. Feb 13, 2019 at 9:09 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Lol well I hope not, but yeah if you need it you are welcome to it. I'd be more concerned with a warped head if you overheated.
  20. Feb 13, 2019 at 9:10 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah that's likely or melted rings I think. But hoping for neither.
    BossFoss[QUOTED] likes this.
