Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Mar 1, 2019 at 5:19 PM
    justinf307
    justinf307 Well-Known Member
    Justin
    Glenrock WY
    2007 Tacoma DCSB
  2. Mar 1, 2019 at 5:55 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Nice. Interesting. I like the folding design
  3. Mar 1, 2019 at 6:38 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    What is that...like 3 years without? :p It's about fucking time
  4. Mar 1, 2019 at 6:41 PM
    Digiratus
    Roaming the PNW
    The RedHead
    @drr @turbodb
    The 4x4 swap meet is next Sunday, the 10th, at the fairgrounds from 9-4. Interested? I'll be there about 10.
  5. Mar 1, 2019 at 7:47 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    That's called Stockholm syndrome
  6. Mar 1, 2019 at 7:49 PM
    Speedytech7
    I don't like letting Chinese lithium garbage sit anywhere unattended, has a bad habit of catching flame. Also those don't like to work in the cold because well, lithium doesn't like to work in the cold.
  7. Mar 1, 2019 at 7:53 PM
    Digiratus
    Roaming the PNW
    The RedHead
    naivate
  8. Mar 1, 2019 at 7:53 PM
    Speedytech7
    I can't wait for summer to see how many of these lithium battery powered scooters littering the streets burst into flame.
    IDtrucks likes this.
  9. Mar 1, 2019 at 7:53 PM
    Speedytech7
    You dropped this ï
    Digiratus[QUOTED] likes this.
  10. Mar 1, 2019 at 7:58 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Actually, a misspell. Fixed.
    Speedytech7[QUOTED] likes this.
  11. Mar 1, 2019 at 7:58 PM
    Speedytech7
    I just don't want one near my vehicle when it does, much like those cheapo jumpstarter packs.
    We've seen those packs go thermonuclear and burn trucks down, and a local AZ guy caught one right before it went up in flames and burnt his cruiser to a crisp. He got lucky and just needed a new seat cover and an interior cleaning. Those packs are hard to put out too without a neutralizer
  12. Mar 1, 2019 at 8:01 PM
    Speedytech7
    Employing this method then:lalala:
  13. Mar 1, 2019 at 8:04 PM
    Speedytech7
    Coil buckets and bent shocks can be replaced. A bit harder to glue together ashes
  14. Mar 1, 2019 at 8:15 PM
    Digiratus
    Roaming the PNW
    The RedHead
    An aluminum coil spacer never once burnt a Tacoma to the ground. Just sayin!
  15. Mar 1, 2019 at 8:17 PM
    Speedytech7
    This is truth, I dunno how coil spacer got brought up even. I'm figuring it was a weak deflection. We all know they're a bad idea anyway.
  16. Mar 1, 2019 at 8:27 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    I'm down. I'm sure there is something that I can buy that I don't need.
  17. Mar 1, 2019 at 8:30 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    I have one of those Noco jump packs that's been sitting in my truck for 3 or 4 years. Never used or charged since new.
    My battery went completely dead last month, as in not even the dash lights would come on, and that thing turned it over in 3 revs. Pretty impressive really.
    jubei likes this.
  18. Mar 1, 2019 at 8:35 PM
    Digiratus
    Roaming the PNW
    The RedHead
    It is amazing how much crap will be there. I am sure you will find something you 'must have'. :rolleyes:
    drr[QUOTED] likes this.
  19. Mar 1, 2019 at 8:39 PM
    Speedytech7
    Put a real chip on your shoulder eh? Haha, I'll drop it in any event, my only intent was to warn. When the much more stable LiFe polymer become more popular you bet I'll have one. Until then dual batteries will have to suffice.
    m3bassman[QUOTED] likes this.
  20. Mar 1, 2019 at 11:06 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I need one of these. Need to shop for one I like.
    I don't think it's the batteries that are the fault here pretty sure China makes basically all the lithium batteries used in pretty much all electronic devices. I'd be willing to be that it was faulty electronics in the device more than the battery
