Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Mar 8, 2019 at 9:29 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  2. Mar 8, 2019 at 9:41 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Makes sense to a point. But bit lazy too. There are way to make the buds stronger to a point they would at least last a bit longer before damaging the frame
    Digiratus[QUOTED] likes this.
  3. Mar 8, 2019 at 9:46 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I don't know where the main failure points were on yours Mike, but one would think that some reinforcement to the belly skid wouldn't hurt at least. At least that would be where I would suspect them to bend very easily when I was installing them on my 1st gen.
  4. Mar 8, 2019 at 9:48 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Bell pan and tranny skid cave very easily.
    Lots gusset them. Well...people who know they bend do.
    PcBuilder14[QUOTED] likes this.
  5. Mar 8, 2019 at 10:03 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Actually. it is the IFS skid that has deformed the most. Repeated impacts have made it almost impossible to mount. The belly pan skid is a bit deformed but not near as much as the IFS.
  6. Mar 8, 2019 at 10:25 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    What he's saying is correct, over-building one component just pushes the failure mechanism somewhere else. However, there are ways of adding a "fuse" to the system to make sure it fails predictably. For a skid plate, using 3/8" Grade 5 fasteners instead of 1/2" Grade 8 likely means that the bolts will shear and the thing will fall off before doing any real frame damage.
    My understanding is that the BB skids are heavy as hell, do you really want to add more weight to them? I bet you've gotten your $300 worth out of those things a couple of times over. Is there any way we can move mounting holes/brackets around so they line up a little better and you can get some more life out of them?
  7. Mar 8, 2019 at 10:51 PM
    Digiratus
    Roaming the PNW
    The RedHead
    This is maybe something we can talk about this weekend.
    drr[QUOTED] likes this.
  8. Mar 8, 2019 at 10:53 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I was hoping they offered a gusseting kit.
    I do agree, I definitely got my money's worth out of my first set.
    m3bassman[QUOTED] likes this.
  9. Mar 8, 2019 at 10:56 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Im still tempted to get the aluminum ones for Igor. Never do anything THAT hard anyways in Igor.
  10. Mar 8, 2019 at 11:08 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah its a grand for a full set from Bud. haha ouch
  11. Mar 8, 2019 at 11:14 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The 3/16 bare steel full set is $700 shipped.
  12. Mar 8, 2019 at 11:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah not a bad deal.
    Weighs like 3x as much as the aluminum ones. The full set of aluminum weighs I think less than the stock skids.
    The weight savings are what's tempting. You of all people should know it sucks getting the rig fat haha
    yeah i mean its all relative I think. Depends on how you use the truck really.
  13. Mar 8, 2019 at 11:22 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah i know.
    My SS skid is fine for what I do, and it has a couple major pings in it from me hitting stuff. Idk how the aluminum would fair long term. Bud Built claims aluminum does fine with direct impacts but not good with being drug around. Not sure how much merit that has.
    Either way, I've almost bought them a few times. Price tag is just hard to swallow.
  14. Mar 9, 2019 at 2:24 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Rip Zane
  15. Mar 9, 2019 at 5:41 AM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    What happened to Zane?
  16. Mar 9, 2019 at 5:52 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    JKO1998 likes this.
  17. Mar 9, 2019 at 6:12 AM
    BossFoss
    Wyoming
    01 DC Tacoma
    I saw that after I posted. What thread was the carnage in?. I haven't seen that many go in a hit before.
  18. Mar 9, 2019 at 9:26 AM
    Digiratus
    Roaming the PNW
    The RedHead
    The heavy hand of "god" is upon us...
  19. Mar 9, 2019 at 9:41 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Guessing in the lunch table thread something happened
  20. Mar 9, 2019 at 9:44 AM
    JKO1998
    Utah
    Nothing bad ever happens at the lunch table
