Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Mar 9, 2019 at 9:47 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    JKO1998 likes this.
  2. Mar 9, 2019 at 9:48 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
  3. Mar 9, 2019 at 9:49 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Didn't read it all. It's short though, thinking was just backing up Zane. Couple people were. Either way it was way off topic and uncalled for
  4. Mar 9, 2019 at 10:09 AM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
  5. Mar 9, 2019 at 10:18 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I just went to Zane's profile and looked at his last posts.
    BossFoss[QUOTED] likes this.
  6. Mar 9, 2019 at 10:28 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Not 3x, its actually a little less than 2x. The 3/16th steel set is 124# and the Aluminum is 63# and the 1/8th steel is 83#. So some weight savings but not as much as you suggest and I'm betting 63# is not less than the stock skids.
    IMO, the aluminum price makes it not worth it. The cost adds about $400 and would be $1100 shipped. It's
    Aluminum: $982 + 114.11 = 1096.11
    Steel : $575 + $122.14 = $697.14
  7. Mar 9, 2019 at 11:11 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    The problem with aluminum is that it's not nearly as tough as steel, so dragging it over rocks would do a lot more damage. You have to increase the thickness quite a bit to get even close to the strength of steel, so the weight savings end up not being as good as they could be.
    Now titanium skids, that's a different story...
  8. Mar 9, 2019 at 12:03 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah okay seeing the real numbers makes me remember. So a full set of skits is only 13lbs more than the stock skids. Thats awesome.
    And yeah 1/2 the weight. Thats a lot. Considering how heavy the rigs can get. I think its worth the effort..other than the cost.
    But again. Is steel really needed? You aren't doing anything crazy hardcore anymore. And I know Igor never will either. So why not go for a more light weight solution that will still protect you in the rare occasion you need it.
    Baller status there! haha
    Right not saying they are as strong. Purely making the argument that if one isn't planning on doing trails that requires heavy skid use. Why not go for the aluminum?
  9. Mar 9, 2019 at 12:50 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Probably tweaked from the jack a bit. Just brace it standing up then put a piece of wood on it and smack it a few times with a sledge. Or have the lady do it :p
  10. Mar 9, 2019 at 3:37 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Annnnnnddd now you see how that 1000 buck a roos for the Solo LCAs could merit its cost hahaha
  11. Mar 9, 2019 at 3:56 PM
    Digiratus
    Roaming the PNW
    The RedHead
    A little late now :oops:, but I recall putting a ratchet strap around the LCA arms to prevent spreading when we used the bottle jack to press out the old bushings.
    turbodb likes this.
  12. Mar 9, 2019 at 4:31 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Yep, we did this. And we took our time and were judicious with both pressure and heat until it released and we could push it out.
    Digiratus[QUOTED] likes this.
  13. Mar 9, 2019 at 6:30 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I felt like I could feel a difference right away with the whitelines. Especially under hard braking. Notice any differences yourself?
  14. Mar 9, 2019 at 7:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Lol no but they are just normal poly bushings so super easy to swap in and out.
    m3bassman[QUOTED] likes this.
  15. Mar 9, 2019 at 7:15 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Remind me why we did this when we had a 20T shop press about 10 ft away?
  16. Mar 9, 2019 at 7:20 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I think we tried initially.
  17. Mar 9, 2019 at 7:37 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The way the bushings are i think you have to press them out from the inside.
  18. Mar 9, 2019 at 8:03 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    We used the press for the passenger side. The problem on the driver side was that we couldn't get the sleeves out of the bushings, and so the threaded rod didn't fit through.
  19. Mar 9, 2019 at 8:08 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    well that doesn't look sketchy at all lol
  20. Mar 9, 2019 at 8:09 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    There were four of us, so that meant we knew what we were doing. hahahahaha
    Digiratus likes this.
