Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Mar 13, 2019 at 7:38 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    steering rack stud. Damn why did you take that out? Ive never had mine come out.
    man I hate that..
    THat one manual mine have it, wasn't sure if it was free or not. Last time this happened to me it was because I had overlooked a ground connection.
  2. Mar 13, 2019 at 8:08 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    I'm sure it's something simple, it's nice just to see it coming together, and the fact its telling me what's wrong is nice. Its pretty amazing how much most of the wiring is identical in every way and only a few differences here and there.
  3. Mar 14, 2019 at 2:23 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    oh oh oh oh
    steering rack
    Edit: i guessed that before i scrolled down past your initial post
    i know my steering rack hardware :D
    Lemme tell you hot i got that bitch back into mine. it SUCKS
    I had to cut a notch in the bottom of the frame channel, below where that clamp is bolted to the frame, so that I could stick a looooong pair of needle nose pliers in it to hold the nut so i could get that bolt started (since it is no longer welded to the frame). then i could hold the nut for the bottom bolt and get that one going.
    double edit: well guess you had a much easier time getting it back in than i did
    m3bassman[QUOTED] likes this.
  4. Mar 14, 2019 at 6:53 PM
    GregoryS10
    GregoryS10 Well-Known Member
    Gregory
    Casper WY
    2015 tacoma TRD off-road
    Has anyone used an uniden CB? Im trying to us an AUX cord to connect it to the tacoma's speakers but when i plug it into the external speaker jack on the CB it works as a PA and i hear my own voice come through the speakers. Any suggestions??
  5. Mar 14, 2019 at 6:53 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Steering rack clamp stud
  6. Mar 14, 2019 at 7:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    You just have it in the wrong port. There are two back there.
    I wouldn't wire it into your car stereo though. I'd just get a better speaker and tuck it away somewhere
  7. Mar 14, 2019 at 8:26 PM
    GregoryS10
    Gregory
    Casper WY
    Ive tried it in both, the one that the owner manual says is the external speaker does the PA thing and the one that it says is the PA acts as if nothing is plugged in until I flip the PA switch and then it also works as a PA, which that part seems correct to me.
  8. Mar 14, 2019 at 8:29 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Hmm odd. Could be because your trying to wire a balance connection to an unbalanced port.
    I wouldnt run it like that though anyways
  9. Mar 14, 2019 at 8:31 PM
    GregoryS10
    Gregory
    Casper WY
    Ya I should probably just buy an external speaker and hide it under the seat or something. That way I can still listen the to radio while using the CB
  10. Mar 14, 2019 at 8:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Exactly. Uinden makes a nice one for like 12 bucks
  11. Mar 15, 2019 at 9:31 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  12. Mar 15, 2019 at 11:24 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    I'd like to get a CB radio. Totally new territory for me. Are there any radios that have an internal antenna so you don't have to mount one externally?
    My use would be just to listen to chatter on the interstate for fun (and maybe in the event of an emergency someday in lieu of cell phone coverage; also on the interstate).
  13. Mar 16, 2019 at 12:55 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sounds like your clutch wasn't aligned right maybe.
    And input on tcase?
    Only cb that will do that is a handheld which I wouldn't bother with. The range will be maybe a mile. Radios are all about the antenna and the tune. Without that, you're never gonna have good performance.
    A cb likely won't be good to get help either as you'll be lucky to get more than 3 miles out of any legal cb radio. Ham radio is much better suited for that.
    NMTrailRider[QUOTED] likes this.
  14. Mar 16, 2019 at 5:10 AM
    BossFoss
    Wyoming
    01 DC Tacoma
    It's a monster, have a trans jack or the adapter for a regular jack to help. It's doable by yourself but if you can have an extra set of hands it's better. It's sealed between the tcase and trans with a small main seal around the output shaft so you could separate them without oil going everywhere if that's what you are asking.
    Edit: also a long extension to help with the top bolts, like 2' long.
  15. Mar 16, 2019 at 6:53 AM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    That throw out bearing rotating? Mine makes a squeal like that sometimes when it's super cold out. Mine is for sure tob. It's a common prob on second gens but not sure about first gens
  16. Mar 16, 2019 at 8:01 AM
    SconnieHailer
    Marc
    Blackdawg[OP] likes this.
  17. Mar 16, 2019 at 8:06 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I'd guess throwout bearing too.
    You can get it out with the cheap horrible freight trans jack, but it's a bit of a balancing act. I've got the process pretty well figured out here recently. :anonymous:
    There's 4 bolts that hold the crossmember to the frame, and four more that hold the trans mount to the crossmember. Remove those last after bellhousing and starter bolts, and wiring.
  18. Mar 16, 2019 at 10:06 AM
    BossFoss
    Wyoming
    01 DC Tacoma
    You will need to lift up on the trans up a little once you get the 4 nuts off. The weight of it makes it tough for those to back out. Also you will need to pull the shifters out of the top so it can fall down and back.
  19. Mar 16, 2019 at 10:15 AM
    Speedytech7
    Wouldn't matter, it would have realigned itself the first time the clutch was pressed.
    m3bassman likes this.
  20. Mar 16, 2019 at 10:40 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Cool for sure. A good inspection would be needed indeed.
    The skid?
    Are you talking about the front drive output seal? Or the full tcase where it meets the tranny
