Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Mar 18, 2019 at 6:26 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Maybe my OEM shock bushings should mysteriously shred themselves so I can use it as an excuse for coilovers :spy:
    I know bushings aren't the same as bearings...
  2. Mar 18, 2019 at 6:34 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    If they’re anything like my autozone strut bushing they’re already gone
  3. Mar 18, 2019 at 8:10 AM
    PcBuilder14
    Brent
    Nor Cal
    Haha probably accurate.
    That's too long, I was hoping for something like 15k...
  4. Mar 18, 2019 at 9:34 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Well he has barely taken his off-road so I wouldn't bank on his numbers if your actually going to use yours. His is a street queen
  5. Mar 18, 2019 at 9:40 AM
    PcBuilder14
    Brent
    Nor Cal
    I like your answer better. My front end is sagging so bad from the extra weight and a lot of cycling off road that the CV's actually angle up towards the wheel/tire. Need to replace them with something soon and your ADS purchase is making me :jellydance:
  6. Mar 18, 2019 at 9:42 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I can bring some lightly used kings for you...hahahahaha
  7. Mar 18, 2019 at 10:01 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
  8. Mar 18, 2019 at 10:27 AM
    JKO1998
    Utah
    :rolleyes:
    Digiratus likes this.
  9. Mar 18, 2019 at 10:49 AM
    PcBuilder14
    Brent
    Nor Cal
    Hmm, don't think they'd fit all too well...
    Nah, just the factory stuff. Fairly impressed at how well the factory stuff does up front. Just too saggy now and of course sucks in whoop sections.
  10. Mar 18, 2019 at 11:07 AM
    PcBuilder14
    Brent
    Nor Cal
    Yup, the stock rear suspension didn't last very long at all with the RTT and extra gear on trips. With the AAL and air bumps it's decent now. Still need to get new shocks for the rear since the stocks act like limit straps now with the AAL. The air bumps let me push it a lot more than I probably should, but it's nice and smooth.
    Axle hop is something I've been noticing a lot as well, even with the AAL.
  11. Mar 18, 2019 at 11:33 AM
    PcBuilder14
    Brent
    Nor Cal
    That was a consideration as well, but I wanted to do something that would be able to carry forward into when leaf spring replacements and shocks become a reality, or if a temporary solution it would not cost a lot.
    The bump stops were something I knew I'd get eventually, so they were something that made sense in my mind. At least this way if the rear suspension begins to sag again at least I'm not slamming into the factory bump stops and possibly bending the frame like it felt before I had them.
    The AAL was cheap enough that I could justify it as a temporary solution. Plus it didn't raise the rear end so high that it's a stink bug. One day I'd like to get the Deaver expo packs rated for 400-600lbs of additional weight. Hopefully that would be the right range for tent, gear, and the eventual rear bumper.
    You know you can't keep that thing boring and stock. I think it's time to consolidate and have a built 3rd gen :boink:
  12. Mar 18, 2019 at 11:40 AM
    PcBuilder14
    Brent
    Nor Cal
    I will say, I normally don't care for that color but the black wheels make it look much better! Still need to pick up a pro grille too. Just keep finding other things to spend money on.
    New tires are something I really want too, but I'm trying to make myself wait until the stocks get shredded or something. Maybe I'll get my wish after this Utah trip :anonymous:
    m3bassman[QUOTED] likes this.
  13. Mar 18, 2019 at 11:51 AM
    PcBuilder14
    Brent
    Nor Cal
    Yeah, the colormatch is convenient with that color. Before they offered leather in the non-limited models I really wanting the orange interior scheme. Wouldn't match the grey exterior, but still looks nice imo. Luckily the regular grey dash bezel matches up with my paint color pretty well too, just doesn't pop.
  14. Mar 18, 2019 at 1:11 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    lol I might have! probably..
    Looks like I need to yearly or at least biannually.
  15. Mar 18, 2019 at 4:03 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    You figure out the fuel pump? EFI relay to Circuit opening relay up under the dash to the left of the steering column.
  16. Mar 18, 2019 at 4:55 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Thats where the "circuit opening relay" is? Cool.
    No not home yet. Bought a tube cutter this morning to trim the tank hanger tube to fit the 340LPH pump. Guess this means I have to turbo it now...lol
    I'll finish that up when I get home then start putting the tank back in. I'll test to see if the pump is getting power first though.
  17. Mar 18, 2019 at 8:50 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Lol that sound like solid reasoning, can't poke any holes in that.
  18. Mar 19, 2019 at 7:09 AM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Digiratus[QUOTED] likes this.
  19. Mar 19, 2019 at 8:42 AM
    BossFoss
    Wyoming
    01 DC Tacoma
    This is out of the 97, so should be the same. My 01 is a smaller black one on the inside fuse panel.
  20. Mar 19, 2019 at 9:06 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    awesome. Hopefully I get home in time tonight to check it out before it gets dark.
