Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Mar 19, 2019 at 8:09 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    @Man of Steel TRD has a very nice one that he's just basically rebuilt, new turbos and all.
    I like that gen too, but I had a hard time finding any that weren't dogged into the ground from years on neglect. Most people let them break because "they're too hard to maintain and repair". So it's hard to find a nice one. I like my gen too much, so much 80s and more than enough power for a GT car.
  2. Mar 19, 2019 at 8:11 PM
    Speedytech7
    One of the first things automotive diagnostic programs teach you is to not assume correlation. Steers you off course
  3. Mar 19, 2019 at 8:20 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I can't do that in Igor at all. I don't think. Usually 280 range.
    I wouldn't think that way. Bad injectors tend to make it run lean more than rich.
    I think the motor in this gen is one of the best sounding v6s ever.
    They are expensive to own I've read. Was one for sale up here for a long time in good shape. Was yellow though. Didn't love that and an auto.
    MkIII supra is still my favorite
    Speedytech7[QUOTED] likes this.
  4. Mar 19, 2019 at 8:24 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I’ve never got over 250 I don’t think, even 31’s haha.
    But then again, that trucks only been out of that corner of Utah like 3 times sooo, no highway miles hahah.
  5. Mar 19, 2019 at 8:30 PM
    Speedytech7
    I like the MkIII, a 91 turbo model crossed the block at Mecum last weekend with 32k miles and brought 29k. Only three bidders. That's the most I've ever seen one of those bring, they usually don't break 15-18k.
    The VG30DE does have a good sound. Actually most Nissan V6s do for some reason... Strange. They did make Japan's first mass produced v6 though, maybe they know what's up
  6. Mar 19, 2019 at 8:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Frank barely gets 180 a tank on the highway if it makes you feel better haha
    So I tested the fuel pump power. Had Devin crank it. The battery is dead pretty much. Showed 8v though. Couldn't fully crank bit pump showed 4-5v and the plug. So looks like all this effort is for nothing pretty much. No idea what's causing this.
  7. Mar 19, 2019 at 8:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Wow that's nuts.
    I hope to have one again someday. Found a 91 with a 2jz in it I really wanted. But he decided to finish it up a bit more before selling. Interior was a bit taken apart.
  8. Mar 19, 2019 at 8:32 PM
    Speedytech7
    Well what about spark or injection pulse. Have you check to see if you're getting either? Rent a noid light set for the injectors and you can do the spark visually
  9. Mar 19, 2019 at 8:33 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Haven't looked too close. Be the next things I guess
  10. Mar 19, 2019 at 9:09 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Something something chain store something something savy folks something all the parts you'll ever need.... :rockband:
  11. Mar 19, 2019 at 9:26 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    My averages for the last two years (i.e. non-stock) are:
    all-up: 15.78
    4WD: 13.95
    Highway: 16.75
    Note that all these numbers are adjusted for accuracy - i.e. they compensate for the fact that the ODO/speedo don't read quite right. If I didn't adjust - i.e. if I just divided (ODO miles / gallons), they'd be ~8% higher.
    Unadjusted, the ODO reading 300 on fumes sounds about right, with a very slight tailwind. With a headwind, no way. With a nice tailwind, might be able to get up to 330 after having the fuel light on for ~30 miles.
    m3bassman[QUOTED] likes this.
  12. Mar 19, 2019 at 9:31 PM
    Speedytech7
    AC Delco doesn't actually make many Japanese suspension parts, looks like you got a 555 and a federal mogul
  13. Mar 19, 2019 at 11:57 PM
    Man of Steel TRD
    Man of Steel TRD Ignorance is the new normal
    Jeremy
    Gilbert, AZ
    2021 Ram Limited Night Edition, 91 300ZXTT, 90 Toyota Pickup ECLB
    Tow package, LED interior lighting, led low beams, led fog lights, led licence plate lights, OEM bed mat, OEM mud flaps, OEM chrome raised tailgate letter inserts, nerf bars, AVS ventshades. Complete Kicker audio system (4 channel amp, mids and tweets in the front, 2 ways in the back, 2 10 inch comp rt subs, Zxsum8, alpine pdx 1.600 boxes and amp rack by Mr Marv), Pop & Lock, Mobtown locking bed storage doors, Bilstein 5100s, Katzkin Leather interior, Redline Hoodstruts, Backflip.
    Just put the plenum back on tonight. Going to pull the motor in the next couple of days so I can replace the rear main seal and get to reassembling it and paint the engine bay!! Also put the back back together as well. Just have too many parts everywhere!! How's it going @Speedytech7 ?
  14. Mar 20, 2019 at 8:28 AM
    Speedytech7
    I think it's going pretty good, really need to pressure test my fuel system and then I can throw the intake plenum back on and fire it up. I've changed every sensor and ignition component so good chance something won't work right haha
  15. Mar 20, 2019 at 9:55 AM
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    Man I wish my hands were that small for working on this car!! Haha!!
  16. Mar 21, 2019 at 12:52 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Anyone in the Evanston area?
    Grant's rear wheel bearing nuked. haha same thing happened to him that did to me. Thought it was the front passenger wheel area. Was the rear bearing.
  17. Mar 21, 2019 at 7:35 PM
    Justrom
    Justrom Well-Known Member
    County 10 - Wyoming
    '13 Dbl Cab Long Bed
    I'm afraid to even log in here in the days leading up to a trip. Don't want my truck to get any ideas!
    PcBuilder14 and m3bassman like this.
  18. Mar 21, 2019 at 10:17 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well I figured out what was causing the pull of the wheel when braking..and why do some reason today my alignment was out.
    Lca bushings are completely shot. The rear one in particular. So much regret on throwing out Frank's stock lcas..
    Not sure what I'm gonna do yet
  19. Mar 21, 2019 at 10:21 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  20. Mar 21, 2019 at 10:24 PM
    Speedytech7
