Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Apr 1, 2019 at 12:03 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Sorry, what I wrote was confusing. What I meant to write was" With just the rotor on it, was there any rubbing noise when you spun it? "
  2. Apr 1, 2019 at 12:33 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Lame. Your truck is now worth 50% what it was Imo haha can't believe you let Tyler have that.
    It doesn't sound like the calipers are dragging on the rotor which is what you and Zane are both suggesting it seems.
  3. Apr 1, 2019 at 12:39 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    Well you aren't the one buying so I guess I'm in the clear haha. You'd have sold the SC in my shoes too I bet. It adds no real sale value to the truck but it's a valuable chunk of aluminum on it's own.
    I'm not suggesting the caliper is dragging now, I think it might just be cheapo rotor if the one from the other side doesn't net the same result.
  4. Apr 1, 2019 at 1:27 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    don't know, will try.
    Nope, no running with just the rotor (when it was not snugged down).
  5. Apr 1, 2019 at 1:44 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I have to agree with Monte on this one, the truck was way more interesting to me with the SC on it.
    And @turbodb I agree with Zane, it is more likely a rotor issue.
    edit: A wheel bearing failure typically manifests with a noise (think crunch, crunch,crunch) as the wheel rotates or or slop in the X and Y axis.
    turbodb likes this.
  6. Apr 1, 2019 at 4:17 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    It's not really the rotor, it's the fact that when the lugs are tightened, the hub becomes hard to spin*. I guess I noticed it first when I was temporarily snugging up the rotor to install the caliper.
    *hard to spin hub made me think of a wheel bearing, since that's what's spinning in the hub.
    I think Zane and Mike are suggesting that maybe the rotor is tweaked, and so snugging it up (either with or without the wheel installed also) is causing other things to get pulled out of alignment or rub abnormally...thus making the hub hard to spin.
    So, first step is to swap the rotor with the other one. If the problem persists, then there's something wrong with the hub/bearing. If the problem goes away, it's a rotor problem. ...at least in my mind.
    Nice. It's a pretty easy job. I did both sides this morning in a little under 2 hours including clean-up and brake bleeding; assuming you don't run into some issue. I will say that the 4Runner is easier though, since it uses a hard brake line into the caliper. Strange the Taco is different...
  7. Apr 1, 2019 at 4:45 PM
    Speedytech7
    I told you this, crack a bleeder open, push the pedal to the floor and use something to hold it there while you work on the brakes. The plunger won't let brake fluid out of the reservoir when it's in pressure position.
    turbodb likes this.
  8. Apr 1, 2019 at 4:49 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Yeah, seems strange to me that it would deform anything, esp. because the two lugs on the rotor aren't even torqued - they are just finger tight. So like 1 ft-lb, hahahaha. Anyway, we'll see tomorrow when I take everything apart again to install the suspension.
    For brake fluid, get yourself some of these at your local parts store. When you remove the brake line at the frame (by the shock tower), put one of the caps on the hard line...as long as the cap is on, no fluid will come out. Which means you only have leakage when you're removing the old flexible line or installing the new one.
  9. Apr 1, 2019 at 5:34 PM
    Speedytech7
    any bleeder, just to relieve pressure so you can get the pedal to the floor
  10. Apr 1, 2019 at 5:44 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Eh maybe. Idk. It's such a rare item that it probably would have helped you actually. That and it make those that want a v6 consider it more.
    Also leaving the line in a cup with a little fluid helps.
  11. Apr 1, 2019 at 5:45 PM
    Speedytech7
    I've never made that trick work, seems to always end up like a siphon and keep bleeding out.
  12. Apr 1, 2019 at 6:35 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    2002 Toyota Tacoma TRD Off Road
    http://www.ksl.com/auto/listing/5478392
    Little higher than you want but the frame looks decent in the one picture
  13. Apr 1, 2019 at 6:52 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not bad. Bit high on price though. Looks clean
  14. Apr 1, 2019 at 6:54 PM
    JKO1998
    Utah
    Yea that’s what I thought, but figured I’d share anyway
  15. Apr 1, 2019 at 6:58 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Appreciate the looking out!
    JKO1998[QUOTED] likes this.
  16. Apr 1, 2019 at 7:23 PM
    JKO1998
    Utah
    I think you messed up on the red
    Bringing that back up for the regret you feel
  17. Apr 1, 2019 at 7:28 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The red? The red one was sold by the time i found it. The black one was the one I regret haha
  18. Apr 1, 2019 at 7:30 PM
    JKO1998
    Utah
    Which one was supercharged? I think I missed the black one
  19. Apr 1, 2019 at 7:31 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    the black one was with 330k on it
  20. Apr 1, 2019 at 7:37 PM
    justinf307
    justinf307 Well-Known Member
    Justin
    Glenrock WY
    2007 Tacoma DCSB
    We have a bunch of family that lives in Cheyenne and they all seem to enjoy it. Like everyone mentioned the winters can be rough, but Cheyenne doesn't necessarily see the worst of the cold either. While the SE Wyoming might not be what everyone thinks of when they think of Wyoming there's definitely some amazing places close. You cant beat proximity to all the good things CO has to offer without having to live there! The snowy range is one of the most underated as far as mountains in Wyoming IMHO, at least if you get off the beaten path. If Laramie is an option we loved it, the winters are probably some of the worst in the state but the summers easily make up for it. 85 degrees max, with cool evenings.
