Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Apr 9, 2019 at 6:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    You're not unbolting the tcase are you? No need to for a clutch.
  2. Apr 9, 2019 at 7:02 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Just pop it in gear in 4wd and use a 3' breaker bar or so. Should come right off.
  3. Apr 9, 2019 at 7:28 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    What?
    BossFoss likes this.
  4. Apr 9, 2019 at 8:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Where you in 4wd?
    Cause youd be moving the whole truck if the shaft moved. If so higher gear. 3rd
  5. Apr 9, 2019 at 8:26 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    You're just turning the engine over.
    Front or rear output seal? You can just put the breaker bar up against the frame and tap the starter with the clutch engaged and the clutch start cancel button.
    m3bassman[QUOTED] likes this.
  6. Apr 9, 2019 at 8:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    oh you pulled both shafts. Well thats your issue. Do the starter technique Brett mentioned then.
  7. Apr 9, 2019 at 8:41 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Stake nut: 90179-22016
    Mine was not easy to remove. It took the rear driveshaft installed, the t-case in 4lo for the impact gun to be able to spin it off.
    edit: Using the same gun, took off the 4 14 mm nuts on the companion flange with the tcase in neutral.
  8. Apr 9, 2019 at 9:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Hmmm @BossFoss
    You have to own a business to buy stuff off of Copart?
    Edit: Looks like it. Damn it. You have an account?
  9. Apr 9, 2019 at 9:19 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    6" wobble extension and you can get all 4.
  10. Apr 9, 2019 at 9:48 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I paid out the ass this year to uncle sam. Tax break my ass.
  11. Apr 9, 2019 at 9:50 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I luv my M18 Fuel impact. One of the better tool investments I've made.
  12. Apr 9, 2019 at 9:52 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    thought about getting one myself. I just love Air tools. But seeing as I don't have air up here(yet) the M18 and M12s are appealing. Make a lot of work a lot faster.
  13. Apr 9, 2019 at 9:57 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I've used it on a lot of things now. It isn't the bigger model but has been plenty for everything I've asked of it. But just barely in the case of the stake nut on the output shaft. Also found it to be small enough to fit in all the places I've needed it to. #milwaukeefanboi
    turbodb likes this.
  14. Apr 9, 2019 at 10:20 PM
    Reh5108
    Idaho
    An old blade screw driver could be ground down to fit in the slot to wedge out the dent more if you have a grinder of sorts. Worked well when I just did 3 of them.
  15. Apr 10, 2019 at 12:02 AM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    You can hire a broker, when I was looking at one I got ahold of one in Co. He charged me I think $500, but since I didn't win the auction he refunded my money. Find a nice DC?
  16. Apr 10, 2019 at 12:04 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah I did. Goes tomorrow though. Don't know if I can get a broker that fast. no photos of the frame either which kind of has me a bit leery. Just randomly checked tonight. Should have been doing it more regularly. Its in CO too so not too far.
  17. Apr 10, 2019 at 5:19 AM
    BossFoss
    Wyoming
    01 DC Tacoma
    Ah nice, iirc it didn't take long to set it up, just call and give them your CC for the deposit and then tell them what you are willing to bid and then watch the auction online. Link?
  18. Apr 10, 2019 at 10:35 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Seems simple enough. Need to pay attention more then.
    This guy: https://www.copart.com/lot/31600879
    Pretty nice looking. Minimal damage. Probably go for more than I'd want to spend anyways.
    BossFoss[QUOTED] likes this.
  19. Apr 10, 2019 at 12:50 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Dang, nice shape, hard to believe they would have totaled that. Yeah you should watch it, probably blow your mind and make you wish even more you had bought SC'd Blackie. The one I had looked at had way worse damage, I think less miles and went for $8,000. I think I was willing to spend like 3-4 and I was quickly out of the running lol. I think that was 2014, I'd be curious to see if it's the same or if things have calmed down a bit.
  20. Apr 10, 2019 at 1:06 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Wow haha that's nuts. I think things have calmed a little but not a lot on 1st gen DC. Still desirable but now some 2md gen double cabs are same price or even cheaper so really getting to the point where you'd only buy one because you really love them.
    I really do wish I'd just bought it. Stupid of me. Yet smart at the same time I guess. Still would have been ideal.
