Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Apr 10, 2019 at 1:11 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Couldn't find it in today's auction but it says starting bid was $4250 if that helps
  2. Apr 10, 2019 at 1:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Was a $0 yesterday haha
    Over my budget. Damn
    BossFoss[QUOTED] likes this.
  3. Apr 10, 2019 at 1:18 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Blackdawg[OP] likes this.
  4. Apr 10, 2019 at 1:20 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
  5. Apr 10, 2019 at 1:23 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Yeah, bad day for whoever was in there. Hopefully they survived.
  6. Apr 10, 2019 at 2:09 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah that'll buff out.
    "For sale! Newly rebuilt Tacoma. Small fender bender, frame is straight, no major damage. Drives like new! 16k obo."
  7. Apr 10, 2019 at 2:28 PM
    JKO1998
    Utah
  8. Apr 10, 2019 at 2:38 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Sounds pretty rare to me, he said I won't find another one like this anywhere. :spending:
  9. Apr 10, 2019 at 2:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    My favorite is how fucking lazy people are when selling stuff like that. Like what shitty photos and he didn't even wash it.
    Just..slap in online. It's worth 21k! Wtf
  10. Apr 10, 2019 at 3:07 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    His wife/SO said he had to list it or else. He did but doesn't really want to part with it, hence the listed price.
  11. Apr 10, 2019 at 4:12 PM
    JKO1998
    Utah
    You texted him? You’re the second one to say this about that truck
  12. Apr 10, 2019 at 4:20 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    That's what I'm gonna do when I ha e to sell Frank.
    "Lightly used built super badass overland Instagram famous Tacoma. 45k firm"
    :rofl:
  13. Apr 10, 2019 at 4:55 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Pretty sure it would be drivers side. Double check first. You'll want it to turn clockwise when looking at the face of it.
  14. Apr 10, 2019 at 5:14 PM
    Squeaky Penguin
    Brett
    Which direction are you looking at it?
    Quit thinking like an engineer and just watch it while someone clicks the starter. If you want it to go the other way put it in reverse.
    m3bassman[QUOTED] likes this.
  15. Apr 10, 2019 at 8:03 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    Work it up and down helps, also you can gently pry inbetween the bell housing and engine block with something to help free it
  16. Apr 10, 2019 at 8:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah make sure it's held up high gh enough in the back too. Otherwise it's a lot of weight on the input shaft
  17. Apr 11, 2019 at 8:53 PM
    Digiratus
    Roaming the PNW
    The RedHead
    My notes and research lists 90311-41007 as the rear output companion flange seal, the outer oil seal on the rear of the t-case. The inner one on the rear, the small one that seals around the shaft splines is 90312-23001.
    The front output companion flange seal is 90311-41012 and the inner one for the front is the same small one used on the rear. 90312-23001.
    Ben, I have not installed my new seal so I can't confirm this is correct. Mine had a lot of wet, soft mud around it so I cleaned it all up and reassembled without replacing...yet. As I have yet to drive it anywhere, I do not know for sure it is fixed. So far (just sitting there) it is dry as a bone. <knocks on wood>
  18. Apr 11, 2019 at 8:58 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I thought you were doing the front one? Not the rear one..
  19. Apr 11, 2019 at 9:16 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I have found this site very helpful in finding the right parts. Especially if you plug in your vin.
    Camelback's catalog is dificult to use IMO.
    https://www.toyotapartsdeal.com/oem/toyota~seal~oil~for~transfer~case~90311-41012.html
    jubei likes this.
  20. Apr 11, 2019 at 9:25 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I will still buy from Camelback. Especially if my order is more than $150 for the free shipping. Their prices are competitive with other online retailers so the free shipping makes the difference. Just don't rely solely on their parts catalog.
