Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. May 23, 2019 at 7:05 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Anyone else tried to upload pics to flickr today?
  2. May 23, 2019 at 7:11 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    No why?
  3. May 23, 2019 at 7:20 PM
    Digiratus
    Roaming the PNW
    The RedHead
    No access, down for maintenance. Been trying all day.
  4. May 23, 2019 at 7:27 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    I think I read it will be down all day today.
  5. May 23, 2019 at 7:29 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Really gonna be closer to 2.5k to do all the fueling and computer control right rather than the half ass jerry rig crap people come up with on here all the time
  6. May 23, 2019 at 7:30 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    What’s the point of Flickr?
    Storing full sized photos?
    Or?
  7. May 23, 2019 at 7:38 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not really. 500 for megasquirt..for me. Or aem. 300? For injectors. 150 for fuel pump if that. Maybe add 500 for meth water. Pretty much all you need.
    Flickr has much better data compression as in it doesn't make the photo look bad. Unlimited bandwidth useage too. And you used to get 1Tb storage for free but that's changed now.
  8. May 23, 2019 at 7:41 PM
    Speedytech7
    You underestimate the costs though, like in bens case the megasquirt woulnd't be easily possible because the trans controller is built into the OEM ECU and requires running signals. The MS that is ideal for these trucks is closer to $1200 now BTW.
  9. May 23, 2019 at 8:45 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not the one thats plug n play for my taco :D
  10. May 23, 2019 at 8:46 PM
    Speedytech7
    That one is pretty strippy, fine for a wheeling rig maybe, or a track vehicle. But lacking most features someone would want for a daily
  11. May 23, 2019 at 8:47 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    In what way?
  12. May 23, 2019 at 8:50 PM
    Speedytech7
    no closed loop self learn, knock module isn't included, cannot address an auto trans (might be able to address a separate trans controller, they aren't clear on that), IO capability is pretty limited so keeping some stock systems for emission might be difficult
    it's totally fine for something you don't mind having your laptop ready to tune on everywhere you go though
  13. May 23, 2019 at 8:52 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well...I don't need a trans controller, manual. And no emissions so. I don't see an issue. Closed loop tuning won't be super easy but not that bad
  14. May 23, 2019 at 8:54 PM
    Speedytech7
    Yeah it might be for some people, but it isn't one of the ECUs from their lineup that I would bother with. I would consider it, and probably still pick something else, if I was going to be tuning something single purpose like a drag truck or something
  15. May 23, 2019 at 8:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I just want a fun day turbo taco. Seems like it would be good for that. Be fine for the SX daily
  16. May 23, 2019 at 9:15 PM
    Speedytech7
    Flickr is back BTW
    Digiratus likes this.
  17. May 24, 2019 at 4:58 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Can't the megasquirt just be run in parallel with the factory ecu? Just control fuel and timing with the MS. This was my plan at least unless I'm missing something. Not entirely sure how it would all work out but I planned on going with the diy kit.
  18. May 24, 2019 at 8:10 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The kit I was looking at. No. It's a full stand alone that plugs into the wiring harness direct.
    I'm not sure mega squirt has a piggy back.
    If you're going the piggy back route just get an arm fic6
  19. May 24, 2019 at 9:11 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Hey Ben, in your time in the Moscow area, did you ever get up to Moscow Mountain?
  20. May 24, 2019 at 9:12 AM
    Digiratus
    Roaming the PNW
    The RedHead
    I meant to tag you on this^^^ @m3bassman
