Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. May 24, 2019 at 9:29 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
  2. May 24, 2019 at 9:37 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Can the fic handle knock and run aux fuel injectors?
  3. May 24, 2019 at 9:39 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    no. Just the main 6. Why are you runnign aux injectors? you don't need to do that shit.
    Knock im not super sure of. I think if you do a GM sensor swap and have good wire run to the stock one it's fine.
  4. May 24, 2019 at 9:48 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Google gave me a couple of routes. One going north from Troy and one going eastish off of 95 north of Moscow. Ever do any camping in either of those areas?
  5. May 24, 2019 at 9:58 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Ok, thanks.
  6. May 24, 2019 at 11:52 AM
    Reh5108
    Idaho
    I'm not yet but from my understanding bigger injectors have idle issues. I'd just like to have something that has more options for if I ever do try and squeeze 300-400 hp out of the 3rz.
    Stock knock should be fine but I wouldn't mind having a second giving feedback.
    DIY MS is around $500 I believe. I don't think that's terrible when it could be a full standalone.
  7. May 24, 2019 at 12:04 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    A MS is a full stand alone. But as Zane was mentioning its a bit restricted. You can add modules to it though. Be fine I think for most things though.
    The AEM FIC6 will do pulse width on the injectors so you won't have idle issues.
  8. May 24, 2019 at 8:24 PM
    Reh5108
    Idaho
    It can also be run in parallel though.
    https://www.diyautotune.com/support/tech/install/install-megasquirt-parallel/
    Being able to tune on a tablet is another perk of the MS
  9. May 24, 2019 at 8:43 PM
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
    Staying the night in Casper on Monday. Any place that is a must stop for dinner?
  10. May 25, 2019 at 1:18 PM
    justinf307
    justinf307 Well-Known Member
    Justin
    Glenrock WY
    2007 Tacoma DCSB
    HQ bbq, Wyoming Ale works, Fire Rock, J's pub. All good choices
    90yota likes this.
  11. May 25, 2019 at 1:20 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    If you're gonna DIY it then yes you can do that, it can be a bit tough to feed the ECU the signals it needs to not get pissy but it's possible. I wouldn't go with the MS box monte was looking at though for that
  12. May 25, 2019 at 1:22 PM
    Speedytech7
    You could run 4 big injectors just fine, I've seen people trim 2200cc injectors and have it run great at idle, it's all about the quality of the tune, but there is a secondary injector rail option for the 3rz if you really want to worry about two stage injection and crossover points
  13. May 25, 2019 at 1:58 PM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    I mountain biked up there a lot but never camped. Make sure to grab some loco grinds or bagel shop in town the other places arent worth much for foods.
  14. May 25, 2019 at 4:44 PM
    90yota
    88 T4R / 15 F350
    Stock....ish
    Awesome thank you
  15. May 27, 2019 at 2:58 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    The T/C that came with my diesel is a J shift with center locker. I would think you could get an AWD low, might have to do some wiring trickery if it has a sensor on it.
    Blackdawg[QUOTED][OP] likes this.
  16. May 27, 2019 at 8:49 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Should be able to I'd think. I wanna find one for the single cab some day I think. Be fun. Pretty low on the priority list though for me.
    Just got back. Was nice. Mostly sunny, good views, good people.
    It's still raining here though..insane how much it's rained in the last now 3 freaking weeks.
  17. May 27, 2019 at 8:57 PM
    BossFoss
    Wyoming
    01 DC Tacoma
    I have 0 plans for it, was just going to sell it with the A340 on craigslist. Yeah it rained all day here today and is going to rain again all day tomorrow. It's getting a bit crazy, but I still appreciate it even though it's totally jacking with my work ATM.
  18. May 27, 2019 at 9:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oh wait. I didn't realize you wanted to get rid of it! Oooo I like where this is going. I foresee a trip to lander to pillage more parts!(not really, obviously I'd give you money for that)
    It's screwing over construction at Tippet too. Same with my parents. I've never had such a long bought of straight rain here ever in my life. I miss the short power cells of rain that last 30 minutes haha
    BossFoss[QUOTED] likes this.
  19. May 27, 2019 at 9:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Little rain the first night. Yeah Dan Melissa Mike Gage Lizzy and two new folks that Gage brought up Kyle and Brittany. Was fun. Super chill. Was great on Sunday. Dumped on us for like 20 mins but that was it. I was outside handing tools to a kid trying to fix an atv. So that was fun haha
    Not really wheeling. Drove a pretty bumpy road twice, on accident really, but mostly just hanging out looking at the area and relaxing.
  20. May 27, 2019 at 9:19 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah it was nice. Shame you couldn't be there. But looks like you had fun anyways!
    I'm super stoked with how Igor rides now for the most part. The front is amazing with the new shocks and control arms. Rear still...well sucks. It works but only have 1" up travel before the bumps isn't working well for bigger stuff.
    But drove it hard over some rough roads. Alignment held great. Still amazes me we can do that shit then get on the interstate and drive 80mph 500 miles home without even a thought. Crazy.
