Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. May 27, 2019 at 9:28 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    You're in the discussion convo about it
  2. May 27, 2019 at 9:34 PM
    Speedytech7
    Check my post again
  3. May 27, 2019 at 9:36 PM
    Speedytech7
    That's not how that works, if you dipped from it early it removes you from the roster, dig through your inbox or Im gonna see if Bob thinks it's an error
  4. May 27, 2019 at 9:40 PM
    Speedytech7
    I just don't want you thinking you were left out of anything :oops:
    m3bassman[QUOTED] likes this.
  5. May 27, 2019 at 9:42 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    I would say there seems to be about a week to two week period in May/early June when it just rains for the entire time. It feels double that this year though.
  6. May 27, 2019 at 9:45 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Dude. Your in the PM. You replied to it even and said you couldn't make it.
    Yeah seems way longer this year. Hopefully means less fires
  7. May 27, 2019 at 9:45 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    You quit?
  8. May 27, 2019 at 9:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  9. May 27, 2019 at 9:47 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well snap dude. That's nuts.
    Anything lined up? Hopefully in Boise still?
  10. May 27, 2019 at 9:52 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I made sure you were included. We were going to be in your back yard afterall.
  11. May 27, 2019 at 9:55 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oh that's good. Where at? Doing something you hopefully like more?
  12. May 27, 2019 at 9:59 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Could mean more fires if it stops...
    Sorry to jump in here at random, I’ll go back to where I belong :oops:
    BossFoss and m3bassman like this.
  13. May 28, 2019 at 8:34 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Haven't seen that with PTT, but when my battery was going out, I got random restarts when it tried to draw too much power. Could be what's happening when you start transmitting with PTT.
  14. May 28, 2019 at 8:51 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    I saw my restarts two times - first, when I thought I was going over larger bumps (and I chalked up to battery connection) but could easily have been APRS transmitting - which to your point is the same as PTT. Second, when I'd turn the key to start the engine; the starter would pull enough current that the radio wouldn't have enough to keep running and it'd restart. Don't have that problem at all with the new battery - radio stays on even as the starter cranks.
  15. May 28, 2019 at 11:54 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    If I recall we fixed that issue on trail with a tightened battery terminal on Dan's rig.
    m3bassman likes this.
  16. May 28, 2019 at 6:22 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    02 Toyota Tacoma TRD "El Brah-co"
    Toytec BOSS with Dakars
    Curious what people are connecting to their non relayed, fused bussman circuits. CB seems to be the most common, anything else?
  17. May 28, 2019 at 6:27 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I had a 12v outlet in the bed for the fridge too.
    Cb I'd probably do direct to battery to try and not have any ground loop issues.
    Reh5108 and Pltmnky[QUOTED] like this.
  18. May 28, 2019 at 6:46 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Well boys and girls, I've been doing some serious thinking.
    It's a possibility I'll be looking to sell the big cheese in the near future. Baby #2 requires a bigger car for Jen. And I'd take over driving the fiesta.
    I won't bore you with my thoughts but it's the best move financially and for where I now live. I don't want to watch it rust away here.
    That being said, if any of you are interested, or know someone who might be let me know. This is very preliminary and I haven't even thought about pricing yet since I haven't done all my research yet but I'm going to be fair and try to leave the sentiment behind.
    :pout:
  19. May 28, 2019 at 7:06 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    :lalala: Don’t do it man. Buy third vehicle, leave Tacoma in the garage all winter long. Boom, problem solved.
  20. May 28, 2019 at 7:08 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Noooooooooooooooooooo
    Sad day.
    But understandable..
    I might have a friend looking. Actually who you should ask first is Tom the guy we wheeled with at Goose. He is getting rid of the Nissan and wants a 2nd gen. Might not want the manual though..
