Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jun 7, 2019 at 9:32 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    nice! haha
    except its in vernal haha
    The house I just looked at was 1800 sq ft. Easly could have add on another 600'.
    JKO1998[QUOTED] likes this.
  2. Jun 7, 2019 at 9:40 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Vernals a nice place if you ignore the oil trash, lazy tribe and the boom and bust.
    When was the last time you guys went through? 2014?
    gordi likes this.
  3. Jun 7, 2019 at 10:07 AM
    JKO1998
    Utah
    Judging by the fact that the house is 3/4 of a million dollars, the PO probably didn’t care about the heat bill that much.
  4. Jun 7, 2019 at 10:24 AM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    That’s cool as hell, Monte! Keep posting up pics and status as you go so I can nerd out on it!
  5. Jun 7, 2019 at 10:40 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    mm I think I've been through there like maybe even last year. Or 2017 at the latest.
    Yeah should be fun. Have a lot of gear to build and more to just get before I have a real nice setup at the house again. But getting there.
  6. Jun 7, 2019 at 3:28 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Im blind!!!
    Jk
    Looks good!
    m3bassman likes this.
  7. Jun 7, 2019 at 3:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ive found on my soldering work bench that I wish i had light behind me too that was just as bright. Not sure how im gonna do that yet though.
  8. Jun 7, 2019 at 4:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Eh yeah I guess. Might get a floor lamp
  9. Jun 8, 2019 at 7:41 AM
    INBONESTRYKER
    INBONESTRYKER Well-Known Member
    WY
    '96 access cab 3.4 5 spd manual 4X4
    @Blackdawg Do you coat the boards after their all tested?
    Way back when, I needed to be NASA certified to solder boards (school). I only did it when there was time crunch. Fun for the short time but too much sitting. Since all the boards were headed to space they were coated with some kind of plastic. Purpose of which to protect the circuits from any stray metal bits (wire clippings & small drill or tapping chips) that might escape from... floating and shorting circuits. After the dip coating and before curing they were put in a vacuum chamber to degas the coating and to force it under the components. Didn't want the launch vibration to shake the parts off. It was different then all discrete components instead of a few chips; hand instead of wave soldering.
    I'll shut up now!
    T
  10. Jun 8, 2019 at 7:55 AM
    jubei
    NoCo
    Stuff. Also things.
    You can buy conformal coating in an aerosol can too if you’re planning on going this route, Monte.
    @Blackdawg
  11. Jun 8, 2019 at 10:20 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Speedytech7 and turbodb like this.
  12. Jun 8, 2019 at 10:54 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No I don't plan on that. My stuff definitely won't be going to space so no need but that makes sense from a safety point.
    In fact for me it's the opposite, I'll want mine easily repairable and the ability to modify the circuit. I'm adding small daughter boards to these..even tho there 4 already, to create an insert point in the circuit.
    I used to use 4-5 of those at Tim's place. Or similar anyways.
    Weren't battery powered though. Helped a lot.
  13. Jun 8, 2019 at 11:11 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Only 3/4 of a mil, that's amateur hour in the PNW and those penny pinching bastards still winge about their power and heat bills haha
    gordi likes this.
  14. Jun 8, 2019 at 11:12 AM
    Digiratus
    Roaming the PNW
    The RedHead
    The Tesla causes the bill to go up.
    Speedytech7[QUOTED] likes this.
  15. Jun 8, 2019 at 11:13 AM
    Speedytech7
  16. Jun 8, 2019 at 11:14 AM
    Digiratus
    Roaming the PNW
    The RedHead
    White walls and ceiling helps a lot too.
  17. Jun 8, 2019 at 11:15 AM
    Speedytech7
    This is true, does it still count as white if one of mine is covered in greasy hand prints haha
  18. Jun 8, 2019 at 11:19 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Yup. Still white. Greasy white like a well loved garage should be.
    And the LC looks good in there but I'm wondering how much clearance you have for the roof. Looks like a tight fit.
  19. Jun 8, 2019 at 11:22 AM
    Speedytech7
    The wideangle lens is just playing tricks, it has about 4 inches off the roof rack which is going in the shit can soon. But on 35s and with the tent it will have zero hopes of being garage-able which is fine, it is robust, it can enjoy the great outdoors full time
  20. Jun 8, 2019 at 10:19 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    SconnieHailer and jubei like this.
