Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jun 15, 2019 at 6:28 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  2. Jun 15, 2019 at 6:28 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Drone is used for light painting. So the bolts of lighting is actually a drone. He does some cool shit
  3. Jun 15, 2019 at 6:30 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Most of the trails that are "kwown" is because they get a lot of traffic. Not so much in Wyo and MT which is nice.
  4. Jun 15, 2019 at 6:31 PM
    Labbi85
    Labbi85 Well-Known Member
    I am planning to enter Wyoming on the north east corner and then going through bighorn NF to Yellowstone park, and from there I thought go to Montana...or maybe I do the same path the opposite side
  5. Jun 15, 2019 at 6:38 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well stop at devil's tower since you'll drive by it.
    Stopping at the tongue river canyon is cool. It's a short walk to the open cave there which goes almost 2 miles down. Bring some flash lights and check it out.
    Up into the big horns if you want to take the dirt road way you could do red grade road from Sheridan all the way up into the mountains it will come out onto the highway eventually. Tons and tons of camping and options for roads to do whatever you want off or red grade. Hunt mountain road is kind of the only other road to get across the mountain sort of. Otherwise you'll be going in and out.
    Not really anything towards Yellowstone as a lot of private land blocks access. That and the mountains are so rugged there's just no roads to begin with. Everything I know of in that area is longish in and out trails. But there are a few.
    I wouldn't do morrison alone in a 2nd gen personally. Plus that won't open till July 15th at the earliest as will be the same for all the other trails up there mostly.
    You could swing out to the Pryor's from the big horns which are pretty cool to cross.
  6. Jun 15, 2019 at 6:38 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    What Monte said. He's using a drone with a big Fenix spot light on it. Must be remote triggered to do waypoints on those pillars. Super cool out of the box use for a drone.
  7. Jun 15, 2019 at 6:59 PM
    Labbi85
    Hey thanks for all the recommendations, I will definitely save your reply.
    With the Morrison Trail I am not sure yet if I want to do it or not, is it really bad or are the switchbacks the only nerve-racking part of the trail? I did last year one or two sketchy trails in Colorado, which turned out to be ok but at the moment of doing it I would have been happy not to attempt it.
    We (friend and I) are planning to leave MI first week of August tho, because most when not all trails are normally open by then.
  8. Jun 15, 2019 at 7:08 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The trail isnt bad. The switch backs are no joke. Not super hard to drive per say but should be taken seriously in a life threatening way. They are narrow and very steep which is really the tricky part as the Apex of the corners can have 2-4' difference or more. There is literally nothing to winch off of if you get in a bad situation. Thus why going alone isn't super recommended especially with bigger trucks such as yours.
    If you've done a lot of offroading you'll be smart and it'll be fine.
    Also if you're a double cab long bed...would not do it. Nothing longer than a 2nd gen dbl short.
    SconnieHailer likes this.
  9. Jun 15, 2019 at 7:08 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Ah, light painting using the drone to paint the light. Very cool.
    SconnieHailer[QUOTED] likes this.
  10. Jun 15, 2019 at 9:29 PM
    Pltmnky
    Pltmnky TACO Corp.
    1/2 DUB 1/2 Moran
    02 Toyota Tacoma TRD "El Brah-co"
    Toytec BOSS with Dakars
    Wyoming trails are locals only bruh! :rofl:
    Kidding, just depends on where you go. Big horns and wind rivers have the most, if you look at the ohv maps online, that is your best bet.
    Digiratus likes this.
  11. Jun 15, 2019 at 10:24 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I love this time of year. We are one week away from the summer solstice, the longest day of the year. At 9:30 pm local there was still enough light out to be able to setup camp.
    Monte would love it. :p
    Pltmnky and turbodb like this.
  12. Jun 15, 2019 at 10:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yes I do :D
    Digiratus[QUOTED] likes this.
  13. Jun 16, 2019 at 2:39 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    God damn it I hate doing motor mounts. I can not get one to line up. It's so close but nothing I do gets it there. So frustrating and fatiguing.
  14. Jun 16, 2019 at 6:23 AM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Dang guy, burning the morning oil just a bit there.
  15. Jun 16, 2019 at 10:05 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Go give your Dad a hug. And thank him for putting up with all your crap. :D
    Happy Fathers Day Dads.
    Justrom, jubei, Speedytech7 and 3 others like this.
  16. Jun 16, 2019 at 7:52 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Gotta get it done!
    Was a bitch. Jesus. But it's done.
    And good Lord Frankenstein sounds good. Man I miss driving him. Really makes you want to drive fast haha
    BossFoss[QUOTED] likes this.
  17. Jun 16, 2019 at 8:00 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    No matter what stiff or new motor mounts are a bitch.
  18. Jun 16, 2019 at 10:07 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    True. I remember doing the bomb proof and 4xi one last time was a bitch. These were especially bad as it was all new for the block mounts too
  19. Jun 16, 2019 at 10:13 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    If you are flexible on dates,
    What trails did you do in Colorado? If you're in an auto I don't see Morrison being too bad at all. Having to do 3 point turns going uphill in a standard gets a little sketchy though. It definitely isn't a trail to be taken lightly because of the consequences if a mistake is made but its not very technical in my opinion.
    Blackdawg[OP] likes this.
  20. Jun 16, 2019 at 10:15 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Agreed.
    Though it more like 5 point turns haha
    m3bassman likes this.
