Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jul 23, 2019 at 9:20 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Idk Id have to look tomorrow, thought the ignition was the go between the battery and the main relay
  2. Jul 23, 2019 at 9:23 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I'll check to after work.
  3. Jul 23, 2019 at 9:49 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No doubt. Will look tomorrow. Hopefully not the ignition switch is all I want.
    m3bassman[QUOTED] likes this.
  4. Jul 23, 2019 at 10:03 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    BossFoss likes this.
  5. Jul 23, 2019 at 10:14 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Does El Pequeño Rojo have two chassis grounds? One between the engine and the firewall and another from the battery to the fender next to it?
  6. Jul 23, 2019 at 10:15 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  7. Jul 23, 2019 at 10:15 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yes I believe so.
  8. Jul 23, 2019 at 10:20 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I would verify continuity on both with a multimeter. I can't recall where but I've read those chassis grounds play a big role in the loop and can impact dash and intrumentation.
    Blackdawg[QUOTED][OP] likes this.
  9. Jul 23, 2019 at 10:23 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  10. Jul 23, 2019 at 10:28 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
  11. Jul 23, 2019 at 10:31 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not really.
    The difference is you remove the entire stock bushing and then just put in a poly bushing with a sleeve(all bushings have the sleeve). Vs like the Hite lines that many folks do as they are poly but just like oem. They ha e a metal outer sleeve too which these eliminate basically making the install easier and certainly the replacement easier.
    Which is one if the reasons why I went with solo lcas on Igor..
    JKO1998[QUOTED] likes this.
  12. Jul 23, 2019 at 10:37 PM
    Digiratus
    Roaming the PNW
    The RedHead
  13. Jul 23, 2019 at 11:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Because when they go bad...and they will due to how the came tabs force them to be twisted for your alignment..you might have to battle with a rusted up outer sleeve vs just popping out some bushings.
    I think it's awesome. I'm gonna get some for the little truck.
    But yeah looking for parts for grants truck while his is in Bolivia to keep it road worthy while it's parked for a month. Replacing a lot of bushings.
  14. Jul 24, 2019 at 12:07 AM
    JKO1998
    Utah
  15. Jul 24, 2019 at 7:15 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    So far away haha
    Tough call. The SPC bushings are one solid piece vs a split design. not sure you could get it out without hurting it. And you don't know if you pull it and then will see damage or not till you're there.
    I'd follow the rule of "since it's out, replace it" in this case.
  16. Jul 24, 2019 at 9:01 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah thats a draw back on the SPCs, can't grease them(the mount bushings). Any time you can't actively grease it later, I grease the hell out of it haha
    If the uppers are fine I wouldn't be worried about replacing those. They are easier to do IMO than the mount bushings.
  17. Jul 24, 2019 at 9:35 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah I was saying if the ubj is fine leave it. You don't have that many miles on them right?
  18. Jul 24, 2019 at 10:50 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Flat bed looks angled down, maybe it's just the picture.
    The ubj is easy enough to change. Takes 30 minutes. I'd leave them until they're bad.
  19. Jul 24, 2019 at 11:04 AM
    JKO1998
    Utah
    Got that squat going on I think
  20. Jul 24, 2019 at 11:34 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
