Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Jul 25, 2019 at 10:10 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    The engine bay one yes, and inspect those square fuses real close they can look good and ohm out bad, they corrode easily
  2. Jul 25, 2019 at 10:29 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Cracked one trying to get it out..haha
  3. Jul 25, 2019 at 10:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Lol usually I don't. But I guessing those fuses haven't moved in 24 years.
    I'll order some new ones.
  4. Jul 25, 2019 at 10:51 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The dash lit up. I posted it yesterday. I cleaned the ground for the ecu under the intake. Though it showed no signs of corrosion. Dash lit up. And sort of cranked it. But got out to check the engine bay to make sure I had the engine clear before starting.
    Went back in. Nothing. No dash not igintion power.
    Then I sat there in defeat for a second and the dash slowly lit back up. But wouldn't crank and then dead again.
    Super weird.
  5. Jul 25, 2019 at 10:59 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No. The key dinger doesn't even shut off which it should when in the on position.
    That's why I figured the igintion switch was the issue. But I've gone through all the connectors by now and res seated just about everything I can see.
  6. Jul 25, 2019 at 11:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Hmm I don't know actually. Possible. Why?
  7. Jul 26, 2019 at 10:09 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I can see that I suppose. I know it has a tow ball but idk about a harness. I'll check tonight. If i have the energy. Got up super early...okay not that early, but early for me to go biking this morning. Was fun.
    m3bassman[QUOTED] likes this.
  8. Jul 26, 2019 at 11:39 AM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
  9. Jul 26, 2019 at 12:22 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    cool for sure. Not 24k cool though haha
  10. Jul 26, 2019 at 12:29 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    SconnieHailer[QUOTED] likes this.
  11. Jul 26, 2019 at 12:45 PM
    SconnieHailer
    Marc
    Lol that'd teach her to not want to drive my truck :rofl:
    Shed probably think it's cool honestly
    m3bassman likes this.
  12. Jul 27, 2019 at 9:09 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No harness back there. Just the tow package
  13. Jul 27, 2019 at 2:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I'm guess Zane is on to it. Fuse box might just be corroded. Every thing else is fine.
  14. Jul 27, 2019 at 5:04 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    IMG_20190727_175545~3.jpg A few thousand later...
    Speedytech7, Pltmnky, Justrom and 3 others like this.
  15. Jul 27, 2019 at 5:11 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Wowza that's quite the puzzle!
  16. Jul 27, 2019 at 7:43 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well I pulled both fuse boxes apart. Both look fine. No corrosion anywhere.
    I'm going to replace my positive terminal though as it's an aftermarket one. Not done great. Voltages read fine everywhere but the in cab fuse box.
    Also dude reached out to me with a pretty clean mkiii Supra. Pretty much everything I want. It's clean, lots of good spare parts. Nothing major needs done but somethings to tighten up.
    Plus it's professionally 2jzgte swapped with 5spd and targa top.
    I very much want..
    Speedytech7, m3bassman, jubei and 2 others like this.
  17. Jul 27, 2019 at 8:45 PM
    SconnieHailer
    Marc
    You only "need" one taco right?
  18. Jul 27, 2019 at 8:58 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    True haha might be enough to get me to sell one!
  19. Jul 27, 2019 at 9:50 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  20. Jul 27, 2019 at 10:22 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Love that. Cool idea and nice work. What's your plan for between the pennies - epoxy fill or something? Or just leaving the gaps?
    Speedytech7 likes this.
